MrBeefy Posted March 4, 2009 Share Posted March 4, 2009 I wonder what the max score one could get on this track? It can't be no more than 72,000 can it? 75,000 is the record on TG. 72,950 is #2... so, I guess there is room for improvement. Seems to be some luck involved. You lose time when there's cars blocking the road. But if somebody is better at squeezing between them they'll be faster vs going in the grass (which is what I have to do half the time). I'd have to agree. It seems some games there's a plethora of cars that are side by side blocking you path while other times they're stacked just right to zigzag between them. Yeah its alot better to squeeze by them if you can but I found if its on a bad turn it may be easier just to hit the grass and quickly swerve back. Dag nabbit i'm no longer in first looks like its back to getting my hand to cramp again. Link to comment Share on other sites More sharing options...
Almost Rice Posted March 4, 2009 Share Posted March 4, 2009 70600 crashed twice. Link to comment Share on other sites More sharing options...
MrBeefy Posted March 4, 2009 Share Posted March 4, 2009 I've found the hardest turn is turn 4. How do some of you handle this turn. When I know its coming up I get as close on the left as I can then gun it hard left running a little into the grass then I should be able to take the rest of the turn without worrying about crashing into a sign on the right. Only problem with this is when there are cars there it screws that tech. up. Link to comment Share on other sites More sharing options...
aftermac Posted March 4, 2009 Share Posted March 4, 2009 I've found the hardest turn is turn 4. How do some of you handle this turn. When I know its coming up I get as close on the left as I can then gun it hard left running a little into the grass then I should be able to take the rest of the turn without worrying about crashing into a sign on the right. Only problem with this is when there are cars there it screws that tech. up. I handle it the same way you do and hope a car doesn't show up. If someone has a better suggestion, I'd love to hear it! Also, what speed do you shift from Lo to Hi gear? I usually do at about 80-100 MPH. Link to comment Share on other sites More sharing options...
MrBeefy Posted March 4, 2009 Share Posted March 4, 2009 I've found the hardest turn is turn 4. How do some of you handle this turn. When I know its coming up I get as close on the left as I can then gun it hard left running a little into the grass then I should be able to take the rest of the turn without worrying about crashing into a sign on the right. Only problem with this is when there are cars there it screws that tech. up. I handle it the same way you do and hope a car doesn't show up. If someone has a better suggestion, I'd love to hear it! Also, what speed do you shift from Lo to Hi gear? I usually do at about 80-100 MPH. 156ish since Lo seems to max out around 160. Link to comment Share on other sites More sharing options...
xZanU Posted March 4, 2009 Share Posted March 4, 2009 I believe my best qualifying lap was 56:37. I regularly finish with 61 units remaining... I keep trying for 62, but I'm not sure it's possible. Wow, that's great. I still hope to break into the 57's. Link to comment Share on other sites More sharing options...
xZanU Posted March 4, 2009 Share Posted March 4, 2009 72,650 I think i got a great high score. I saved 5 pictures. I'm real proud of this score. I hope it holds up. Nice one, you are in 1st place : ) Link to comment Share on other sites More sharing options...
darthkur Posted March 5, 2009 Author Share Posted March 5, 2009 I've found the hardest turn is turn 4. How do some of you handle this turn. When I start to approach that turn I hit the brakes for a second then cut left but trying to keep in the middle of the road in case there's a car on either side. If I'm still heading into the curve too fast after that I'll down shift for a moment or two. Yeah you'll lose some time but not nearly as much as you would if you crash. I handle it the same way you do and hope a car doesn't show up. If someone has a better suggestion, I'd love to hear it! Also, what speed do you shift from Lo to Hi gear? I usually do at about 80-100 MPH. I usually shift by the sound of the engine, just like in an actual standard transmission vehicle. It's something you just have a feel for. I know that's probably not all too helpful. Link to comment Share on other sites More sharing options...
roadrunner Posted March 5, 2009 Share Posted March 5, 2009 (edited) I believe my best qualifying lap was 56:37. I regularly finish with 61 units remaining... I keep trying for 62, but I'm not sure it's possible. Wow, that's great. I still hope to break into the 57's. I never looked to see what my qualifying lap times were. I'll have to take a look at that the next time i play. Edited March 5, 2009 by roadrunner Link to comment Share on other sites More sharing options...
aftermac Posted March 5, 2009 Share Posted March 5, 2009 72,550 Oh, so close... Link to comment Share on other sites More sharing options...
roadrunner Posted March 5, 2009 Share Posted March 5, 2009 It doesn't look like my score will hold up for much longer. It might take at least 73,000 To win this round. I don't know if i can do better than 72,650. Everything had to go just right. Qualify first. Avoid the water puddles. Don't crash. And alot of luck. Link to comment Share on other sites More sharing options...
xZanU Posted March 5, 2009 Share Posted March 5, 2009 72,450 Yes! I exclaim because I did not crash this time : ) Now if I can only get a break with the wall of three cars on the turn with a water puddle in the middle I will be in good shape. Link to comment Share on other sites More sharing options...
roadrunner Posted March 5, 2009 Share Posted March 5, 2009 (edited) 73,350 I can't believe how good i did!! WOW!! Edited March 9, 2009 by roadrunner Link to comment Share on other sites More sharing options...
gdement Posted March 5, 2009 Share Posted March 5, 2009 (edited) I've found the hardest turn is turn 4. How do some of you handle this turn. When I know its coming up I get as close on the left as I can then gun it hard left running a little into the grass then I should be able to take the rest of the turn without worrying about crashing into a sign on the right. Only problem with this is when there are cars there it screws that tech. up. I handle it the same way you do and hope a car doesn't show up. If someone has a better suggestion, I'd love to hear it! Also, what speed do you shift from Lo to Hi gear? I usually do at about 80-100 MPH. 156ish since Lo seems to max out around 160. I used to shift late, but when I was playing I experimented with shifting sooner. I got in the habit of shifting at 120 instead. I noticed the speed picks up quickly after shifting so I think this is faster. But I don't know what's ideal. ... these scores are getting insane. I seriously doubt I can improve that much, but it's worth a try. Edited March 5, 2009 by gdement Link to comment Share on other sites More sharing options...
xZanU Posted March 6, 2009 Share Posted March 6, 2009 73,350 And here you thought you would not do any better. Good Job. Link to comment Share on other sites More sharing options...
roadrunner Posted March 6, 2009 Share Posted March 6, 2009 73,350 And here you thought you would not do any better. Good Job. Thanks! I'm still trying to do better, i haven't quit. Has anybody ever crashed at the end of the qualifying lap. That's happened to me quite a few times. I'm glad we're not racing the Suzuka track. That track is very difficult. Link to comment Share on other sites More sharing options...
aftermac Posted March 6, 2009 Share Posted March 6, 2009 73,350 And here you thought you would not do any better. Good Job. Thanks! I'm still trying to do better, i haven't quit. Has anybody ever crashed at the end of the qualifying lap. That's happened to me quite a few times. I'm glad we're not racing the Suzuka track. That track is very difficult. You're putting up some great times... don't know if I'll be able to catch up to you. I've crashed a couple times after the finish line on the qualifying lap. Link to comment Share on other sites More sharing options...
roadrunner Posted March 6, 2009 Share Posted March 6, 2009 (edited) 73,750 I made the picture bigger. Edited March 8, 2009 by roadrunner Link to comment Share on other sites More sharing options...
MrBeefy Posted March 6, 2009 Share Posted March 6, 2009 Better still not top though 73350 Link to comment Share on other sites More sharing options...
theKLT Posted March 7, 2009 Share Posted March 7, 2009 66000 Link to comment Share on other sites More sharing options...
aftermac Posted March 8, 2009 Share Posted March 8, 2009 74,400 I thought I was having a decent race when I was playing, but I didn't expect this! Link to comment Share on other sites More sharing options...
roadrunner Posted March 8, 2009 Share Posted March 8, 2009 (edited) ^^^^ WOW!!! You only saved 1 picture? I think i would have saved more if that was my score. Good luck to anybody who can beat that awesome score. Edited March 8, 2009 by roadrunner Link to comment Share on other sites More sharing options...
roadrunner Posted March 8, 2009 Share Posted March 8, 2009 For fun i raced the test track. And i also figured out how to make my saved pictures bigger. From now on when i post a picture i'll make it big so it's easier to see. Link to comment Share on other sites More sharing options...
aftermac Posted March 8, 2009 Share Posted March 8, 2009 ^^^^ WOW!!! You only saved 1 picture? I think i would have saved more if that was my score. Good luck to anybody who can beat that awesome score. Thanks! Yeah, I only saved one... but, if that score holds up I might have it framed! There's still a week left, so I'm sure you guys will make a good run at it! Link to comment Share on other sites More sharing options...
atomickneedrop Posted March 11, 2009 Share Posted March 11, 2009 68650 Link to comment Share on other sites More sharing options...
