Wickeycolumbus Posted May 7, 2009 Share Posted May 7, 2009 I wanted to take a stab at making a RAM based game, so I decided to try to do Combat. Right now, it is two player, and the tanks fire automatically. When you hit your opponent's tank, your tank gets larger, and your opponent's gets smaller. There are several bytes free, so let me know if you have suggestions! The tanks can only move vertically, I am not sure If I can make them move horizontally in only 128 bytes. Archive_6.zip Quote Link to comment Share on other sites More sharing options...
Kojote Posted May 8, 2009 Share Posted May 8, 2009 Wickeycolumbus nice to see you joining the RAM game fun Just on a sidenote, such games would also qualify for my compo, if they match the theme =) Quote Link to comment Share on other sites More sharing options...
Wickeycolumbus Posted May 9, 2009 Author Share Posted May 9, 2009 I saved a few bytes here and there, 16 bytes free total. I am going to try using the fire button to fire rather than automatic firing. I have found it useful since I make no use of the stack, to use the stack pointer as an extra 'register'. In initialization, set the SP to any byte you will use frequently in your game loop, and when you want to access that number, do a tsx, and x contains the value I hope this helps other people doing RAM based games. Wickeycolumbus nice to see you joining the RAM game fun icon_smile.gif Just on a sidenote, such games would also qualify for my compo, if they match the theme =) Thanks Kojote! I want to enter the contest, but I have not yet come up with a good idea for a puzzle game. RAMCombat2.zip Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted May 9, 2009 Share Posted May 9, 2009 Welcome to the club Wickey! BTW: For checking collision registers, you should use BIT, which will save some bytes. For the joysticks, you can load SWCHA into A and then use repeated LSRs. Also think about looping instead of repeating similiar code for both players. Quote Link to comment Share on other sites More sharing options...
Wickeycolumbus Posted May 10, 2009 Author Share Posted May 10, 2009 (edited) I added some sound when the tanks get hit Welcome to the club Wickey! For the joysticks, you can load SWCHA into A and then use repeated LSRs I am not quite sure I understand what you are saying. How would I LSR what I am ANDing? RAMCombat3.zip Edited May 10, 2009 by Wickeycolumbus Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted May 10, 2009 Share Posted May 10, 2009 I am not quite sure I understand what you are saying. How would I LSR what I am ANDing? lda SWCHA lsr bcc .skipRightUp ... .skipRightUp lsr bcc .skipRightDown ... .skipRightDown ... I think you got the idea. Works also with ASL e.g. if you are only interested into the left player joystick. Quote Link to comment Share on other sites More sharing options...
Wickeycolumbus Posted May 10, 2009 Author Share Posted May 10, 2009 I am not quite sure I understand what you are saying. How would I LSR what I am ANDing? lda SWCHA lsr bcc .skipRightUp ... .skipRightUp lsr bcc .skipRightDown ... .skipRightDown ... I think you got the idea. Works also with ASL e.g. if you are only interested into the left player joystick. Cool, thanks. Saved 4 bytes Horizontal movement is next! (hopefully) RAMCombat4.zip Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted May 11, 2009 Share Posted May 11, 2009 Horizontal movement is next! (hopefully) Use relative movements (HMxy) only. RESPx is using way too much bytes. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted May 27, 2009 Share Posted May 27, 2009 Any more progress on this one? Quote Link to comment Share on other sites More sharing options...
Wickeycolumbus Posted May 27, 2009 Author Share Posted May 27, 2009 Any more progress on this one? Not much I haven't had much time, but now one of the players can move horizontaly (sort of) Archive_8.zip Quote Link to comment Share on other sites More sharing options...
Wickeycolumbus Posted June 16, 2009 Author Share Posted June 16, 2009 (edited) I had some time to work on this today. I decided to drop horizontal movement and use the button to fire instead. I only need to free 4 more bytes so I can include the M1/PF collision detection, let me know if you see anywhere I can free some bytes! EDIT: Now I only need 2 more bytes Archive_12.zip Edited June 16, 2009 by Wickeycolumbus Quote Link to comment Share on other sites More sharing options...
+Omegamatrix Posted June 16, 2009 Share Posted June 16, 2009 (edited) Hi Wickey, Maybe something like this? ldx #1 .loopCollisions: lda CXMOP,X bpl .skipIncrement inc P0_End,X dec P1_End,X lsr AUDV0; will this work? .skipIncrement dex bpl .loopCollisions ; X=$FF, so no need for TSX below I'm using your LSR AUDV0 in there. My question is does that work? It's great if it does. I did not check if you got your ram lined up like this already. I couldn't get your code to compile, so it's untested. There was a branch out of range (easy fix), but a deeper problem with some label mismatch in the "sprite positioning" routine. I was using the non-mac assembly file here. Edited June 16, 2009 by Omegamatrix Quote Link to comment Share on other sites More sharing options...
Wickeycolumbus Posted June 16, 2009 Author Share Posted June 16, 2009 Hi Wickey, Maybe something like this? ldx #1 .loopCollisions: lda CXMOP,X bpl .skipIncrement inc P0_End,X dec P1_End,X lsr AUDV0; will this work? .skipIncrement dex bpl .loopCollisions ; X=$FF, so no need for TSX below I'm using your LSR AUDV0 in there. My question is does that work? It's great if it does. I did not check if you got your ram lined up like this already. I couldn't get your code to compile, so it's untested. There was a branch out of range (easy fix), but a deeper problem with some label mismatch in the "sprite positioning" routine. I was using the non-mac assembly file here. That will not work because of these two lines: inc P0_End,X dec P1_End,X P0_End, P1_End, P0_Y, and P1_Y are a few bytes apart (this saves 4 bytes) I think I may have come up with a solution though. The lsr AUDV0 works BTW, but you have to clear AUDV0 every frame. Quote Link to comment Share on other sites More sharing options...
+Omegamatrix Posted June 16, 2009 Share Posted June 16, 2009 (edited) That will not work because of these two lines: inc P0_End,X dec P1_End,X P0_End, P1_End, P0_Y, and P1_Y are a few bytes apart (this saves 4 bytes) Oh well, I tried. The lsr AUDV0 works BTW, but you have to clear AUDV0 every frame. I wonder though if it it is reading INPT1, and then writing it back into AUDV0? If the value from the register is being loaded from memory, shifted, and then put it back into the memory? INPT1 is what is read when you try to read AUDV0, according to the memory map. Edited June 16, 2009 by Omegamatrix Quote Link to comment Share on other sites More sharing options...
Wickeycolumbus Posted June 16, 2009 Author Share Posted June 16, 2009 Ok, just one more byte now! Archive_13.zip Quote Link to comment Share on other sites More sharing options...
Wickeycolumbus Posted June 17, 2009 Author Share Posted June 17, 2009 (edited) Got it! I forgot I did not use tsx to get #$FF into X any more, so I set the stack pointer to 1 so I could save a byte by doing a tsx instead of the ldx #1. I think this will be the final version. Archive_14.zip Edited June 17, 2009 by Wickeycolumbus Quote Link to comment Share on other sites More sharing options...
