usage of datatypes/structures in dasm possible?
I wonder if it is possible to have something like datatypes in dasm. I'll illustrate my 'problem':
Right now, I've the following declaration for RAM usage:
Ship1Struct
PositionShip1X		.word
PositionShip1Z		.word
VelocityShip1X		.word
VelocityShip1Z		.word
DirectionShip1		.byte
Ship2Struct
PositionShip2X		.word
PositionShip2Z		.word
VelocityShip2X		.word
VelocityShip2Z		.word
DirectionShip2		.byte
I wonder if it would be possible to use something like:
Type ShipStruct
 PositionX			.word
 PositionZ			.word
 VelocityX			.word
 VelocityZ			.word
 Direction			.byte
End Type
Ship1Struct		.ShipStruct
Ship2Struct		.ShipStruct
Any ideas are welcome.
Edited by roland p
How about using a macro?
			MAC SHIP;  1st parameter the var name prefix
{1}_PositionX	.word
{1}_PositionZ	.word
{1}_VelocityX	.word
{1}_VelocityZ	.word
{1}_Direction	.byte
		ENDM
; declare the ships...
 SHIP Ship1
 SHIP Ship2
Then you'd access the vars as "Ship1_PositionX", etc. The above will work, barring any minor typos.
Having said that, I don't think this is a great way to define variables. I'd have each variable indexed by ship number. Where you have word variables, split into two with a low/high, or double the index before lookup.
Just for reference, macros can do interesting stuff... here's a few to browse through...
ROM_BANK_SIZE			   = $800
		MAC NEWBANK; bank name
			SEG {1}
			ORG ORIGIN
			RORG $F000
BANK_START	  SET *
{1}			 SET ORIGIN / 2048
ORIGIN		  SET ORIGIN + 2048
_CURRENT_BANK   SET {1}
		ENDM
		MAC DEFINE_1K_SEGMENT; {seg name}
			ALIGN $400
SEGMENT_{1}	 SET *
BANK_{1}		SET _CURRENT_BANK
		ENDM
		MAC CHECK_BANK_SIZE; name
.TEMP = * - BANK_START
ECHO {1}, "(2K) SIZE = ", .TEMP, ", FREE=", ROM_BANK_SIZE - .TEMP
#if ( .TEMP ) > ROM_BANK_SIZE
ECHO "BANK OVERFLOW @ ", * - ORIGIN
ERR
#endif
		ENDM
		MAC CHECK_HALF_BANK_SIZE; name
 ; This macro is for checking the first 1K of ROM bank data that is to be copied to RAM.
 ; Note that these ROM banks can contain 2K, so this macro will generally go 'halfway'
ECHO {1}, "(1K) SIZE = ", .TEMP, ", FREE=", ROM_BANK_SIZE/2 - .TEMP
#if ( .TEMP ) > ROM_BANK_SIZE/2
ERR
#endif
		ENDM
		MAC OVERLAY; {name}
SEG.U OVERLAY_{1}
org Overlay
		ENDM
MAC VALIDATE_OVERLAY
	LIST OFF
	#if * - Overlay > OVERLAY_SIZE
		ERR
	#endif
	LIST ON
ENDM
 ; Macro inserts a page break if the object would overlap a page
MAC OPTIONAL_PAGEBREAK; { string, size }
	LIST OFF
	IF (>( * + {2} -1 )) > ( >* )
EARLY_LOCATION  SET *
		ALIGN 256
		ECHO "PAGE BREAK INSERTED FOR ", {1}
		ECHO "REQUESTED SIZE = ", {2}
		ECHO "WASTED SPACE = ", *-EARLY_LOCATION
		ECHO "PAGEBREAK LOCATION = ", *
	ENDIF
	LIST ON
ENDM
MAC CHECK_PAGE_CROSSING
	LIST OFF
#if ( >BLOCK_END != >BLOCK_START )
ECHO "PAGE CROSSING @ ", BLOCK_START
#endif
	LIST ON
ENDM
MAC CHECKPAGE
LIST OFF
	IF >. != >{1}
		ECHO ""
		ECHO "ERROR: different pages! (", {1}, ",", ., ")"
		ECHO ""
	ERR
	ENDIF
	LIST ON
ENDM
MAC CHECKPAGE_BNE
	LIST OFF
	IF 0;>(. + 2) != >{1}
		ECHO ""
		ECHO ""
		ERR
	ENDIF
	LIST ON
		bne	 {1}
ENDM
MAC CHECKPAGE_BPL
	LIST OFF
	IF (>(.+2 )) != >{1}
		ECHO ""
		ECHO ""
		ERR
	ENDIF
	LIST ON
		bpl	 {1}
ENDM
IDENTITY	SET 0
MAC IDENT; {object}
#if DEBUG=YES
	lda #IDENTITY
	sta debug_ident
	lda {1}
	sta debug_object
#endif
IDENTITY	SET IDENTITY + 1
ENDM
Cheers
A
Thanks,
I didn't know that labels can be generated too.
I have to agree that indexing looks cleaner than the macro. Actually accessing the data through indexing will be easier too.
Here is how I do data structures in my engine:
; STRUCTURE BUILDING MACROS
; Function:	vcs_CORE_STRUCT
; Purpose:		Define the start of a structure
; Parameters:
;		_offset		=	Initial offset for the structure
; Inputs:	   None
; Returns:	  None
	 mac vcs_CORE_STRUCT; _offset
__struct_offset	set {1}
__struct_base	set {1}
	 endm
; Function:	vcs_CORE_LABEL
; Purpose:		Define a label inside of a structure
; Parameters:
;		_name		=	Name of the label to define
; Inputs:	   None
; Returns:	  None
	 mac vcs_CORE_LABEL; _name
{1}			equ __struct_offset
	 endm
; Function:	vcs_CORE_ENUM
; Purpose:		Define an enumerated label inside of a structure
; Parameters:
; Inputs:	   None
; Returns:	  None
	 mac vcs_CORE_ENUM; _name
__struct_offset	set __struct_offset+1
	 endm
; Function:	vcs_CORE_BYTE
; Purpose:		Define an 8-bit structure value
; Parameters:
; Inputs:	   None
; Returns:	  None
	 mac vcs_BYTE; _name
	 endm
; Function:	vcs_CORE_WORD
; Purpose:		Define a 16-bit structure value
; Parameters:
; Inputs:	   None
; Returns:	  None
	 mac vcs_WORD; _name
__struct_offset	set __struct_offset+2
	 endm
; Function:	vcs_CORE_ARRAY
; Purpose:		Define an array embedded inside of a structure
; Parameters:
;		_name		=	Name of the array to define
;		_size		=	Size of the array
; Inputs:	   None
; Returns:	  None
	 mac vcs_CORE_ARRAY; _name, _size
__struct_offset	set __struct_offset+_size
	 endm
; Function:	vcs_CORE_END
; Purpose:		Define the end of a structure
; Parameters:
;		_prefix		=	Prefix name of the finishing structure
; Inputs:	   None
; Returns:	  None
	 mac vcs_CORE_END; _prefix
{1}_SIZEOF	equ __struct_offset
{1}_END		equ __struct_offset-__struct_base
	 endm
; Function:	vcs_CORE_BITDEF
; Purpose:		Define a bit definition and mask
; Parameters:
;		_prefix		=	Prefix name for the bit definition
;		_name		=	Name of the bit definition
;		_bit		=	Starting bit number
;		_mask		=	Bit mask
; Inputs:	   None
; Returns:	  None
	 mac vcs_CORE_BITDEF; _prefix, _name, _bit, _mask
{1}B_{2}	equ {3}
{1}F_{2}	equ {4}<<{3}
	 endm
--Selgus
I've decided to keep the declaration as it is. I think constructing the variable names is a case of bad practise, at least from my point of view.
But the previous posts gave me the idea to change my macros, and only pass the ship number when you call them. The macro will then reconstuct the variables (like: LDA position{1}X). This will make my macro calling routines much cleaner which was my main goal.
What's the benefits of of your macros compared to using the ORG functionality and the DS,byte,word keywords?
I try not to make my source code dependent on any one assembler.
I have done this in engines for all different platforms/assemblers so that I can have a consistent way of defining structures, format them like you would in a higher-level language, allow for readability, etc. Plus I have additional macros that allow me to allow negative offsets when you set an indirect register addressing (like on the 68k).
--Selgus
The refactoring of my code is getting along nicely.
The structure of my variables looks now like:
;ships data
SHIP1_POS_X
SHIP1_POS_Z
SHIP1_VEL_X
SHIP1_VEL_Y
SHIP1_DIR
SHIP2_POS_X
SHIP2_POS_Z
SHIP2_VEL_X
SHIP2_VEL_Y
SHIP2_DIR
;playfield data (for drawing playfield)
PLAYFIELD1_GRP0_PTR
PLAYFIELD1_GRP1_PTR
etc.
PLAYFIELD2_GRP0_PTR
PLAYFIELD2_GRP1_PTR
etc.
I can now call my macros like:
CALC_SPRITE SHIP2, PLAYFIELD1   ;ship2 is shown in the upper playfield
CALC_SPRITE SHIP1, PLAYFIELD2   ;ship1 is shown in the lower playfield
I looks now how it whould look like if you where having types.
The downside of this is that the macro's generate unrolled code, maybe I should index the variables like an array, like Andrew said, but the macros can get pretty complex. I don't know what the best way is.
