thekrunchyfrog Posted May 29, 2009 Share Posted May 29, 2009 I checked several sites and videos, then cut the right pin on the chip, but now all I get on when I turn on the NES is a white screen. Any ideas what I did wrong? Quote Link to comment Share on other sites More sharing options...
ApolloBoy Posted May 29, 2009 Share Posted May 29, 2009 Are your games clean? It helps that you clean both your games and the cart connector, since disabling the lockout chip won't fix everything. Quote Link to comment Share on other sites More sharing options...
nathanallan Posted May 29, 2009 Share Posted May 29, 2009 also make sure the screws are all in place for holding the cart slot in place. I have seen broken traces happen when someone tried to 'adjust' the screws by loosening them, hence bending the board until the traces broke. also check the connectors, contacts, all that jazz. Quote Link to comment Share on other sites More sharing options...
shadow460 Posted June 1, 2009 Share Posted June 1, 2009 Time to replace the connector. Even then it still may not be perfect, but a new connector plus disabling the 10NES chip make night and day difference. Quote Link to comment Share on other sites More sharing options...
DeadlyDiskKun Posted June 1, 2009 Share Posted June 1, 2009 Try bending all of the pins up a bit, it can make your NES operate much nicer. Quote Link to comment Share on other sites More sharing options...
Video Posted June 1, 2009 Share Posted June 1, 2009 I'd agree with the above, make sure the games are clean, if it gets the blinky screen befor the mod, snipping the chip isn't goiing to help make it work. Less than $10 gets a new cart edge connector, but I've had luck just bending the pins a tad for a little more life (but have a replacement handy uncase you break one) Quote Link to comment Share on other sites More sharing options...
MasterESGT Posted June 7, 2009 Share Posted June 7, 2009 Try this test: do not put any cart in the NES, press power and see what happened. A steady white screen (no blinking) indicates that the lockout mod is ok. If screen still blinking, the mod is not done correctly. Try to replace the 72 pin connector or clean at least your carts. Quote Link to comment Share on other sites More sharing options...
thekrunchyfrog Posted June 9, 2009 Author Share Posted June 9, 2009 I just got back from Vacation and had a chance to try bending the pins up. It works great. Thanks for the many and quick responses everyone. Great community feeling. Quote Link to comment Share on other sites More sharing options...
