RSS Bot Posted May 30, 2009 Share Posted May 30, 2009 Download Stella Here: http://stella.sourceforge.net/ Download bB Base Build Here: http://www.bataribasic.com/download.html Download bB Latest Build Here: http://www.atariage.com/forums/index.php?s...p;#entry1752068 Download Visual bB Here: http://www.atariage.com/forums/index.php?showtopic=123849 1. Install Stella 2. Create directory c:\Atari2600\bB 3. Extract the contents of the bB base build into the new directory. 4. Set the following environment variables: (Control Panel, System, Advanced, System Environment) bB=c:\Atari2600\bB This sets the install directory for Batari Basic. path=%path%;c:\Atari2600\bB (Append ;c:\Atari2600\bB to your existing path statement) This insures the bB compiler can work from any command prompt. 5. Do a test build of the sample progggy! cd c:\atari2600\bB\samples 2600bas sample.bas It should say build successful! 6. Run this binary in stella 7. Make two new directories under c:\atari2600 Projects and VisualbB 8. Copy the contents of the Visual bB archive to the new directory created above. 9. Run VisualbB.exe In the configuration wizard, specify where things live. Stella lives in c:\program files\stella\stella.exe by default. http://www.atariage.com/forums/index.php?a...;showentry=6136 Link to comment Share on other sites More sharing options...
