fujidude Posted September 2, 2015 Share Posted September 2, 2015 Where can I get the installer where everything is ready to use? I've been poking around but am missing it. Quote Link to comment Share on other sites More sharing options...
Van Posted September 2, 2015 Share Posted September 2, 2015 Here: http://www.wudsn.com/index.php/ide/installation Yogi Quote Link to comment Share on other sites More sharing options...
fujidude Posted September 2, 2015 Share Posted September 2, 2015 Van, I've been there. Those are instructions. Instructions that say install Eclipse 1st, etc. etc. Not too long ago, I swear there was a single file zip or installer that had the entire environment covered (at least for A8), including Eclipse and with everything pre configured. Was I dreaming? Quote Link to comment Share on other sites More sharing options...
Van Posted September 2, 2015 Share Posted September 2, 2015 In the first paragraph of that page: If you are using a Windows operating system, I recommend to download the ready to run zero installation distribution wudsn-ide-win64.zip (for 64-bit Windows) or wudsn-ide-win32.zip (for 32-bit Windows) . It contains the Eclipse Platform, the latest stable version of WUDSN IDE plugin, all supported compilers and an emulator for each supported platform. For 64b Win http://www.wudsn.com/productions/java/ide/downloads/wudsn-ide-win64.zip For 32b Win http://www.wudsn.com/productions/java/ide/downloads/wudsn-ide-win32.zip Yogi Quote Link to comment Share on other sites More sharing options...
fujidude Posted September 3, 2015 Share Posted September 3, 2015 OMG. Indeed they are. I guess my attention was immediately drawn to the contact links, then onto the install instructions where it said to go get Eclipse, and on and on and so forth. Quote Link to comment Share on other sites More sharing options...
Van Posted September 3, 2015 Share Posted September 3, 2015 OMG. Indeed they are. I guess my attention was immediately drawn to the contact links, then onto the install instructions where it said to go get Eclipse, and on and on and so forth. No Problem They are sort of buried Yogi Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted September 3, 2015 Share Posted September 3, 2015 Thanks so much JAC! This is great, the zero effort install is SOOOOO nice. Years ago had your IDE plugin setup but alas between upgrades to my system/ HD crashes had not re-installed it till just a little while ago. So many improvements and enhancements, ( last project was NES/ ASM6 last year, wish I had used WUDSN) The only issue I had during the install. was Java related. The install from a few mounts ago quit working; turns out that I had allowed a 'auto update' request from Java that installed v 8.xx on my XP system (v8 doesn't support XP and removes older versions. WHAT?). Eclipse can not open with this combo, but after I tracked this down and reverted to Java v7 all is well. Currently wanting to do some TRS-80 CoCo stuff and would like very much to try with this IDE. I think I understand the work-around for using another assembler, AS09 for 6809 in this case, but any advice is welcome till I have a more specific question. Again THANK YOU for your efforts, so nice Yogi Java 8 works fine on XP. Ignore the warning box that pops up. All you need to do for Eclipse is include the java installation folder in the path. Mine is here: C:\Program Files\Java\jre1.8.0_60\bin. Quote Link to comment Share on other sites More sharing options...
Van Posted September 3, 2015 Share Posted September 3, 2015 Java 8 works fine on XP. Ignore the warning box that pops up. All you need to do for Eclipse is include the java installation folder in the path. Mine is here: C:\Program Files\Java\jre1.8.0_60\bin. OK will try that. Yogi Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted September 3, 2015 Share Posted September 3, 2015 To help others in the future, here's how to do it. Press the Windows key and hit the break key to bring up System Properties. Click the Advanced tab. Click the Environment Variables button. In the Lower Box, scroll (if necessary) to find Path. Select it and hit Edit Click in the Variable Value box, then use right arrow key to get to the end of the line. Type a semi-colon ; and your path to Java, in my case, it was C:\Program Files\Java\jre1.8.0_60\bin. Press the OK button 3 times. Attached is a picture to make it super easy. 1 Quote Link to comment Share on other sites More sharing options...
fujidude Posted September 3, 2015 Share Posted September 3, 2015 Or WIN-R, CMD, then: path %PATH%;<javapath> But that likely would not be persistent among log-ons. 1 Quote Link to comment Share on other sites More sharing options...
Van Posted September 4, 2015 Share Posted September 4, 2015 Or WIN-R, CMD, then: path %PATH%;<javapath> But that likely would not be persistent among log-ons. Yea this is how I have different tools setup in NP++, thru the NPExec plugin. Setting the path to Java in the EV is probably a good idea but I wouldn't want to have too many GCC based compilers in the EV. Have heard there can be problems. Yogi Quote Link to comment Share on other sites More sharing options...
+JAC! Posted September 4, 2015 Author Share Posted September 4, 2015 (edited) >No Problem They are sort of buried Absolutely true. That has been on my "to fix" list for a long time since meanwhile most people use these downloads. Now there are more obvious indications where they should be. Edited September 4, 2015 by JAC! Quote Link to comment Share on other sites More sharing options...
gozar Posted September 6, 2015 Share Posted September 6, 2015 FYI, on Windows, if you don't have Java and you go to java.com, by default it downloads the 32-bit version. Which means, if you download the 64-bit version of WUDSN, when you try to start Eclipse, it just fails silently. I ended up going to show all downloads (http://java.com/en/download/manual.jsp) and download the 64-bit version. Quote Link to comment Share on other sites More sharing options...
fujidude Posted September 6, 2015 Share Posted September 6, 2015 I think you can have both versions? Quote Link to comment Share on other sites More sharing options...
+JAC! Posted September 7, 2015 Author Share Posted September 7, 2015 Sure you can, but only one of them will become the default. So if you have also both Eclipse versions installed (32/64) you need to explicitly specify the JVM path in one of the "Eclipse.ini" files. So to keep things simple it is recommended to stick to one combination (32/32) or (64/64). Quote Link to comment Share on other sites More sharing options...
Gury Posted September 14, 2015 Share Posted September 14, 2015 JAC, thank you for all your hard work done for others to read. Very educational and interesting for all Atari developers. 1 Quote Link to comment Share on other sites More sharing options...
jeffpiep Posted October 16, 2015 Share Posted October 16, 2015 I ran into problems trying to get WUDSN working on Eclipse 4.5 MARS with Java 1.8 in Ubuntu 14.04. It installs, but then the Preferences pages are incomplete. There is no place to fill in the details on the assemblers. Should it work OK with this configuration, or do I need to use Eclipse 4.3 and Java 1.7? Quote Link to comment Share on other sites More sharing options...
+JAC! Posted October 17, 2015 Author Share Posted October 17, 2015 Sure, based on the compatibility promises of Java & Eclipse it should work. I only have a test setup for the minimum supported version though. Is the "Assembler" section completely missing? If it is present, did you specify the path the to desired compiler (e.g. "MADS")? Without that the detail configuration for that compiler will not even show up. Please attach a screen shot and "<workspace>/.metadata/.log" if the problem persists. Quote Link to comment Share on other sites More sharing options...
jeffpiep Posted October 17, 2015 Share Posted October 17, 2015 Sure, based on the compatibility promises of Java & Eclipse it should work. I only have a test setup for the minimum supported version though. Is the "Assembler" section completely missing? If it is present, did you specify the path the to desired compiler (e.g. "MADS")? Without that the detail configuration for that compiler will not even show up. Please attach a screen shot and "<workspace>/.metadata/.log" if the problem persists. Thank-you for the reply. I should also fess up that I'm running Ubuntu in VirtualBox if that matters. Looks to me like it's GUI problems. You can see in the screen shot the "Assembler" section is blank (in fact it auto-resizes to full screen height and has a vertical scroll bar with lots of blank space. Here's the .log file. I found the error "java.lang.IllegalArgumentException: Location must be absolute: www.wudsn.com/update." Once I saw that, I decided to install from the version specific location. That got be a little farther - the next screen shot shows the Assembler section and the path to DASM. The gui form still doesn't look perfect. Under "2600" and the DASM tab, the gui form is incomplete. Quote Link to comment Share on other sites More sharing options...
fujidude Posted October 17, 2015 Share Posted October 17, 2015 (edited) @jeffpiep: Here are some things to try (individually or in combinations) from the VB/Ubuntu side (if you haven't already): Ensure you have "Guest Additions" installed and running on your VM. Toggle the "Enable 3D Acceleration" on the display tab of the VM's settings. Edited October 17, 2015 by fujidude Quote Link to comment Share on other sites More sharing options...
jeffpiep Posted October 18, 2015 Share Posted October 18, 2015 (edited) @fujidude - thank-you, I hadn't tried it with 3D acceleration off. That worked, although the layout of the "assembler" dialogue is still a little wonky. It is functional. @JAC! - I tried Eclipse 4.4 and it works just fine (with VBox 3D acceleration on and off). Thanks for developing this plug-in. Very nice! Edited October 18, 2015 by jeffpiep Quote Link to comment Share on other sites More sharing options...
+JAC! Posted October 19, 2015 Author Share Posted October 19, 2015 "Location must be absolute: www.wudsn.com/update" appears because the silly input field for the update site URLs doesnt have a default protocol set. It has no effect on the installed software. You have to input "https://www.wudsn.com/update". Probably you implicitly added the "https://" when you put in the version specific URLs. As for the problem with 4.5 I'll try and update my VM and see if I can isolate the issue, but that'll quite quite some time. Quote Link to comment Share on other sites More sharing options...
+xucaen Posted November 8, 2015 Share Posted November 8, 2015 Hi! I am installing the WUDSN add on for the first time. I am trying to use ATasm to build the rainbow example. It's trying to use the MADS compiler but I want it to use ATasm. Here is a quick video of my setup. I know I did something wrong, I just need help seeing it. Thanks! Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted November 8, 2015 Share Posted November 8, 2015 Hi! I am installing the WUDSN add on for the first time. I am trying to use ATasm to build the rainbow example. It's trying to use the MADS compiler but I want it to use ATasm. You need to change the default assembler for the chosen file type. Do so in the file associations dialog: 1 Quote Link to comment Share on other sites More sharing options...
+xucaen Posted November 8, 2015 Share Posted November 8, 2015 Thank you! Quote Link to comment Share on other sites More sharing options...
