Deteacher Posted June 14, 2009 Share Posted June 14, 2009 This week's game is Road Blasters, chosen by Mister VCS. This week will run until Saturday, June 20th, 2009 @ 12:00 Noon, EST. Once I get back from my daughter's ballet recital tonight, I'll add all the info. Here's a link to the ROM to get you started. http://www.rom-world.com/file.php?id=21934 This is the Upright version (Rev. 4) You might need to download the parent roms for this to work (I'm not sure.) Also, please base your score on 1 credit of play (since this game has a continue feature.) Since this is the first time we're using this type of game, there might be bugs to work out, so please bear with me. Link to comment Share on other sites More sharing options...
+SpiceWare Posted June 14, 2009 Share Posted June 14, 2009 rev 4 is the parent rom 7,560 Link to comment Share on other sites More sharing options...
Kurt_Woloch Posted June 15, 2009 Share Posted June 15, 2009 OK, I think this should be enough for today... 84965. Link to comment Share on other sites More sharing options...
aftermac Posted June 15, 2009 Share Posted June 15, 2009 Are we starting from rookie or veteran? Veteran is the default, but this seems to make a difference with the end of level bonuses. Link to comment Share on other sites More sharing options...
+SpiceWare Posted June 15, 2009 Share Posted June 15, 2009 12,350 Link to comment Share on other sites More sharing options...
Deteacher Posted June 15, 2009 Author Share Posted June 15, 2009 Are we starting from rookie or veteran? Veteran is the default, but this seems to make a difference with the end of level bonuses. How about we start at Rookie? That way, all scores will be consistent. If anyone has a better suggestion, I'll entertain them. Link to comment Share on other sites More sharing options...
aftermac Posted June 16, 2009 Share Posted June 16, 2009 7,960 Are we starting from rookie or veteran? Veteran is the default, but this seems to make a difference with the end of level bonuses. How about we start at Rookie? That way, all scores will be consistent. If anyone has a better suggestion, I'll entertain them. Works for me. I just need to use a better controller than my trackpad. Link to comment Share on other sites More sharing options...
+SpiceWare Posted June 16, 2009 Share Posted June 16, 2009 Works for me. I just need to use a better controller than my trackpad. Hit TAB and try adjusting "Dial Sensitivity" under "Analog Controls". Mine used to be 25%, it's now at 15% and I can steer better with my trackball. I tried the same with a PS2 controller's analog stick and that didn't help at all. Link to comment Share on other sites More sharing options...
darthkur Posted June 16, 2009 Share Posted June 16, 2009 4,590 I really like this game but with the controls available it's unplayable. Link to comment Share on other sites More sharing options...
aftermac Posted June 17, 2009 Share Posted June 17, 2009 19,630 Works for me. I just need to use a better controller than my trackpad. Hit TAB and try adjusting "Dial Sensitivity" under "Analog Controls". Mine used to be 25%, it's now at 15% and I can steer better with my trackball. I tried the same with a PS2 controller's analog stick and that didn't help at all. I got the game to work reasonably well with the d-pad on my controller. By default the The pedal is set to joy1 x-axis, which is also joy 1 left and right and by default used on the dial controls. By setting this to something else... like Mouse Y-Axis, and having Dial Analog set to only Mouse X-Axis this allow the Dial Inc and Dial Dec to work properly. Link to comment Share on other sites More sharing options...
aftermac Posted June 17, 2009 Share Posted June 17, 2009 33,540 Link to comment Share on other sites More sharing options...
aftermac Posted June 18, 2009 Share Posted June 18, 2009 49,030 Link to comment Share on other sites More sharing options...
darthkur Posted June 18, 2009 Share Posted June 18, 2009 19,630 Works for me. I just need to use a better controller than my trackpad. Hit TAB and try adjusting "Dial Sensitivity" under "Analog Controls". Mine used to be 25%, it's now at 15% and I can steer better with my trackball. I tried the same with a PS2 controller's analog stick and that didn't help at all. I got the game to work reasonably well with the d-pad on my controller. By default the The pedal is set to joy1 x-axis, which is also joy 1 left and right and by default used on the dial controls. By setting this to something else... like Mouse Y-Axis, and having Dial Analog set to only Mouse X-Axis this allow the Dial Inc and Dial Dec to work properly. Thank you for the info. That helped a lot. 10,230 Link to comment Share on other sites More sharing options...
Mister VCS Posted June 18, 2009 Share Posted June 18, 2009 (edited) 5,920 7,760 final score: 9,770 (rookie-level) Edited June 20, 2009 by Mister VCS Link to comment Share on other sites More sharing options...
Lauren Tyler Posted June 21, 2009 Share Posted June 21, 2009 I couldn't get Roadblasters to play on MAME, so consider this my 'time off' week. Link to comment Share on other sites More sharing options...
aftermac Posted June 21, 2009 Share Posted June 21, 2009 Thank you for the info. That helped a lot. No problem! I couldn't get Roadblasters to play on MAME, so consider this my 'time off' week. Depending on the version on MAME you have it requires you to download the "atarisy1" (Atari System 1 BIOS) file and put it in your ROMs folder. I had to do this to get it to run on my MAME cabinet. However, it ran fine on my iBook without the files. In the future, you run MAME from the command line it will tell you what files you are missing then you can Google and find out what you need. Link to comment Share on other sites More sharing options...
darthkur Posted June 22, 2009 Share Posted June 22, 2009 Deteacher , are you alright or did you get abducted by aliens or something? Link to comment Share on other sites More sharing options...
Deteacher Posted June 22, 2009 Author Share Posted June 22, 2009 Hi all, I'm still alive, but I got some things going on right now and I haven't been able to do my duties as HSC Moderator. Read the new thread in a few minutes. Feel free to discuss there. Link to comment Share on other sites More sharing options...
