SeaGtGruff Posted August 12, 2009 Share Posted August 12, 2009 I've written a "bitmap kernel" for batari Basic, which displays a 2-color "hi-res" 96x192 bitmap using flicker blinds. Trouble is, it's a real pain in the ass to pull up a bitmap in Paint (or other graphics program) and manually type out all the bytes for it. I've never done any programming to open and read a bitmap file-- although I've printed out a tutorial about it from two old Dr. Dobbs issues that I found online. I'm hoping that somebody here might be able to bang out a utility program a lot quicker than I could (and would be nice enough to do so ). What I'm looking for is a routine that would take a 2-color bitmap and convert it to a text file with 8-bit binary values, like the following: column_0 byte %00000000 byte %00000000 byte %00110000 byte %00001110 byte %01000000 byte %00111000 byte %00000000 byte %00000000 etc. column_1 byte %00000000 byte %00000000 byte %00110000 byte %00001110 byte %01000000 byte %00111000 byte %00000000 byte %00000000 etc. column_2 byte %00000000 byte %00000000 byte %00110000 byte %00001110 byte %01000000 byte %00111000 byte %00000000 byte %00000000 etc. Ideally, the bitmap would be 96x192, although the utility could work with any size bitmap-- the only real restriction being that the bitmap should be a 2-color bitmap, so that each pixel is either on or off. The bytes will be used for 2600 player data, so the first 8 columns of pixels would be written out as one column of 8-bit values, then the next 8 columns of pixels would be another column, etc., as shown in the example above. So for a 96x192 bitmap, there would be 192 values for the first column, 192 values for the next column, and so on, with 12 columns in all. I can take a two-color picture and resize it to 96x192, so that's not a problem. And I can reformat the text output to suit my needs, so the output format of the utility could be different than I've described. For example, even converting a two-color bitmap to a text file with 0s and 1s would be okay-- one line of text for each row of pixels, without putting them as byte values: 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000001000000000000000000000000000000000000000 000000000000000000010100000000000000000000000000000000000000 000000000000000000100010000000000000000000000000000000000000 000000000000000001000001000000011111111111000000000000000000 000000000000000011111111100000010000000001000000000000000000 000000000000000000000000000000010000000001000000000000000000 000000000000000000000000000000010000000001000000000000000000 000000000000000000000000000000010000000001000000000000000000 000000000000000000000000000000011111111111000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 I'll probably write my own utility regardless, just so I learn how to do it, but it would be cool if someone could bang something out quickly, or if somebody knows of an existing utility that already does something like this. Michael Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted August 12, 2009 Author Share Posted August 12, 2009 Nevermind, I found a utility that converts a bitmap to ASCII art, and I can make it do what I need. But I'll still probably (eventually) write a utility of my own to generate output in the exact format I'm looking for-- not just for me, but for other people who want to use my bB "bitmap kernel." Michael Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted August 12, 2009 Share Posted August 12, 2009 I have a few converters on my website, on my Atari page, listed below SpiceWare Utility. One of them is a 48 pixel converter, which I could clone off and turn into a 96 pixel converter. Only limitation is your image must be accessable via URL (I had problems trying to make upload work). Other thing is it outputs the images using my "graphics.h" file, instead of this: .byte %00000000 ; 0 .byte %00000000 ; 1 .byte %00001100 ; 2 .byte %00001100 ; 3 .byte %00011100 ; 4 .byte %00011000 ; 5 .byte %00111100 ; 6 .byte %00111100 ; 7 .byte %01101000 ; 8 .byte %01110110 ; 9 .byte %01111110 ; 10 .byte %01000110 ; 11 .byte %00111100 ; 12 .byte %00111100 ; 13 .byte %00111100 ; 14 .byte %01110110 ; 15 .byte %11111111 ; 16 .byte %11111111 ; 17 .byte %11111011 ; 18 .byte %11111111 ; 19 .byte %11111111 ; 20 .byte %11111011 ; 21 .byte %11111111 ; 22 .byte %01111110 ; 23 .byte %00111100 ; 24 it outputs this, which I find much easier to read: .byte zz________ ; 0 .byte zz________ ; 1 .byte zz____XX__ ; 2 .byte zz____XX__ ; 3 .byte zz___XXX__ ; 4 .byte zz___XX___ ; 5 .byte zz__XXXX__ ; 6 .byte zz__XXXX__ ; 7 .byte zz_XX_X___ ; 8 .byte zz_XXX_XX_ ; 9 .byte zz_XXXXXX_ ; 10 .byte zz_X___XX_ ; 11 .byte zz__XXXX__ ; 12 .byte zz__XXXX__ ; 13 .byte zz__XXXX__ ; 14 .byte zz_XXX_XX_ ; 15 .byte zzXXXXXXXX ; 16 .byte zzXXXXXXXX ; 17 .byte zzXXXXX_XX ; 18 .byte zzXXXXXXXX ; 19 .byte zzXXXXXXXX ; 20 .byte zzXXXXX_XX ; 21 .byte zzXXXXXXXX ; 22 .byte zz_XXXXXX_ ; 23 .byte zz__XXXX__ ; 24 graphics.h.zip Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted August 12, 2009 Share Posted August 12, 2009 (edited) Here's the Sprite Converter in action: Screen 1 - select the image Screen 2 - select the sprite's background color (optionally add/remove extra rows[use negative values to remove]). If the color numbers are hard to see you can hit Change Colors to select from different background colors(each click will advance to the new color).WARNING - the field values might change when using Change Colors - notice that Background Color reverted to 1 Screen 3 - copy your results and paste into your code. Hit Next Sprite if you have more to convert. Edited August 12, 2009 by SpiceWare Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted August 12, 2009 Share Posted August 12, 2009 test Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted August 12, 2009 Share Posted August 12, 2009 You can post an image on AtariAge and my site can access it (I suspect you need to be logged onto AtariAge for it to work) Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted August 12, 2009 Author Share Posted August 12, 2009 Cool beans! Thanks, I'll try it out! Michael Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted August 13, 2009 Author Share Posted August 13, 2009 (edited) Evil Spock 96x192 bitmap Evil_Spock_bw.bmp Michael Edited August 13, 2009 by SeaGtGruff Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted August 13, 2009 Author Share Posted August 13, 2009 Faye Dunaway Faye_Dunaway_bw.bmp Michael Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted August 13, 2009 Share Posted August 13, 2009 (edited) Give her a whirl! The image needs to be gif, not bmp. I put a gif version on my site, it's the example URL. http://spiceware.org/atari/convert96.php Edit: it's now accessible from my Atari Page Edited August 13, 2009 by SpiceWare Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted August 13, 2009 Author Share Posted August 13, 2009 Legalize Shemp Legalize_Shemp_bw.bmp Michael Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted August 13, 2009 Author Share Posted August 13, 2009 Give her a whirl! The image needs to be gif, not bmp. I put a gif version on my site, it's the example URL. http://spiceware.org/atari/convert96.php Edit: it's now accessible from my Atari Page Okay, thank you so much!!! Michael Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted August 13, 2009 Share Posted August 13, 2009 No problem, it took less than 10 minutes. The hard work was done when I wrote Medieval Mayhem(figured out how to have PHP convert a gif to data for the dragon) and Stay Frosty(added the 1 sprite converter and 48 pixel converter). To make this I just copied the four convert-48 php files, did a mass change from 48 to 96, and finally tweaked the output routine to do 12 sprites of data instead of 6. Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted August 13, 2009 Share Posted August 13, 2009 Note that the output is generated twice, right-side-up followed by upside-down (though the 2-sprite convert only outputs right-side-up as that's what MM needed) Also if you have trouble getting bB to work with the graphic.h file, a few find/replace-all will convert the format: from zz to % from _ to 0 from X to 1 from .byte to byte (based on your example, I'm assuming that bB uses byte instead of DASM's .byte) Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted August 13, 2009 Author Share Posted August 13, 2009 I'm assuming that bB uses byte instead of DASM's .byte) Actually, bB doesn't have a byte command-- I used inline assembly, so it's DASM's byte command. From what I've read in the DASM user's manual, byte, BYTE, .byte, and .BYTE are all the same. I just prefer to leave off the period, and to put it in uppercase: BYTE HEX WORD etc. But I change my mind every so often about things like that-- one year I'm using ORG $F000, the next year I'm using ORG $1000, etc.-- so maybe someday I'll suddenly decide that I like .byte better! Michael Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted August 13, 2009 Share Posted August 13, 2009 (edited) Wasn't aware that DASM support variations on byte - I suspect the initial DASM code I saw used .byte and I didn't pursue it any further. Since you're inlining you shouldn't have any trouble getting graphic.h to work. Edited August 13, 2009 by SpiceWare Quote Link to comment Share on other sites More sharing options...
jwierer Posted August 13, 2009 Share Posted August 13, 2009 The output form BMP to Atari 2600 comes very close to what you want, but is limited to a width of 40 pixels which seems like a limitation that could easily be changed. The author didn't post source, but he could probably be reached to make the change. I just gave it a shot and this is the output PF0TitleLeft .byte #%11110000 .byte #%11110000 .byte #%11110000 .byte #%11110000 .byte #%11110000 .byte #%11110000 .byte #%11110000 .byte #%11110000 .byte #%11110000 .byte #%11110000 .byte #%11110000 .byte #%11110000 .byte #%11110000 .byte #%11110000 .byte #%11110000 .byte #%11110000 .byte #%11110000 PF0TitleRight .byte #%11000000 .byte #%11110000 .byte #%11110000 .byte #%11110000 .byte #%11110000 .byte #%11110000 .byte #%11110000 .byte #%01110000 .byte #%01110000 .byte #%10010000 .byte #%11110000 .byte #%11110000 .byte #%11110000 .byte #%11110000 .byte #%11110000 .byte #%11110000 .byte #%11110000 PF1TitleLeft .byte #%11111111 .byte #%11111110 .byte #%11100000 .byte #%11111110 .byte #%11111111 .byte #%11111111 .byte #%11111111 .byte #%11111111 .byte #%11111111 .byte #%11111111 .byte #%11111111 .byte #%11111111 .byte #%11111111 .byte #%11111111 .byte #%11111111 .byte #%11111111 .byte #%11111111 PF1TitleRight .byte #%11111111 .byte #%11010111 .byte #%11000000 .byte #%11111111 .byte #%11111111 .byte #%11111111 .byte #%11111111 .byte #%01111111 .byte #%01111111 .byte #%11110111 .byte #%11111111 .byte #%11111111 .byte #%11111111 .byte #%11111111 .byte #%11111111 .byte #%11111111 .byte #%11111111 PF2TitleLeft .byte #%00000111 .byte #%00000000 .byte #%11110000 .byte #%11111110 .byte #%11111111 .byte #%11111111 .byte #%11111111 .byte #%11111111 .byte #%11111111 .byte #%01111111 .byte #%11111111 .byte #%11111111 .byte #%11111111 .byte #%11111111 .byte #%11111111 .byte #%11111111 .byte #%11111111 PF2TitleRight .byte #%11111111 .byte #%11111111 .byte #%11111111 .byte #%11111111 .byte #%01111111 .byte #%11111111 .byte #%11111111 .byte #%11111111 .byte #%11111111 .byte #%11111111 .byte #%11111111 .byte #%11111111 .byte #%11111111 .byte #%11111111 .byte #%11111111 .byte #%11111111 .byte #%11111111 -Jeff Quote Link to comment Share on other sites More sharing options...
