Cybergoth Posted August 28, 2009 Share Posted August 28, 2009 More to the point - you're stripping out entire sections of your blog because they can't get their crap together, and come up with a way to properly migrate the older entries over. It ain't brain-surgery. It's data. If a web browser can still parse it, they should be able to cobble together a script that can properly transfer it over to the new software. I spaced on this earlier, I didn't realize Manuel was removing so many entries. Manuel, why are you doing this? It's more or less just an overhaul of the content I present there, focusing it on the more valuable information. Part of my blogging process is try & error and every once in a while I remove the error. The update has kinda given me the chance for an overdue spring-cleaning Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted August 28, 2009 Share Posted August 28, 2009 I just installed Opera and I'm using it now. For one thing, the blue color differences you pointed out before are considerably more pronounced in Opera than they are in Firefox, Safari and IE7. Opera 9.64: 1. 0/102/153 (mostly), 2. 0/120/168 (for the tabs e.g. Forums and the Pac-Man icon), 3. 20/102/153 (for the upper ~40% of the top bar (Have You Played Atari Today?) 4. 13/109/158 (for the upper half of the bottom bar) Firefox 3.52: - 0/102/153 (identical with Opera) - 0/122/170 (0/+2/+2) - 20/103/152 (0/+1/-1) - 13/110/158 (0/+1/0) Safari 4.03: - 0/102/153 (identical with Opera) - 0/122/170 (0/+2/+2) - 20/103/152 (0/+1/-1) - 13/109/158 (identical with Opera) So the values are quite identical. Actually Firefox and Safari are even slightly more off the major dark blue than Opera. Maybe your colors come out diffently, which could be due to your OS or the color profile of your graphics cart/monitor? Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted August 28, 2009 Share Posted August 28, 2009 (edited) This (screenshot from FF) doesn't look very good too. In Opera we have the same problem, execpt that the rounded borders are missing and the "jump to" and "next page" arrows aren't taller than the other buttons. Edited August 28, 2009 by Thomas Jentzsch Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted August 28, 2009 Share Posted August 28, 2009 Is it possible to change the color of the borders around the screenshots from blue to grey (original IP.Board version) -or remove them? Agreed. They should become less sticking out. Either by changing the color or by making them thinner. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted August 28, 2009 Share Posted August 28, 2009 16 user(s) active in the Blogs 14 Guests, 1 Anonymous Users MSN/Bing, Cybergoth Quote Link to comment Share on other sites More sharing options...
Cybergoth Posted August 28, 2009 Share Posted August 28, 2009 Bing is probably considered a guest Quote Link to comment Share on other sites More sharing options...
Albert Posted August 28, 2009 Author Share Posted August 28, 2009 So the values are quite identical. Actually Firefox and Safari are even slightly more off the major dark blue than Opera. Maybe your colors come out diffently, which could be due to your OS or the color profile of your graphics cart/monitor? Could be one or both. At any rate, I will adjust these soon enough. ..Al Quote Link to comment Share on other sites More sharing options...
Albert Posted August 28, 2009 Author Share Posted August 28, 2009 Is it possible to change the color of the borders around the screenshots from blue to grey (original IP.Board version) -or remove them? Yes, I'm going to change that border soon. From the names I guess those are propietary. Not a very good idea to use propietary stuff, IMO. This is intentional, Invision knows that the rounded corners will not render properly in all browsers, but it degrades gracefully. If you're using a good browser (Firefox, Safari, Chrome), you get the rounded corners. If you're using a bad browser (IE, Opera, etc.) you don't get all the bling. EDIT: Found those properties are called experimental.Maybe that helps for Opera: http://home.e-tjenesten.org/~ato/2009/08/border-radius-opera Holy cow I am so not doing that. The rounded tab at the top of the page is actually comprised of two images, which is why you can see those rounded corners in Opera. Yes, except for the "New Content" page. You mean the tabs that are shown for all the various search results pages (including "View New Content")? Yeah, those are drawn using the CSS styles and not with images. I think they used images for the tabs at the top as they are a bit "fancier" in the default skin (two tones). Since the skin here is only using a single color for the tabs, I could change the tab at the top to use the radius CSS styles, but I'll probably keep it as is. ..Al Quote Link to comment Share on other sites More sharing options...
Albert Posted August 28, 2009 Author Share Posted August 28, 2009 Bing is probably considered a guest Yes, the various search engine agents do not log into the forum. ..Al Quote Link to comment Share on other sites More sharing options...
Albert Posted August 28, 2009 Author Share Posted August 28, 2009 It doesn't seem to matter what I'm searching for. I put a search into the box, it gives me the results. I click on a post and try to return to the search within a few seconds and it gives me a Webpage Has Expired message nearly every time. Invision has fixed this problem for the next release of the software (which I hope is coming within the week). ..Al Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted August 28, 2009 Share Posted August 28, 2009 If you're using a bad browser (IE, Opera, etc.) you don't get all the bling. How do you unregister from AA? :x Quote Link to comment Share on other sites More sharing options...
Albert Posted August 28, 2009 Author Share Posted August 28, 2009 After replacing all with [media] tags in my blog I just discovered that all tags are also broken, none of the links in my playdex works: http://www.atariage.com/forums/blog/54/entry-6284-playdex-2-3/ Anyone know how to fix these? Invision gave me updated code for the BBcode tag, so this is now fixed. ..Al Quote Link to comment Share on other sites More sharing options...
Albert Posted August 28, 2009 Author Share Posted August 28, 2009 When/How are the tag clouds updated by the way? I removed all Ghosts'n'Goblins entries from the blog, but the tag is still in the cloud. Also it assumes two pages worth of G'n'G entries, while stating at the same time that there are none: http://www.atariage.com/forums/blog/54-planet-bob/page__tag__Ghosts'n'Goblins The error that the above link returns has been fixed by Invision for the next version of the software. Looks like I will need to file a separate bug regarding the tags not getting removed (doing that now). ..Al Quote Link to comment Share on other sites More sharing options...
Albert Posted August 28, 2009 Author Share Posted August 28, 2009 Yeah... you don't want to do that. Especially since if you edit anything posted earlier than 2006, the new software will screw up your blog. It doesn't recognize 2005 (or earlier) as a valid date, so it takes it upon itself to change it to 2006 - [ The year field has been fixed, it now starts at 2004. ..Al Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted August 28, 2009 Share Posted August 28, 2009 Has anyone mentioned this yet? When I go to a blog entry and edit it, when I'm done, it doesn't go back to the blog entry, it goes back to the top of my blog that shows multiple entries. Not fun when I might need to add more items to the blog entry I was working on. Quote Link to comment Share on other sites More sharing options...
Albert Posted August 28, 2009 Author Share Posted August 28, 2009 Has anyone mentioned this yet? When I go to a blog entry and edit it, when I'm done, it doesn't go back to the blog entry, it goes back to the top of my blog that shows multiple entries. Not fun when I might need to add more items to the blog entry I was working on. I noticed this yesterday and will file a bug against it now. Invision's going to love me, I've filed tons of bugs in the last two days. They have been good about fixing them so far. ..Al Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted August 28, 2009 Share Posted August 28, 2009 I noticed this yesterday and will file a bug against it now. Invision's going to love me, I've filed tons of bugs in the last two days. They have been good about fixing them so far. That's good. It's nice that they aren't acting like you're bothering them. Quote Link to comment Share on other sites More sharing options...
Albert Posted August 28, 2009 Author Share Posted August 28, 2009 That's good. It's nice that they aren't acting like you're bothering them. Well, that's what they are getting paid to do. I am paying for this software (and a significant amount ever year), so this is really part of the normal support. And fixing problems improves their software. As long as you are entering legitimate issues, describe them clearly, and Invision can reproduce them, they will generally fix them. More complex issues (the blog is full of them) may be put off if the fix is not relatively easy. I have a feeling the blog is going to see some significant changes for the next version. ..Al Quote Link to comment Share on other sites More sharing options...
Cybergoth Posted August 28, 2009 Share Posted August 28, 2009 Invision gave me updated code for the BBcode tag, so this is now fixed. Yay! Things are going forward again! Any news on my dotted "Playing..." category tag? And on the tag paging? (Here's an example: http://www.atariage.com/forums/blog/54-planet-bob/page__tag__Colony%207 => It's impossible to access the second page of this tag) Besides the missing "latest comment" info, these two seem to be the biggest issues remaining right now. Quote Link to comment Share on other sites More sharing options...
Albert Posted August 28, 2009 Author Share Posted August 28, 2009 Any news on my dotted "Playing..." category tag? I just posted a bug about this. I was able to reproduce it by using two or more consecutive periods. And on the tag paging? (Here's an example: http://www.atariage.com/forums/blog/54-planet-bob/page__tag__Colony%207 => It's impossible to access the second page of this tag) This has been fixed for the next version: http://forums.invisionpower.com/tracker/issue-18181-tags-pagination-does-not-work/ ..Al Quote Link to comment Share on other sites More sharing options...
+Nathan Strum Posted August 28, 2009 Share Posted August 28, 2009 It's more or less just an overhaul of the content I present there, focusing it on the more valuable information. Part of my blogging process is try & error and every once in a while I remove the error. The update has kinda given me the chance for an overdue spring-cleaning If I did that to my blog, I wouldn't have anything left! The year field has been fixed, it now starts at 2004. Sweet! Now I can go back in and fix the rest of my blog. Thanks! Has anyone mentioned this yet? When I go to a blog entry and edit it, when I'm done, it doesn't go back to the blog entry, it goes back to the top of my blog that shows multiple entries. Not fun when I might need to add more items to the blog entry I was working on. I noticed this yesterday and will file a bug against it now. Invision's going to love me, I've filed tons of bugs in the last two days. They have been good about fixing them so far. The previous blog software did this as well. After an edit, it always jumped you back to the "home" page of your blog. It would be much better to have it dump you off at the same place you were working. Quote Link to comment Share on other sites More sharing options...
Cybergoth Posted August 28, 2009 Share Posted August 28, 2009 It's more or less just an overhaul of the content I present there, focusing it on the more valuable information. Part of my blogging process is try & error and every once in a while I remove the error. The update has kinda given me the chance for an overdue spring-cleaning If I did that to my blog, I wouldn't have anything left! I'm not that strict, I usually leave the entries that have gathered a couple of comments (other than my own ), since I don't want to lose all the the valuable feedback Quote Link to comment Share on other sites More sharing options...
Albert Posted August 28, 2009 Author Share Posted August 28, 2009 The bug regarding tags not getting deleted when you remove the last blog entry referencing a tag has been fixed: http://forums.invisionpower.com/tracker/issue-18202-tag-removal-when-deleting-blog-entries/ ..Al Quote Link to comment Share on other sites More sharing options...
Albert Posted August 28, 2009 Author Share Posted August 28, 2009 The previous blog software did this as well. After an edit, it always jumped you back to the "home" page of your blog. It would be much better to have it dump you off at the same place you were working. This has now been fixed. http://forums.invisionpower.com/index.php?app=tracker&showissue=18203 ..Al Quote Link to comment Share on other sites More sharing options...
Albert Posted August 28, 2009 Author Share Posted August 28, 2009 Any news on my dotted "Playing..." category tag? Fixed: http://forums.invisionpower.com/index.php?app=tracker&showissue=18207 ..Al Quote Link to comment Share on other sites More sharing options...
