S1500 Posted October 6, 2009 Share Posted October 6, 2009 I can't find my power supply for my FB2, but one I found might be the one. However, I want to make absolutely sure as not to risk frying my FB2. So, anyone have a picture of the proper power supply? I've too many power supplies! Thankfully, I found a few power supplies that work great for USB hubs. Quote Link to comment Share on other sites More sharing options...
BigO Posted October 6, 2009 Share Posted October 6, 2009 (edited) I don't have a picture handy, but the FB2 power supplies I've seen have the Atari logo on them. From memory, they're fairly small: about 1.25" wide 1.25" deep and 2" high (viewed as plugged into a wall). Can get a pic later this afternoon if you still need it by then. Edited October 6, 2009 by BigO Quote Link to comment Share on other sites More sharing options...
BigO Posted October 6, 2009 Share Posted October 6, 2009 Crappy webcam pictures: Quote Link to comment Share on other sites More sharing options...
S1500 Posted October 6, 2009 Author Share Posted October 6, 2009 Thanks. Good thing I asked, since I was about to plug in the wrong one. Quote Link to comment Share on other sites More sharing options...
S1500 Posted November 25, 2009 Author Share Posted November 25, 2009 Managed to snag one at a thrift store. It's not an Atari one, but the specs match. Quote Link to comment Share on other sites More sharing options...
atwwong Posted November 26, 2009 Share Posted November 26, 2009 Hope it works fine! Quote Link to comment Share on other sites More sharing options...
nathanallan Posted November 26, 2009 Share Posted November 26, 2009 Thanks. Good thing I asked, since I was about to plug in the wrong one. How do you mean, the wrong one? To make sure, you need the correct fitting tip, 9vdc (and I think it can regulate it down from about 12vdc) and at least 200mA, tip POSITIVE. Was the one you were about to use tip negative? That would have messed things up, or going over 12vdc. Does it work? Quote Link to comment Share on other sites More sharing options...
S1500 Posted November 26, 2009 Author Share Posted November 26, 2009 Thanks. Good thing I asked, since I was about to plug in the wrong one. How do you mean, the wrong one? To make sure, you need the correct fitting tip, 9vdc (and I think it can regulate it down from about 12vdc) and at least 200mA, tip POSITIVE. Was the one you were about to use tip negative? That would have messed things up, or going over 12vdc. Does it work? I meant I had a power supply that looked quite a bit like the FB2 supply, but it wasn't. It had a different output voltage, etc. The power supply I bought from Unique Thrift was for some telephony device. It works perfectly with the Flashback 2. Quote Link to comment Share on other sites More sharing options...
tz101 Posted January 10, 2010 Share Posted January 10, 2010 I've too many power supplies! Here's what I have done with my power supplies since I collect about every console out there: I use a gold fine point paint marker to write which system(s) each power adapter goes to on each adapter (usually a side location due to labels and plugs). This way I don't end up making any costly mistakes. Some, like Jaguar and Genesis model 1 fit multiple systems, so I mark them accordingly. Quote Link to comment Share on other sites More sharing options...
boxpressed Posted May 26, 2012 Share Posted May 26, 2012 (edited) I need a PS for a FB 2 as well. Apologies for the dumb question, but how can you tell if a PS is tip positive or tip negative? UPDATE: Never mind. Just discovered that the icon on the lower right of the label of the image above shows tip positive. Edited May 26, 2012 by boxpressed Quote Link to comment Share on other sites More sharing options...
