Videogamecollector123 Posted October 21, 2009 Share Posted October 21, 2009 Hi, I'm about to build a Vectrex lightpen I'm in the process of procurring parts right now, however I'm kinda of confused on that part. I can't figure out if any of the parts I'm looking at are the right ones and I want to make sure I have the right ones so I only have to order once. I did however manage to find the phototransistor.http://www.newark.com/jsp/search/productdetail.jsp?SKU=84F234&CMP=AFC-GB100000001(was marked obsolete at mouser)So if anyone could help me with this, that would be great Quote Link to comment Share on other sites More sharing options...
Videogamecollector123 Posted October 22, 2009 Author Share Posted October 22, 2009 Hi, I'm about to build a Vectrex lightpen I'm in the process of procurring parts right now, however I'm kinda of confused on that part. I can't figure out if any of the parts I'm looking at are the right ones and I want to make sure I have the right ones so I only have to order once. I did however manage to find the phototransistor.http://www.newark.com/jsp/search/productdetail.jsp?SKU=84F234&CMP=AFC-GB100000001(was marked obsolete at mouser)So if anyone could help me with this, that would be great As I said above in the first post, I can't really tell which ones are the right ones, mainly the resistors and capacitors. I think this is it for the 10K the resistors http://www.newark.com/multicomp/mcf-0-25w-10k/carbon-film/dp/38K0328 but I can't figure out the capactiors and 2.2k resistor still. Also the 2N3904 transistor. I think I found the semiconductor but I'm not sure http://www.newark.com/nte-electronics/nte74ls132/logic-ic/dp/31C5638 Quote Link to comment Share on other sites More sharing options...
Spazmonkey Posted October 22, 2009 Share Posted October 22, 2009 Could you link to a parts list so we know what your even looking for? Quote Link to comment Share on other sites More sharing options...
Videogamecollector123 Posted October 22, 2009 Author Share Posted October 22, 2009 oh, sorry I for some reason assummed anyone who could help me would know of the circuit, my mistake here it is http://www.playvectrex.com/vectech/mvlp/mvlp_f.htm Quote Link to comment Share on other sites More sharing options...
Spazmonkey Posted October 22, 2009 Share Posted October 22, 2009 http://mouser.com/ProductDetail/KOA-Speer/MF1-4LCT52R222J/?qs=sGAEpiMZZMtMTfExsNintYUauQExemKKnFnJ0m%2fAuz0%3d 2.2k http://mouser.com/ProductDetail/KOA-Speer/MF1-4LCT52R103J/?qs=sGAEpiMZZMtMTfExsNintZ6E7%252beOea5beqkIZko6mAg%3d 10k http://mouser.com/ProductDetail/Fairchild-Semiconductor/2N3904TF/?qs=sGAEpiMZZMuDHCWHhuFg%252baPN204G4fBceHZeJOgYNHY%3d 2n3904 http://mouser.com/ProductDetail/Vishay-BC-Components/K103M15X7RF53H5/?qs=sGAEpiMZZMuAYrNc52CMZOqBXleu%252bdrV5Ll8noE4DtE%3d ceramic caps http://mouser.com/ProductDetail/Nichicon/UVZ1C470MDD1TD/?qs=sGAEpiMZZMsCnlYck6hSqAgLGvHuIMneuCOllWkIgdk%3d electrolytic caps I need to go, I will find the rest for you later..... Quote Link to comment Share on other sites More sharing options...
Videogamecollector123 Posted October 22, 2009 Author Share Posted October 22, 2009 http://mouser.com/ProductDetail/KOA-Speer/MF1-4LCT52R222J/?qs=sGAEpiMZZMtMTfExsNintYUauQExemKKnFnJ0m%2fAuz0%3d 2.2k http://mouser.com/ProductDetail/KOA-Speer/MF1-4LCT52R103J/?qs=sGAEpiMZZMtMTfExsNintZ6E7%252beOea5beqkIZko6mAg%3d 10k http://mouser.com/ProductDetail/Fairchild-Semiconductor/2N3904TF/?qs=sGAEpiMZZMuDHCWHhuFg%252baPN204G4fBceHZeJOgYNHY%3d 2n3904 http://mouser.com/ProductDetail/Vishay-BC-Components/K103M15X7RF53H5/?qs=sGAEpiMZZMuAYrNc52CMZOqBXleu%252bdrV5Ll8noE4DtE%3d ceramic caps http://mouser.com/ProductDetail/Nichicon/UVZ1C470MDD1TD/?qs=sGAEpiMZZMsCnlYck6hSqAgLGvHuIMneuCOllWkIgdk%3d electrolytic caps I need to go, I will find the rest for you later..... Thanks, just take your time finding the rest of the parts, your help is greatly appreciated Quote Link to comment Share on other sites More sharing options...
Spazmonkey Posted October 22, 2009 Share Posted October 22, 2009 Here's your last part, http://mouser.com/ProductDetail/Texas-Instruments/SN74LS132N/?qs=sGAEpiMZZMutXGli8Ay4kP28D9wZ8SQIl0%2fVrowVA5w%3d Good luck, it looks like you may be new to do it yourself projects, so I would like to say take everything very very slowly. If your in no rush to finish, you will have a much nicer end project, and less headaches. Quote Link to comment Share on other sites More sharing options...
Videogamecollector123 Posted October 22, 2009 Author Share Posted October 22, 2009 Here's your last part, http://mouser.com/ProductDetail/Texas-Instruments/SN74LS132N/?qs=sGAEpiMZZMutXGli8Ay4kP28D9wZ8SQIl0%2fVrowVA5w%3d Good luck, it looks like you may be new to do it yourself projects, so I would like to say take everything very very slowly. If your in no rush to finish, you will have a much nicer end project, and less headaches. Yes I am new to this, but this is a good starting point as it's a simple cicuit. One last thing is, do you know if the phototransistor is on mouser? when I looked it said obsolete but then again I can't find anything. I think I'm just going to order double of all the parts just in case of a screwup I can get back on track. Quote Link to comment Share on other sites More sharing options...
Spazmonkey Posted October 22, 2009 Share Posted October 22, 2009 Here's your last part, http://mouser.com/ProductDetail/Texas-Instruments/SN74LS132N/?qs=sGAEpiMZZMutXGli8Ay4kP28D9wZ8SQIl0%2fVrowVA5w%3d Good luck, it looks like you may be new to do it yourself projects, so I would like to say take everything very very slowly. If your in no rush to finish, you will have a much nicer end project, and less headaches. Yes I am new to this, but this is a good starting point as it's a simple cicuit. One last thing is, do you know if the phototransistor is on mouser? when I looked it said obsolete but then again I can't find anything. I think I'm just going to order double of all the parts just in case of a screwup I can get back on track. I couldn't find that particular one, but if you can find all of the specs of it, I'm sure there is something that is very very similar on mouser. Quote Link to comment Share on other sites More sharing options...
Videogamecollector123 Posted October 22, 2009 Author Share Posted October 22, 2009 Here's your last part, http://mouser.com/ProductDetail/Texas-Instruments/SN74LS132N/?qs=sGAEpiMZZMutXGli8Ay4kP28D9wZ8SQIl0%2fVrowVA5w%3d Good luck, it looks like you may be new to do it yourself projects, so I would like to say take everything very very slowly. If your in no rush to finish, you will have a much nicer end project, and less headaches. Yes I am new to this, but this is a good starting point as it's a simple cicuit. One last thing is, do you know if the phototransistor is on mouser? when I looked it said obsolete but then again I can't find anything. I think I'm just going to order double of all the parts just in case of a screwup I can get back on track. I couldn't find that particular one, but if you can find all of the specs of it, I'm sure there is something that is very very similar on mouser. Well all the specs are here, http://www.newark.com/jsp/search/productdetail.jsp?SKU=84F234&CMP=AFC-GB100000001, if you could help me find a similar part that would be great, this is something I really want to do Quote Link to comment Share on other sites More sharing options...
lgallair Posted October 23, 2009 Share Posted October 23, 2009 (edited) If this helps, here's the list of part #'s I used when I built mine. I realize the photo transistor on Mouser is obsolete but they do have a "show similar" link at the bottom of the page. If you want, I have an extra L14G3 from Mouser that I no longer require. QTY DESCRIPTION DIGI-KEY # MOUSER # 2 10k ohm resistor (¼) 10KQBK-ND 1 2.2k ohm resistor (¼) 2.2KQBK-ND 1 0.01µF @ 100V capacitor P4904-ND 1 47uf @ 10V capacitor 493-1020-ND 140-XRL16V47-RC 1 L14G3 photo Transistor L14G3-ND 512-L14G3 1 2N3904 transistor 2N3904FS-ND 512-2N3904BU 1 74LS132 chip MM74HC132N-ND 595-SN74LS132N Edited October 23, 2009 by lgallair Quote Link to comment Share on other sites More sharing options...
Videogamecollector123 Posted October 23, 2009 Author Share Posted October 23, 2009 If this helps, here's the list of part #'s I used when I built mine. I realize the photo transistor on Mouser is obsolete but they do have a "show similar" link at the bottom of the page. If you want, I have an extra L14G3 from Mouser that I no longer require. VECTREX LIGHTPEN QTY DESCRIPTION DIGI-KEY # MOUSER # --- ---------------------------------- -------------------- ------------------- 2 10k ohm resistor (¼) 10KQBK-ND 1 2.2k ohm resistor (¼) 2.2KQBK-ND 1 0.01µF @ 100V capacitor P4904-ND 1 47uf @ 10V capacitor 493-1020-ND 140-XRL16V47-RC 1 L14G3 photo Transistor L14G3-ND 512-L14G3 1 2N3904 transistor 2N3904FS-ND 512-2N3904BU 1 74LS132 chip MM74HC132N-ND 595-SN74LS132N I have the rest of those parts, I would take that phototransistor that would be great. do you want anything for it? Quote Link to comment Share on other sites More sharing options...
Videogamecollector123 Posted October 24, 2009 Author Share Posted October 24, 2009 Hey, I have one last question. I'm using the cable from a Slik Stick and need to make sure the three wires I need to use are the Yellow, Black, and Green. Quote Link to comment Share on other sites More sharing options...
