Irgendwer Posted April 12, 2015 Share Posted April 12, 2015 I discarded using chars at the moment. Take in account that each level has more than 128 graphics, and many of them are larger than 4x8 pixels. They are mixed in several ways. I can tell you because I had to make several little adjustments to get the rendering right, including shifting and masking. You may like to read also this (sometimes derailed but still intresting) thread: http://atariage.com/forums/topic/188835-wich-one-of-these-two-prince-of-persia-you-prefer/ Regarding char mode, I provided an example there: http://atariage.com/forums/topic/188835-wich-one-of-these-two-prince-of-persia-you-prefer/page-23?do=findComment&comment=2395627 Let me know if you need support in the graphics department. Quote Link to comment https://forums.atariage.com/topic/152500-prince-of-persia/page/22/#findComment-3217063 Share on other sites More sharing options...
Franco Catrin Posted April 12, 2015 Share Posted April 12, 2015 I see two risks going the CharSet route 1) There is no way to make sure that all combination of screens and background animations + sprites will fit in 256 chars, until you get the code running. If you need just 1 additional char, you have to get rid of the code and start again. 2) The drawing complexity increases a lot. And once the code is complete, it may be useless according to the first risk. Sure that you can take one screen and make an estimate, but other screens that may look similar, can be completely different. Just look my slideshow of level 1 and see all the holes and missing graphics, those are the graphics not present in the first screens. And that doesn't include the animations. For me (as a coder), taking the CharSet route is just premature optimization, and we can get stuck there for a long time without any advancement. If you are worried for perfomance, I must remember that the sprite animation is just 15fps for memory reasons, the game just can't go further than that. Anyway, I plan to make the source public, so my first priority is to have the game running. Prince of Persia for Atari 8 bit... just think of how cool will be that. Then if somebody want to try the CharSet way (the remake of the port), it will be easier to test and finish, and the "worst" possible result is that we would have just one PoP. On the graphics side, yes I will need help. At this stage I prefer to do the graphics myself based in the ones I've taken for my tests. This is because the graphics are been fixed/modified to fit the original PoP rendering method (masking, shifting, and so on). Once complete, you can take them as reference to make an improved version. By the way, this is what MrSid wrote about the graphics. And he went all through it: Imagine you're working on the game, and suddenly you find out that the game has falling floors, which don't fit into your graphics mode plans. So you have to throw everything away and start from scratch. Trust me, the various animated bits of the game are the hardest part. It's not just background and a few character sprites... 4 Quote Link to comment https://forums.atariage.com/topic/152500-prince-of-persia/page/22/#findComment-3217218 Share on other sites More sharing options...
Irgendwer Posted April 12, 2015 Share Posted April 12, 2015 1) There is no way to make sure that all combination of screens and background animations + sprites will fit in 256 chars, until you get the code running. If you need just 1 additional char, you have to get rid of the code and start again. Or join two similar char representations and free one. (BTW: Unfortunately we have only 128 chars per font, but otherwise you can also use more than one font for different horizontal sections, which could also form a solution for the problem above.) 2) The drawing complexity increases a lot. And once the code is complete, it may be useless according to the first risk. AFAIK, these are the tiles of the C64 version: http://atariage.com/forums/uploads/monthly_10_2011/post-6517-0-25517500-1318665683.png I do not see any increase of complexity when substituting those building blocks by others relying on chars... (and matching char alignment) For me (as a coder), taking the CharSet route is just premature optimization, and we can get stuck there for a long time without any advancement. I see the this mode mainly as an advantage to improve the look while offering a 5th colour - but I'm far from persuading you to go the char route. I would appreaciate any usable PoP on the A8 - independent from the kind of creation. On the graphics side, yes I will need help. At this stage I prefer to do the graphics myself based in the ones I've taken for my tests. This is because the graphics are been fixed/modified to fit the original PoP rendering method (masking, shifting, and so on). Once complete, you can take them as reference to make an improved version. OK. Thanks! Quote Link to comment https://forums.atariage.com/topic/152500-prince-of-persia/page/22/#findComment-3217240 Share on other sites More sharing options...
Franco Catrin Posted April 12, 2015 Share Posted April 12, 2015 AFAIK, these are the tiles of the C64 version: http://atariage.com/forums/uploads/monthly_10_2011/post-6517-0-25517500-1318665683.png I do not see any increase of complexity when substituting those building blocks by others relying on chars... (and matching char alignment) If you look at those graphics, you can't just put them together, you have to combine them. Because of the perspective, one block must be blended into the next. If you put them together as they are, you will end with black triangles everywhere. Quote Link to comment https://forums.atariage.com/topic/152500-prince-of-persia/page/22/#findComment-3217242 Share on other sites More sharing options...
tschak909 Posted April 12, 2015 Share Posted April 12, 2015 I am agreeing with Franco on this particular approach. The Apple II DHGR is _not_ a tile based mode, and PoP's code has been highly optimized to take advantage of that fact, notwithstanding its highly unusual non-linear, artifacted nature. You would be wasting CPU cycles translating everything into tiles, and you'd lose a great deal of granularity with all of the animation needed (moving floors, torches, spikes, etc.), as has been mentioned before, the Apple II has no sprites, and the game wasn't written to the constraints usually associated with Atari 8-bit, Commodore 64, or even TMS9918 based sprites.) (not to mention that PoP has lots of little graphic flourishes that can easily overwhelm an 8-bit character set!) so you would be gaining absolutely nothing in terms of performance, and very little memory efficiency. -Thom 2 Quote Link to comment https://forums.atariage.com/topic/152500-prince-of-persia/page/22/#findComment-3217252 Share on other sites More sharing options...
potatohead Posted April 12, 2015 Share Posted April 12, 2015 It is just HGR, but yes. The renderer takes full advantage of how the Apple works. One alternative, if a 5th color is worth it, would be to make a bitmap char mode. Stack them up and use DLI to set new charbase values so that the screen is all unique chars. This is as convoluted as the Apple is, but it would be 5 color and a renderer will be similar. 2 Quote Link to comment https://forums.atariage.com/topic/152500-prince-of-persia/page/22/#findComment-3217266 Share on other sites More sharing options...
Franco Catrin Posted April 13, 2015 Share Posted April 13, 2015 I've just published a new video showing the rendering engine. It includes an animation test (loose floors) 15 Quote Link to comment https://forums.atariage.com/topic/152500-prince-of-persia/page/22/#findComment-3217671 Share on other sites More sharing options...
Heaven/TQA Posted April 13, 2015 Share Posted April 13, 2015 cool. Quote Link to comment https://forums.atariage.com/topic/152500-prince-of-persia/page/22/#findComment-3217742 Share on other sites More sharing options...
+MrFish Posted April 13, 2015 Share Posted April 13, 2015 (edited) I've just published a new video showing the rendering engine. It includes an animation test (loose floors) BTW, the big and small stone designs can be varied a little so they don't look as much like repeated patterns -- since the graphic sections are made up of more than one stone (The shaded small stones were done with variations, for example). I just used a repeated pattern on the others in order to make throwing a design together quicker back when I did these. I can work something better up if I get a little time later today. Edited April 13, 2015 by MrFish Quote Link to comment https://forums.atariage.com/topic/152500-prince-of-persia/page/22/#findComment-3217890 Share on other sites More sharing options...
Franco Catrin Posted April 13, 2015 Share Posted April 13, 2015 That would be great. Thanks! Quote Link to comment https://forums.atariage.com/topic/152500-prince-of-persia/page/22/#findComment-3217959 Share on other sites More sharing options...
tschak909 Posted April 13, 2015 Share Posted April 13, 2015 What are you coding these rendering tests in? are they just rendering simulations approximating the graphics mode, at this point? -Thom Quote Link to comment https://forums.atariage.com/topic/152500-prince-of-persia/page/22/#findComment-3218007 Share on other sites More sharing options...
Franco Catrin Posted April 13, 2015 Share Posted April 13, 2015 They are rendering simulations limited by the ATARI restrictions. The code is in java but taking in account that it must be ported to the 6502. It's a fast way to understand and test the rendering as you can see. Quote Link to comment https://forums.atariage.com/topic/152500-prince-of-persia/page/22/#findComment-3218176 Share on other sites More sharing options...
kiwilove Posted April 13, 2015 Share Posted April 13, 2015 While I can greatly admire how Prince of Persia is/was a great game - but because this is now 2015 - I wonder if you will add to the game - making it into a plus or extended version? I'm not a fan of doing conversions - unless you also add something new to it - since this is now so many decades? later. Yes - do the straight conversion - as perfect as you want to - but consider also - an improved? version that'll add some new twists/etc to it - to take it beyond the original game. Harvey Quote Link to comment https://forums.atariage.com/topic/152500-prince-of-persia/page/22/#findComment-3218202 Share on other sites More sharing options...
Franco Catrin Posted April 13, 2015 Share Posted April 13, 2015 My plan is to make a "direct" conversion at this time. I will publish the code if somebody want to make it better. 9 Quote Link to comment https://forums.atariage.com/topic/152500-prince-of-persia/page/22/#findComment-3218218 Share on other sites More sharing options...
José Pereira Posted April 14, 2015 Author Share Posted April 14, 2015 MrFish I send a message to Franco and wanted to add you but it seems I can't... Is there any problem with me? Thanks. Quote Link to comment https://forums.atariage.com/topic/152500-prince-of-persia/page/22/#findComment-3218521 Share on other sites More sharing options...
+MrFish Posted April 14, 2015 Share Posted April 14, 2015 MrFish I send a message to Franco and wanted to add you but it seems I can't... Is there any problem with me? Thanks. Yeah Jose, I put your sig on "Hide" a while back and I must have accidentally included ignoring messages when I did that. Go ahead and try it now. Quote Link to comment https://forums.atariage.com/topic/152500-prince-of-persia/page/22/#findComment-3218535 Share on other sites More sharing options...
tschak909 Posted April 21, 2015 Share Posted April 21, 2015 Any status updates? -Thom Quote Link to comment https://forums.atariage.com/topic/152500-prince-of-persia/page/22/#findComment-3223179 Share on other sites More sharing options...
Franco Catrin Posted April 21, 2015 Share Posted April 21, 2015 We are "on it". We moved the development to a private conversation, drop me a line if you are interested. Several ideas for graphics (combinations of PM/PF) are on the table. On my side, the 6502 coding has begun. 4 Quote Link to comment https://forums.atariage.com/topic/152500-prince-of-persia/page/22/#findComment-3223187 Share on other sites More sharing options...
potatohead Posted April 21, 2015 Share Posted April 21, 2015 Cool beans. Bummer about it being private, but I totally get the hassle. Please consider keeping dev logs. Should be an interesting read after the fact. Heck, I will help to format and make avaliable when the time is right. 2 Quote Link to comment https://forums.atariage.com/topic/152500-prince-of-persia/page/22/#findComment-3223203 Share on other sites More sharing options...
potatohead Posted April 21, 2015 Share Posted April 21, 2015 ...not that you need it. Just saying I support the effort and am interested in the tale. 1 Quote Link to comment https://forums.atariage.com/topic/152500-prince-of-persia/page/22/#findComment-3223227 Share on other sites More sharing options...
Franco Catrin Posted April 21, 2015 Share Posted April 21, 2015 I didn't wanted to go private, but now that I see it, I think that was for good. And looking at this topic entirely, I see that things could get messy when too much people want to have a saying on everything but are not willing to help working on it. Of course I want a development log. I started working on this after reading MrSid dev log for the C64 version. Just loved it. For now, I'm taking screenshots and videos of the process. 5 Quote Link to comment https://forums.atariage.com/topic/152500-prince-of-persia/page/22/#findComment-3223238 Share on other sites More sharing options...
Franco Catrin Posted May 1, 2015 Share Posted May 1, 2015 A small step for the game, but a milestone for me... The current code running on the real hardware for the first time: 22 Quote Link to comment https://forums.atariage.com/topic/152500-prince-of-persia/page/22/#findComment-3229339 Share on other sites More sharing options...
Poison Posted May 1, 2015 Share Posted May 1, 2015 WOW!! Amazing! Quote Link to comment https://forums.atariage.com/topic/152500-prince-of-persia/page/22/#findComment-3229379 Share on other sites More sharing options...
potatohead Posted May 1, 2015 Share Posted May 1, 2015 Cool beans. Looking good. Quote Link to comment https://forums.atariage.com/topic/152500-prince-of-persia/page/22/#findComment-3229381 Share on other sites More sharing options...
mrsid Posted May 1, 2015 Share Posted May 1, 2015 I'd recommend not posting any more previews, it'll demotivate you. Keep moving forward... Quote Link to comment https://forums.atariage.com/topic/152500-prince-of-persia/page/22/#findComment-3229439 Share on other sites More sharing options...
