Wookie Posted November 3, 2009 Share Posted November 3, 2009 I've never used the Handy emulator before and I want to use it to test out some of my code. What is the status of Handy on Linux? I was greping the internet earlier and found an old SDL/Handy and the latest and greatest Handy seems to be Win32 only. Is there an active Handy on Linux project still around? --Wookie Quote Link to comment Share on other sites More sharing options...
busterm Posted November 4, 2009 Share Posted November 4, 2009 (edited) Handy hasnt been actively developed on by the original author in sometime. The good news is that it has been open sources and a number or people over time have ported it to a number of devices and updated the code a bit from looking at the source the last win32 update was 2 years ago. Its a really good emulator...well more blunt is as good as its going to get really. The only other lynx emulator i know of is Metalynx or something like that and it pretty much only ran a couple homebrews from what I remember. If your a linux user Zopher Domain has a ubuntu version from earlier this year available for download dated 5/18/2009 though I've not used any of the Linux versions. Just the win32 and old Beos builds. http://www.zophar.net/linux/lynx/handy-sdl.html Found some info on the build from Zophar's Domain here http://sdlemu.ngemu.com/ its the latest win32 source ported. The source is also available there as well Edited November 4, 2009 by busterm Quote Link to comment Share on other sites More sharing options...
Wookie Posted November 4, 2009 Author Share Posted November 4, 2009 thanks! Quote Link to comment Share on other sites More sharing options...
+karri Posted November 4, 2009 Share Posted November 4, 2009 thanks! mednafen is in the main repositories and it is based on Handy code -- Karri Quote Link to comment Share on other sites More sharing options...
Wookie Posted November 4, 2009 Author Share Posted November 4, 2009 mednafen is in the main repositories and it is based on Handy code -- Karri So I've got mednafen working. Unfortunately, it seems like the debugger isn't working when running Lynx roms. I'm hitting Alt+D and nothing is happening as far as I can tell. Is it possible to use mednafen for debugging? If not, I know what my next coding project will be. We need a way to set breakpoints, step through code, read/write memory, etc. Emulators are the best way to do that. --Wookie Quote Link to comment Share on other sites More sharing options...
+karri Posted November 5, 2009 Share Posted November 5, 2009 mednafen is in the main repositories and it is based on Handy code -- Karri So I've got mednafen working. Unfortunately, it seems like the debugger isn't working when running Lynx roms. I'm hitting Alt+D and nothing is happening as far as I can tell. Is it possible to use mednafen for debugging? If not, I know what my next coding project will be. We need a way to set breakpoints, step through code, read/write memory, etc. Emulators are the best way to do that. --Wookie I am seriously thinking about integrating compilers and debuggers for Code::Blocks IDE. Please think about supporting Code::Blocks if you can modify NESHLA to fully support it. It is much faster and better than Eclipse or any other I have seen. It is on Ubuntu universe called "codeblocks". It uses no Makefiles and you can run stuff on Windows and Linux without any changes to your projects. -- Karri Quote Link to comment Share on other sites More sharing options...
Wookie Posted November 5, 2009 Author Share Posted November 5, 2009 I am seriously thinking about integrating compilers and debuggers for Code::Blocks IDE. Please think about supporting Code::Blocks if you can modify NESHLA to fully support it. It is much faster and better than Eclipse or any other I have seen. It is on Ubuntu universe called "codeblocks". It uses no Makefiles and you can run stuff on Windows and Linux without any changes to your projects. -- Karri Maybe it would be better to create a cross-platform liblynx project that packages up a lynx emulator as a library that can be used by other applications. That way it could be embedded in other IDE's as plugins. I personally use vim for all of my coding, so supporting Code::Blocks is not really interesting to me. I will however take patches against NESHLA for that purpose. --Wookie Quote Link to comment Share on other sites More sharing options...
gravitone Posted November 12, 2009 Share Posted November 12, 2009 I am seriously thinking about integrating compilers and debuggers for Code::Blocks IDE. Please think about supporting Code::Blocks if you can modify NESHLA to fully support it. It is much faster and better than Eclipse or any other I have seen. It is on Ubuntu universe called "codeblocks". It uses no Makefiles and you can run stuff on Windows and Linux without any changes to your projects. -- Karri Maybe it would be better to create a cross-platform liblynx project that packages up a lynx emulator as a library that can be used by other applications. That way it could be embedded in other IDE's as plugins. I personally use vim for all of my coding, so supporting Code::Blocks is not really interesting to me. I will however take patches against NESHLA for that purpose. --Wookie Focussing on NESHLA sounds like a good idea to me after having a quick look at it. Quote Link to comment Share on other sites More sharing options...
Wookie Posted November 12, 2009 Author Share Posted November 12, 2009 Focussing on NESHLA sounds like a good idea to me after having a quick look at it. I'm now the de facto maintainer of NESHLA. The latest version is in my NESHLA bitbucket repo. I took Brian's source, cleaned it up, added GNU autotools to manage the build process and made it portable enough that it compiles and runs on Linux/Mac OS X. I probably broke Windows support though. I was hoping to get one or more people to help maintain Windows support since I only use Linux. Now that we've worked out portable implementations of the Lynx encryption/decryption process, I'm going to do some work on NESHLA to support the Lynx. I think I'll rename it to 6502HLA unless you guys have a better name for it. I'm hoping to make it a more general 6502 HLA tool with support for other 6502 systems. --Wookie Quote Link to comment Share on other sites More sharing options...
