Vectrex lighpen question
Videogamecollector123
Hi, I am having a little trouble with the modified Vectrex lightpen,all the options just flicker on the screen when I put the pen up to it. This is the parts list, I wanted to know if there is anything wrong with it, I'm using the Playvectrex circuit
595-SN74LS132N
Quad 2-inp pos-NAND
660-MF1/4LCT52R222J
1/4 WATT 2.2K OHM 5%
660-MF1/4LCT52R103J
1/4 WATT 10K OHM 5%
512-2N3904TF
NPN 40V 200mA
594-K103M15X7RF53H5
.2LS .01UF 50V 20%
647-UVZ1C470MDD1TD
47uF 16V 20%
595-SN74LS132N
Quad 2-inp pos-NAND
660-MF1/4LCT52R222J
660-MF1/4LCT52R103J
1/4 WATT 10K OHM 5%
512-2N3904TF
NPN 40V 200mA
594-K103M15X7RF53H5
.2LS .01UF 50V 20%
647-UVZ1C470MDD1TD
47uF 16V 20%
also an NTE3032
tn_gallery_24423_428_426413.jpgtn_gallery_24423_428_322435.jpgtn_gallery_24423_428_46015.jpgjpgtn_gallery_24423_428_426413.jpg
Those are pictures of the circuit. On closer inspection the lead that connects the Phototransistor to the resistors wasn't soldered on right and was only making intermediate contact, so I'll try soldering it tommorow and see if the results are affected. I also sawed down the tip of the marker to put the transistor closer to the point.
