Latest WarBirds(working title) snap shots.
Gorf
Here is the latest snap shots of Warbirds. Still more work to be done but the first four levels
are practically complete. Now working on the Boss level, and may throw in a bonus secret level
(or two) that you get when you accomplish a certain feat of fancy.
Mission: Astral Assault
Mission: Battle Beams
Mission: Death Squad
Mission: War Wings
Mission: Momma Bird
Edited by Gorf
  • Like 5
Mission: War Wings
Mission: Momma Bird
All I can say is WOW! Please sign me up! :cool:
Mission: War Wings
Mission: Momma Bird
All in good time my friend. All in good time. :)
Just remember, the longer I work on a title, the
better it becomes.
Still much to be dealt with. Glad you like what you see.
I'm pretty sure you'll like what you play just as much
if not more.
It looks fantastic! I'll definitely be buying a cart (or two) assuming a release is forthcoming.
tjb
You will get these from ChickyBaby as a 3DSSS release once they are finished. There will be some time to go yet.
Probably when its warm again....hopefully. :) Im just hoping I can fit this all on a 32 K chip or Im going
to have to get creative hardware wise and quickly. Never messed with switch banking for 7800 yet....yet. ;)
Oh crap! I just noticed, thre is no mission text in War Wings.... DOH!...Ill have to fix
and update that shot. :(
EDIT: Shot of War wings repaired! :)
Edited by Gorf
tjb
Probably when its warm again....hopefully. icon_smile.gif Im just hoping I can fit this all on a 32 K chip or Im going
to have to get creative hardware wise and quickly. Never messed with switch banking for 7800 yet....yet. icon_wink.gif
EDIT: Shot of War wings repaired! icon_smile.gif
Hmm, 3DSSS + MilfTech should be interesting. Will there be naked chicks on the box? icon_mrgreen.gif
tjb
tjb
tjb
There will be no MILF tech on my games. An not one naked person anywhere.
Chicky will be sole distributor but it will be a sole 3DSSS release.
You can do 48K without bankswitching on the 7800. :)
Mitch
Mitch
Yeah but I have the 32k boards with POKEYS(Yes POKEY sound). Will they still work?
Edited by Gorf
Since you'll be using POKEY boards, the POKEY chip uses a portion of the available address space, leaving you with 32K for ROM.
This is the kind of situation that the XBoard would be so well suited for, if only it was more widely distributed. :(
Mitch
Yeah but I have the 32k bords will they still work?
Which board do you have? Is it the CO24926 Atari board?
Mitch
Mitch
Mitch
CO26461's...there is a spot for a smaller chip too.
Edited by Gorf
Ah, you edited while I was typing.
No, you can't use larger chips on the CO26461 board. Also, the larger C301105 Pokey board is somewhat uncommon.
Mitch
Sorry about that ....Well Im not out of room just yet and Im almost done with all the levels.
However I may not be able to fit the secret levels on there.
Edited by Gorf
The smaller chip footprint (to the right of POKEY) is for a 74LS04 inverter, which you will need to add--along with a 0.1uF capacitor at location C2, I believe--to allow the board to support 32K EPROMs. You will also need to clip open the jumper marked W3, directly underneath the inverter.
Mitch
Good to hear, hopefully you can fit it all in.
Mitch
Good to know....I will need to know the exact way for the Eproms. Unless I invest in 32k OTP's.
Do you know if the pokeys are all working?
The board needs the inverter because /OE is active high on Atari's mask ROMs but active low on standard EPROMs (and OTPs as well, unless I'm mistaken). Fortunately the CO26461 board is already set up for it, and it's a cheap and easy modification to do; the extra hardware required will probably cost about 33 cents per board.
I don't think I've ever seen a POKEY chip go bad on one of these boards; the ones I've pulled have all worked fine for me.
Ok cool...I just realized, I have about 2560 bytes of room left to fit everything else.
YIKES!
I may need to go in and see about optimizing and removing any code that is redundant.
ME WANT!!!!
Sign me up when you make carts, I will definitely buy one!
Curt
YIKES!
