+TrekMD Posted July 8, 2010 Share Posted July 8, 2010 This is cool. I had not seen this thread before. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted July 8, 2010 Share Posted July 8, 2010 I do have an idea for a two button hack, Vanguard. I'm not sure if this is practical but here it is. The idea is button B to shoot left and right and button C to shoot up and down. The controls should be global throughout the game. That would require additional RAM to be able to track the missiles seperately. IIRC it currently uses 2 bytes, so 2 more would need to be scrounged out of the disassembly. Otherwise, pressing a fire button when the alternate missiles are already onscreen would pose a problem...you could either ignore the button or write over the variables (killing missiles in play ala Gorf). Quote Link to comment Share on other sites More sharing options...
RevEng Posted July 8, 2010 Author Share Posted July 8, 2010 Can somebody check this? (posted down here in case it doesn't work) Your 2 button Double Dragon works for me, both on real hardware and in stella! As usual, I've updated the first post with a link to it. Quote Link to comment Share on other sites More sharing options...
nems Posted July 26, 2010 Share Posted July 26, 2010 (edited) Just updated the CX40 2nd Fire Button Instructions. Changes include: Increased the range of acceptable resistors (330 to 680 ohms all work fine). Eliminated the need to connect pin 5 (a 2nd fire button only needs pins 7&9 on one side and pin 8 on the other side). With pin 5 not connected, an added benefit is that one does not need to hold down the 1st fire button when booting with a Harmony cartridge. BTW, you can open any Genesis controller, disconnect pin 5 and still have both fire buttons working on the 2600 (plus eliminate the need to hold down the 1st fire button when booting up the Harmony). Of course you would need to re-connect pin 5 before attempting to use the controller again with a Sega Genesis system. Edited August 7, 2010 by nems 2 Quote Link to comment Share on other sites More sharing options...
RevEng Posted July 27, 2010 Author Share Posted July 27, 2010 Eliminated the need to connect pin 5 (a 2nd fire button only needs pins 7&9 on one side and pin 8 on the other side). With pin 5 not connected, an added benefit is that one does not need to hold down the 1st fire button when booting with a Harmony cartridge. Not having to hold down the button for Harmony 2-button support is pure awesome! Quote Link to comment Share on other sites More sharing options...
+Omegamatrix Posted August 4, 2010 Share Posted August 4, 2010 I just desoldered Pin 5 in my controller, and it worked flawlessly. I don't play any Sega games so this will be a permanent modification too. If you have no soldering skills and don't care about the joystick, then just snip the wire and wrap black electrical tape around both ends. Also Pin 5 is clearly marked on the circuit board (which I liked). Really easy fix, thanks nems!! Quote Link to comment Share on other sites More sharing options...
RevEng Posted August 4, 2010 Author Share Posted August 4, 2010 That's excellent news! I believe I'll neuter some pads and mark them specifically for the Atari somehow. I've updated the FAQ in the first post to include the pin 5 info. Thanks nems! I've also added 2 button versions of Mouse Trap and Sea Hawk to the first post as well. During hardware-testing I noticed that I accidentally enabled the fire button during the Sea Hawk attract mode. I think I'm just going to rename it the "auto-pilot trainer mode", and call it a day. Quote Link to comment Share on other sites More sharing options...
nems Posted August 7, 2010 Share Posted August 7, 2010 (edited) Thanks for more 2-button games! When playing any of these on real hardware, it feels like the 2600 is magically upgraded. Any chance someone could tackle Montezuma's Revenge? Keep all of the current control functionality, but add the 2nd-button to make Joe jump horizontally even from a standing still position. I'm guessing this is quite a challenge since the program must first check which direction Joe is facing (e.g. if Joe if facing east, then a press of the 2nd fire button results in a horizontal jump to the east). A disassembly of the game can be found here. Currently, I love this game but get sick of smashing my joystick handle trying to coordinate a horizontal jump from a standing still position. Some might think of this hack as a cheat, but IMHO it would allow for more precise and fun play, with less wear and tear on your joystick. Edited August 7, 2010 by nems Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted August 7, 2010 Share Posted August 7, 2010 (edited) Actually, the challenge isn't there...because the routine checks the stick itself in the jump routine, and the program keeps track of the button AND the stick from the previous frame (each uses their own byte). Since you have 2 buttons, each can be dedicated to a direction. Rewriting the button routine to keep both buttons only required a few bytes, and altering the jump routine was simplified. However, using 2 values instead of one caused Joe to jump immediately when starting...so I added a couple lines up top to force the "already pressed" value into the button cache. Push the joystick up when pressing either button to jump in place. Try this...This is an E0 bankswitched game (Z26 use -g3). Montezumas_Revenge.zip Edited August 7, 2010 by Nukey Shay 1 Quote Link to comment Share on other sites More sharing options...
nems Posted August 7, 2010 Share Posted August 7, 2010 (edited) Nukey, you are amazingly quick. I tested Montezuma's Revenge via Harmony on NTSC hardware and it works great. Only problem is that the jumping directions should be reversed. It seems most natural to mimic the button order/layout so that: 1st button (Sega B) = jump left 2nd button (Sega C) = jump right Currently you have the jumping directions reversed (opposite order). This game is already so much more fun to play. The precision control is freakin' amazing. Edited August 9, 2010 by nems Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted August 7, 2010 Share Posted August 7, 2010 Edited Quote Link to comment Share on other sites More sharing options...
nems Posted August 7, 2010 Share Posted August 7, 2010 (edited) Thank you Nukey! The game control is soooo great with two buttons. Very responsive. This is an amazing improvement! Panama Joe is much happier too 'cause now he doesn't die nearly as often. Edited August 7, 2010 by nems Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted August 7, 2010 Share Posted August 7, 2010 Should be possible to alter the hack so that it functions both ways (depending on which button is used to start the game, putting it in a difficulty switch, or etc). There's room for branching, and plenty of optimizations that could be done. Did anybody ever get very far into altering the bankswitching to be conventional instead of PB's E0? That too could easily be done if it were upped to 32k...but I don't want to add that much redundancy if it isn't needed (much rather see it in 16k). Quote Link to comment Share on other sites More sharing options...
A.J. Franzman Posted August 7, 2010 Share Posted August 7, 2010 Montezuma\'s Revenge (F6 Conversion) Thomas Jentzsch.bin Montezuma\'s Revenge (F6 Conversion, PAL) Thomas Jentzsch.bin Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted August 7, 2010 Share Posted August 7, 2010 (edited) Thanks...F6 conversions given both buttons. Edited August 9, 2010 by Nukey Shay Quote Link to comment Share on other sites More sharing options...
nems Posted August 8, 2010 Share Posted August 8, 2010 (edited) Nukey, I tested the F6 version of Montezuma and found: 1st Fire button results in a right horizontal jump (should be left). 2nd Fire button is MIA. I'm still playing the hell out of your E0 bankswitched version and it is perfect. Edited August 9, 2010 by nems Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted August 9, 2010 Share Posted August 9, 2010 (edited) I missed editing the routine in another bank. Hopefully, this is straightened out. No way for me to check this (because Z26 doesn't support 2 buttons and Stella no longer works under Win98), so I gotta play it by ear. Current version allows you to select which mode it's in (left difficulty A = single button, B = two buttons). Q: Atari's standard fire button should correspond to the RIGHT jump, correct? I thought that was how I did the E0 version Edited August 10, 2010 by Nukey Shay Quote Link to comment Share on other sites More sharing options...
nems Posted August 9, 2010 Share Posted August 9, 2010 (edited) Current version allows you to select which mode it's in (left difficulty A = single button, B = two buttons). Tested and works just as you described. Excellent job. Though I have to say that once someone experiences the two button version, I doubt they will ever go back to the single button version. Having 2 button control really elevates this game. Q: Atari's standard fire button should correspond to the RIGHT jump, correct? I thought that was how I did the E0 version That is how you did E0 the very first time, then I asked you to flip it (which you did). Currently both E0 and F6 are set up such that: Atari standard button (Sega B) = jump left 2nd button (Sega C) = jump right Either button + joystick up = jump in place ...which seems like a natural order for Sega and modded CX40 controllers. Thanks again. Edited August 9, 2010 by nems Quote Link to comment Share on other sites More sharing options...
RevEng Posted August 9, 2010 Author Share Posted August 9, 2010 I missed editing the routine in another bank. Hopefully, this is straightened out. No way for me to check this (because Z26 doesn't support 2 buttons and Stella no longer works under Win98), so I gotta play it by ear. I hacked in genesis controller support to z26... z26_20040523_genesis.zip ...You only need to use the z26_20040523_genesis.exe binary, but I included the source as it was the easiest way to comply with the GPL. Use the CLI switch "-)GC" for the genesis controller. Left ctrl is the Genesis-B/INPT4 button, and right shift is the Genesis-C/INPT1 button. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted August 10, 2010 Share Posted August 10, 2010 (edited) No biggie...I hacked the game to include a dual-stick mode to use left and right I also added a splash screen, since bank 4 wasn't being used for anything. EDIT: Damn...bonus room got axed...trying this again: Montezumas_Revenge_F6.zip Edited August 10, 2010 by Nukey Shay 1 Quote Link to comment Share on other sites More sharing options...
+thegoldenband Posted November 7, 2010 Share Posted November 7, 2010 Wonderful stuff in this thread! I just finished a good game of Double Dragon (made it to Mission 3), and the two-button control scheme really helps. Thanks so much to Nukey Shay for that. Quote Link to comment Share on other sites More sharing options...
Bakasama Posted November 9, 2010 Share Posted November 9, 2010 How about this for a hack, a two button version of Dark Chambers. In the 2600 version of Dark Chambers, you use the bombs by hitting the fire button twice quickly. Quote Link to comment Share on other sites More sharing options...
psquare75 Posted December 3, 2010 Share Posted December 3, 2010 Wow, I hadn't seen this thread before. Some games off the top of my head. Enduro Star Trek Could IMO badly use 2 button support. Great idea! Quote Link to comment Share on other sites More sharing options...
+Omegamatrix Posted December 9, 2010 Share Posted December 9, 2010 Star Trek How should the controls work for this? You have: - thrust - warp drive - photons - lasers It's very easy to make one button for lasers, one button for photons, and then have warp drive by pressing down. Thrust would remain the same. Or was the thrust the control problem? How should it work?? Quote Link to comment Share on other sites More sharing options...
psquare75 Posted December 9, 2010 Share Posted December 9, 2010 A button phasers B button warp down direction photon. up direction impulse power. Yes, warp is the issue. Quote Link to comment Share on other sites More sharing options...
