GregadetH Posted March 5, 2010 Share Posted March 5, 2010 I've got a Competition Pro SG-6 six button controller made by HoneyBee. It's pretty much the main controller I use when playing my Genny. Yesterday, It started pausing from the z button and nothing else. The d-pad works fine. I cleaned all the contacts and it still does it. The rubber's still nice and springy and hasn't hardened up or cracked. Any ideas as to what's goin' on in there? Quote Link to comment Share on other sites More sharing options...
+save2600 Posted March 5, 2010 Share Posted March 5, 2010 There's a tiny I.C. in there that may have fried. Sometimes unplugging and plugging back in a logic based controller while the console is on can cause this. Especially if you've got the system or control pad near a static charged scenario such as plush carpeting. Quote Link to comment Share on other sites More sharing options...
GregadetH Posted March 5, 2010 Author Share Posted March 5, 2010 There's a tiny I.C. in there that may have fried. Sometimes unplugging and plugging back in a logic based controller while the console is on can cause this. Especially if you've got the system or control pad near a static charged scenario such as plush carpeting. I'm pretty sure that's what happened. Is there a way to physically tell if it's fried? Quote Link to comment Share on other sites More sharing options...
+save2600 Posted March 5, 2010 Share Posted March 5, 2010 I'm pretty sure that's what happened. Is there a way to physically tell if it's fried? Not physically, usually no. But the symptoms sure seem to indicate that's what happened. Did you plug in a regular Genny controller and verify it's not the consoles fault? If the Honeybee is fried, you could always just rewire it and use it as a simple gamepad for another console. Quote Link to comment Share on other sites More sharing options...
GregadetH Posted March 5, 2010 Author Share Posted March 5, 2010 Fortunately, it's not the console. I Guess I'll do some research on how to re-wire it. Thanks! Quote Link to comment Share on other sites More sharing options...
tz101 Posted March 7, 2010 Share Posted March 7, 2010 Don't know that specific controller, but have seen some controllers go from blown fuses/resistors over the years. There is usually at least one resistor on the controller's PCB. A multi-tester should allow you to diagnose if this is the case with yours. Quote Link to comment Share on other sites More sharing options...
GregadetH Posted March 7, 2010 Author Share Posted March 7, 2010 Don't know that specific controller, but have seen some controllers go from blown fuses/resistors over the years. There is usually at least one resistor on the controller's PCB. A multi-tester should allow you to diagnose if this is the case with yours. That's a great idea. I'll check that out later today. Thanks! Quote Link to comment Share on other sites More sharing options...
