I am using this schematic of the PONG arcade system, http://www.atarihq.com/danb/files/PongSchematic.pdf , but have some questions. do the resistors like the one on the HSYNC board hooking up to +5V have any specific value? there isn't one on any schematic I can find.
https://forums.atariage.com/topic/159434-pong-arcade-schematic/
  • 2 weeks later...
Those resistors are pull-up resistors. They are holding the particular inputs at a logic high level. Pull-up resistors usually range in value from 1k ohm to upwards of 10k ohms. You can safely use 2.2k or 2200 ohm (red-red-red-gold - 4band, red-red-black-brown-gold - 5band).
Glenn
  • 3 weeks later...
Glenn
Thank you very much! that is exactly what I needed. :D
