CGQuarterly Posted April 2, 2010 Share Posted April 2, 2010 A question that has come up a couple of times here on AA is whether or not you can use a replacement CX-40 PCB from Best Electronics in a CX-10 (the "heavy-sixer joystick). I had a CX-10 that wasn't working properly, so I thought I would give it a try. IT worked, so I typed up the results and posted an article on Classic Gaming Quarterly. http://www.cgquarterly.com/articles/cx10.htm Thanks for reading, Chris Quote Link to comment Share on other sites More sharing options...
Timstuff Posted April 2, 2010 Share Posted April 2, 2010 A question that has come up a couple of times here on AA is whether or not you can use a replacement CX-40 PCB from Best Electronics in a CX-10 (the "heavy-sixer joystick). I had a CX-10 that wasn't working properly, so I thought I would give it a try. IT worked, so I typed up the results and posted an article on Classic Gaming Quarterly. http://www.cgquarterly.com/articles/cx10.htm Thanks for reading, Chris I did a similar mod once, but yours seems to be cleaner and does not involve any modification of the CX-10 itself. I used a hobby saw to cut the corner off of the circuit board and then used a dremel to shave down some of the white plastic tab board so it could sit on the connectors properly. Good job though, I think that next time I come across a CX-10 I'll do it your way. Quote Link to comment Share on other sites More sharing options...
Almost Rice Posted April 2, 2010 Share Posted April 2, 2010 Do the CX-10 use domes? I believe my set used rectangular switches with a crease down the middle length of the metal. Quote Link to comment Share on other sites More sharing options...
CGQuarterly Posted April 2, 2010 Author Share Posted April 2, 2010 (edited) Yup, domes. The PCB on the right side of the first pic in the article is the original board. That being said, it is certainly possible that there were different versions used so your memory may be correct. Chris Edited April 2, 2010 by Jibbajaba Quote Link to comment Share on other sites More sharing options...
