+FarmerPotato Posted November 1 Share Posted November 1 4 hours ago, OLD CS1 said: This "write a patch and submit" approach has been prevalent since the late 90s and has pushed many people away from open source, at least as an objectionable position I don't understand what you mean here. "write a patch and submit" isn't off-putting to me. There are variations: "Create an Issue that describes the details of what you want" Or "I'm not sure if that's an easy or a hard feature, someone needs to scope it out" All are like "My stack is full, you can help by volunteering". 1 Quote Link to comment https://forums.atariage.com/topic/161356-magellan/page/29/#findComment-5558776 Share on other sites More sharing options...
retrodroid Posted November 1 Share Posted November 1 8 hours ago, matthew180 said: True, but this is a hobby, and there are only so many hobby hours in a day. For right now the work I do on the F18A, tidbit, and forum posts where I can be helpful, is going to have to suffice as my contributions to the community. I guess I should have used a winky face instead of a smile... 😘 Yes, aside from all that stuff you mentioned above, your thread is largely responsible for convincing me that I could, indeed, learn Assembly Language and use it constructively for my own "hobby hours" projects, something I've found to be a very happy place indeed to while away the hours when time and commitments permit. 2 1 Quote Link to comment https://forums.atariage.com/topic/161356-magellan/page/29/#findComment-5558837 Share on other sites More sharing options...
matthew180 Posted November 2 Share Posted November 2 1 hour ago, retrodroid said: I guess I should have used a winky face instead of a smile... 😘 ... Heh, no problem, thanks for clarifying. 🙂 Classic case of how easy it is in writing for there to be confusion between intent and perception. 3 Quote Link to comment https://forums.atariage.com/topic/161356-magellan/page/29/#findComment-5558902 Share on other sites More sharing options...
+OLD CS1 Posted November 2 Share Posted November 2 2 hours ago, retrodroid said: I guess I should have used a winky face instead of a smile... 😘 35 minutes ago, matthew180 said: Heh, no problem, thanks for clarifying. 🙂 Classic case of how easy it is in writing for there to be confusion between intent and perception. That being the case, I rescind and apologize for my directed comment, while I stand by my general comment. 3 Quote Link to comment https://forums.atariage.com/topic/161356-magellan/page/29/#findComment-5558917 Share on other sites More sharing options...
+FarmerPotato Posted November 6 Share Posted November 6 On 11/1/2024 at 8:45 AM, retrodroid said: You could also consider implementing this feature into Magellan yourself and contributing it back to the community. I have my "ExRLE" compression implementation that I will be adding to the code-base once I finish my game as well. I dreamed that I was typing TI BASIC programs into Magellan, like: REM SHIFT ALL THE CHARACTERS UP BY ONE ROW FOR I=30 TO 127 CALL CHARPAT(I, A$) A$ = SEG$(A$,3,14)&"00" CALL CHAR(I,A$) NEXT I Look, a Macro language. REM TRY OUT THE FONT DISPLAY AT(2,1):"THE QUICK BROWN FOX JUMPS" DISPLAY AT(3,1):"OVER THE LAZY DOG" DISPLAY AT(4,1):"the quick brown fox jumps" DISPLAY AT(5,1):"over the lazy dog" A feature I've thought about implementing, needs to do this: REM SHOW SPRITE ON VARIOUS BACKGROUNDS CALL MAGNIFY(3) FOR I=1 TO 10 R=I*2-1 CH=I*4+96 CALL VCHAR(R,1,CH,2) CALL VCHAR(R,2,CH,2) Y=I*16-15 CALL SPRITE(#I,96,7,Y,1) NEXT I Still dreaming. Quote Link to comment https://forums.atariage.com/topic/161356-magellan/page/29/#findComment-5561476 Share on other sites More sharing options...
