+Vorticon Posted October 28, 2013 Share Posted October 28, 2013 Thanks guys. Does accessing the parallel port (both reads and writes)disable interrupts? For what I have in mind, missing a few 1/60th of a second cycles will not be problematic, as long as PIO access does not affect interrupts. If it does, then I may have to go the 9901 route. Quote Link to comment https://forums.atariage.com/topic/162941-assembly-on-the-994a/page/12/#findComment-2855335 Share on other sites More sharing options...
+Lee Stewart Posted October 28, 2013 Share Posted October 28, 2013 Thanks guys. Does accessing the parallel port (both reads and writes)disable interrupts? For what I have in mind, missing a few 1/60th of a second cycles will not be problematic, as long as PIO access does not affect interrupts. If it does, then I may have to go the 9901 route. PIO uses DSR access and, I believe, all DSRs disable interrupts at some point. ...lee Quote Link to comment https://forums.atariage.com/topic/162941-assembly-on-the-994a/page/12/#findComment-2855337 Share on other sites More sharing options...
Willsy Posted October 28, 2013 Share Posted October 28, 2013 You can bypass the DSR for serial and paralell (sp?) access and go straight to the hardware, though owners of the new nanoPEB won't thank you for it If you're going direct to the hardware, then I reckon (haven't tested) you can leave interrupts enabled (LIMI 2) - just don't use GPLWS as your workspace, as that is used by the console ISR IIRC. Quote Link to comment https://forums.atariage.com/topic/162941-assembly-on-the-994a/page/12/#findComment-2855385 Share on other sites More sharing options...
Willsy Posted October 28, 2013 Share Posted October 28, 2013 Hmm... Thinking about it some more, arrival of a byte at the serial port (dunno about parallel port) I think causes an interrupt. I can't remember now. Recommend a good review of Thierry's pages on the TI RS233 card. Quote Link to comment https://forums.atariage.com/topic/162941-assembly-on-the-994a/page/12/#findComment-2855386 Share on other sites More sharing options...
marc.hull Posted October 28, 2013 Share Posted October 28, 2013 Has anyone ever run into problems with the divide instruction giving a larger than possible remainder after execution ? My understanding is that the divide instruction takes two registers and treats that as an unsigned integer in the form of >XXXX XXXX. This is divided by a third value in the form of >XXXX. This should yield a quotient of >XXXX and a remainder of >XXXX (where remainder >XXXX is always less than the divisor.) This weekend when trying to improve my RNG I was dividing larger than 16 bit numbers by the value 768 and was getting remainders much larger than 768. When I cleared the first word of the word pair the remainder came back into range. IE >XXXX XXXX / 768 yielded remainders larger than 768. Whereas >0000 XXXX / 768 yielded remainders smaller than 768. Am I missing something about the significance of the word pair or does the divide instruction have a bug in it ? Quote Link to comment https://forums.atariage.com/topic/162941-assembly-on-the-994a/page/12/#findComment-2855461 Share on other sites More sharing options...
+mizapf Posted October 28, 2013 Share Posted October 28, 2013 Well, if you're getting an overflow, the arguments won't be changed. Maybe your remainder is just the original value of the second word? Quote Link to comment https://forums.atariage.com/topic/162941-assembly-on-the-994a/page/12/#findComment-2855468 Share on other sites More sharing options...
marc.hull Posted October 28, 2013 Share Posted October 28, 2013 Well, if you're getting an overflow, the arguments won't be changed. Maybe your remainder is just the original value of the second word? Well that's probably it then.Just to clarify...... If the instruction creates a quotient larger than 65536 then it terminates and leaves the word pair unchanged ? Thanks Quote Link to comment https://forums.atariage.com/topic/162941-assembly-on-the-994a/page/12/#findComment-2855477 Share on other sites More sharing options...
+mizapf Posted October 28, 2013 Share Posted October 28, 2013 Yes. The arguments remain unchanged. The overflow test can be done before the division process starts; the ALU just has to check whether the divisor is greater than the first word. Quote Link to comment https://forums.atariage.com/topic/162941-assembly-on-the-994a/page/12/#findComment-2855485 Share on other sites More sharing options...
+Lee Stewart Posted October 28, 2013 Share Posted October 28, 2013 Well that's probably it then.Just to clarify...... If the instruction creates a quotient larger than 65536 then it terminates and leaves the word pair unchanged ? Thanks Not to put too fine a point on it; but, it would be a quotient larger than 65535 (FFFFh). ...lee Quote Link to comment https://forums.atariage.com/topic/162941-assembly-on-the-994a/page/12/#findComment-2855503 Share on other sites More sharing options...
+Vorticon Posted October 31, 2013 Share Posted October 31, 2013 Hi. What is the best way to slow down KSCAN polling? I tried something along those lines and it broke the key scanning process completely, but I'm not sure why: KEYINP MOV R11,@SUBRTN * SAVE SUBROUTINE RETURN ADDRESS LI R1,>FF00 RESCAN BLWP @KSCAN * CALL KEYSCAN ROUTINE DELAY LI R10,5000 * DELAY LOOP DEC R10 JNE DELAY CB @KEY,R1 * KEY IS ADDRESS OF KEY VALUE RETURNED BY KSCAN JEQ RESCAN * AN >FF INDICATES NO KEY PRESSED MOV @SUBRTN,R11 * RELOAD RETURN ADDRESS INTO R11 B *R11 Quote Link to comment https://forums.atariage.com/topic/162941-assembly-on-the-994a/page/12/#findComment-2857424 Share on other sites More sharing options...
+Vorticon Posted October 31, 2013 Share Posted October 31, 2013 OK I think I'm going to answer my own post. The main need for the delay was to avoid the same key being detected repeatedly. I found this in my Ultimate Planet code, which should do the trick (I must have been a little smarter a couple of years ago ) ** KEY INPUT ROUTINE ** KEYINP MOV R11,@SUBRTN * SAVE SUBROUTINE RETURN ADDRESS SCAN CLR @GPLSTS * CLEAR GPL STATUS BYTE BLWP @KSCAN * CALL KEYSCAN ROUTINE LIMI 2 * ENABLE INTERRUPTS LIMI 0 * DISABLE INTERRUPTS CB @ANYKEY,@GPLSTS * CHECK IF BIT 2 OF GPL STATUS BYTE IS SET JNE SCAN * RESCAN IF SAME KEY PRESENT IN KEY BUFFER MOV @SUBRTN,R11 * RELOAD RETURN ADDRESS INTO R11 B *R11 Quote Link to comment https://forums.atariage.com/topic/162941-assembly-on-the-994a/page/12/#findComment-2857429 Share on other sites More sharing options...
Asmusr Posted October 31, 2013 Share Posted October 31, 2013 I suggest to move LI R10,5000 outside the delay loop Quote Link to comment https://forums.atariage.com/topic/162941-assembly-on-the-994a/page/12/#findComment-2857432 Share on other sites More sharing options...
+Vorticon Posted October 31, 2013 Share Posted October 31, 2013 (edited) I suggest to move LI R10,5000 outside the delay loop Of course No idea how I missed that!!! Excellent suggestion he he... I need more sleep In case anybody is wondering what I'm up to, I finally finished early this morning the basic framework of a robotic arm control program which controls this robotic arm http://www.owirobots.com/store/index.php?l=product_detail&p=110 which was kindly given to me by Jens Eike last year at the Chicago Fair. The arm is purely mechanical with only gears, 5 motors and an LED light without any electronics, sensors or servos, and I have it hooked up to the parallel port through some simple relay circuitry to provide bi-directional control. As things stand now, I am able to control the arm manually through the TI keyboard. I still want to implement a programming option, but I'm not sure I'll have that finished by Faire time because I still have to move the circuitry off the breadboard and onto a more permanent platform, either a home brew PCB or a perf board tonight. I should be able to demo the arm at the Faire on Saturday. Fun little project Edited October 31, 2013 by Vorticon 3 Quote Link to comment https://forums.atariage.com/topic/162941-assembly-on-the-994a/page/12/#findComment-2857434 Share on other sites More sharing options...
Willsy Posted October 31, 2013 Share Posted October 31, 2013 Excellent. That's just begging to be done in Forth. TF or fbForth, I don't care, but it's perfect Forth. Imagine just typing commands and watching the arm move, then combining those commands into colon definitions. Just like Logo! Quote Link to comment https://forums.atariage.com/topic/162941-assembly-on-the-994a/page/12/#findComment-2857464 Share on other sites More sharing options...
+Vorticon Posted October 31, 2013 Share Posted October 31, 2013 (edited) Excellent. That's just begging to be done in Forth. TF or fbForth, I don't care, but it's perfect Forth. Imagine just typing commands and watching the arm move, then combining those commands into colon definitions. Just like Logo! Definitely something to consider. Embed the assembly code into colon definitions and string them together at will. I assume that there should be no limitations in low level access of the PIO port from within forth. Edited October 31, 2013 by Vorticon Quote Link to comment https://forums.atariage.com/topic/162941-assembly-on-the-994a/page/12/#findComment-2857484 Share on other sites More sharing options...
Willsy Posted October 31, 2013 Share Posted October 31, 2013 None at all. If you load the assembler you can write assembler code and add it to the dictionary like colon defs. E.g. (TF) ASM: delay ( n -- ) *SP+ R1 MOV, \ pop n to R1 $FFFF R0 MOV, \ inner delay to R0 BEGIN, BEGIN, R0 DEC, \ decrement r0 NE REPEAT, \ loop while r0<>0 R1 DEC, \ decrement outer delay NE REPEAT, \ loop while R1 <> 0 ;ASM Boom. That's a machine code definition. You can run it right after typing it: 5 DELAY No "edit/save/assemble/load" cylce. Just type it in. Quote Link to comment https://forums.atariage.com/topic/162941-assembly-on-the-994a/page/12/#findComment-2857495 Share on other sites More sharing options...
Willsy Posted October 31, 2013 Share Posted October 31, 2013 You can even mix Forth and assembly. So, for example, the CRU address of the TI RS232 could be defined as a constant: $FACE CONSTANT RS232_CRU \ (don't know what the cru address is!) ASM: SendToPIO( n -- ) \ send a byte to the PIO R12 RS232_CRU LI, \ load CRU address ... ... ;ASM Quote Link to comment https://forums.atariage.com/topic/162941-assembly-on-the-994a/page/12/#findComment-2857503 Share on other sites More sharing options...
+Vorticon Posted October 31, 2013 Share Posted October 31, 2013 (edited) You can even mix Forth and assembly. So, for example, the CRU address of the TI RS232 could be defined as a constant: $FACE CONSTANT RS232_CRU \ (don't know what the cru address is!) ASM: SendToPIO( n -- ) \ send a byte to the PIO R12 RS232_CRU LI, \ load CRU address ... ... ;ASM >1300 Edited October 31, 2013 by Vorticon Quote Link to comment https://forums.atariage.com/topic/162941-assembly-on-the-994a/page/12/#findComment-2857512 Share on other sites More sharing options...
+Vorticon Posted October 31, 2013 Share Posted October 31, 2013 None at all. If you load the assembler you can write assembler code and add it to the dictionary like colon defs. E.g. (TF) ASM: delay ( n -- ) *SP+ R1 MOV, \ pop n to R1 $FFFF R0 MOV, \ inner delay to R0 BEGIN, BEGIN, R0 DEC, \ decrement r0 NE REPEAT, \ loop while r0<>0 R1 DEC, \ decrement outer delay NE REPEAT, \ loop while R1 <> 0 ;ASM Boom. That's a machine code definition. You can run it right after typing it: 5 DELAY No "edit/save/assemble/load" cylce. Just type it in. Old habits die hard... Frankly I never even considered Forth when I started this project a week ago. The control program is pretty simple because the PIO is so easy to access, so it should be fairly straightforward to port it to TF. I'll have to look at this after the Faire. Quote Link to comment https://forums.atariage.com/topic/162941-assembly-on-the-994a/page/12/#findComment-2857517 Share on other sites More sharing options...
Willsy Posted October 31, 2013 Share Posted October 31, 2013 Or, send me your assembly code and I'll port it. Quote Link to comment https://forums.atariage.com/topic/162941-assembly-on-the-994a/page/12/#findComment-2857520 Share on other sites More sharing options...
+Vorticon Posted October 31, 2013 Share Posted October 31, 2013 Or, send me your assembly code and I'll port it. I just might take you up on that offer! I'll send you the source code once it is finalized. Quote Link to comment https://forums.atariage.com/topic/162941-assembly-on-the-994a/page/12/#findComment-2857521 Share on other sites More sharing options...
matthew180 Posted November 1, 2013 Author Share Posted November 1, 2013 In case anybody is wondering what I'm up to, I finally finished early this morning the basic framework of a robotic arm control program which controls this robotic arm ... ... I should be able to demo the arm at the Faire on Saturday. Fun little project VERY COOL! I really like robotics and I'll be very interested in seeing your project! Quote Link to comment https://forums.atariage.com/topic/162941-assembly-on-the-994a/page/12/#findComment-2857807 Share on other sites More sharing options...
+Vorticon Posted November 14, 2013 Share Posted November 14, 2013 So one of my peeves with the TI Assembler is that one is not allowed labels longer than 6 characters. This becomes a nightmare with large programs as I struggle to come up with unique yet meaningful tags. I noted that the asm994a assembler allows the use of long labels, however the resulting object code will not run and will give the error of ILLEGAL TAG. Is there a better native assembler out there which allows long labels? Quote Link to comment https://forums.atariage.com/topic/162941-assembly-on-the-994a/page/12/#findComment-2866968 Share on other sites More sharing options...
+Lee Stewart Posted November 14, 2013 Share Posted November 14, 2013 So one of my peeves with the TI Assembler is that one is not allowed labels longer than 6 characters. This becomes a nightmare with large programs as I struggle to come up with unique yet meaningful tags. I noted that the asm994a assembler allows the use of long labels, however the resulting object code will not run and will give the error of ILLEGAL TAG. Is there a better native assembler out there which allows long labels? Works fine for me. Are you using Assm994a v3.010? Post the code so we can look over your shoulder. ...lee Quote Link to comment https://forums.atariage.com/topic/162941-assembly-on-the-994a/page/12/#findComment-2866994 Share on other sites More sharing options...
+Vorticon Posted November 14, 2013 Share Posted November 14, 2013 Works fine for me. Are you using Assm994a v3.010? Post the code so we can look over your shoulder. ...lee It's really a very simple test: DEF START12345678 START12345678 CLR R1 LI R2,>FF00 MOVB R2,R1 END Quote Link to comment https://forums.atariage.com/topic/162941-assembly-on-the-994a/page/12/#findComment-2867036 Share on other sites More sharing options...
