The long name exception is probably with the DEF statement because that entry has to go into the REF/DEF table in 99/4A RAM, as well as being read by the E/A or XB loader.
Try something more like this and see if it compiles:
       DEF MAIN
MAIN   CLR  R1
long_loop_name DEC R1
               JNE long_loop_name
       END
Edited by matthew180
There is a difference between internal labels and external labels. If you use a DEF, the label will be put into the object code so that the linking loader can resolve REFs with it. If it does not appear in a DEF or REF, the symbol length is just a matter of the assembler.
[Edit: I was too slow... ]
Edited by mizapf
Your example worked for me unmodified.
* Loaded into Asm994a v3.010
* Checked "Def Regs", "Produce Listing File", and "Produce HEX Obj File"
* Copied resulting .obj file to my DSK3 directory for Classic99
* Run Classic99 with E/A cart
* Choose #3 in main E/A menu
* DSK3.long_label_test.obj
* Press enter
* START
Same question, Walid: Are you using Asm994a v3.010?
...lee
Yes I am.
So here's a weird one for you: it seems that if the object file is saved with the .obj extension, it will run just fine. However, if the object file has the _o or .o extension, then I get the ILLEGAL TAG error...
I'm used to name my object files xxxx_o and never had that issue before. Go ahead and try it and please let me know if I am going crazy here... My Classic99 version on this computer is QI371.
Yes I am.
I'm using QI372; but, now that you mention it, I seem to remember having some similar kind of problem running in FIAD mode. I'm sorry that I don't remember the specifics—but, I think that's what drove me to have Asm994a copy my object files to a disk image from which I copied to a FIAD directory with Fred's Ti99Dir. A RPITA, but it works.
...lee
Yes I am.
It's because Classic99 is not translating the file. (Unfortunately the 'ILLEGAL TAG' message given by the loader isn't very useful).
In order to read /Windows text files/ as TI files, Classic99 resorts to the extension. If the extension is .TXT or .OBJ (and .OBJ is only there to support Asm994A), then it knows it's a text file and applies the translation.
Troubleshooting this would have been easy the same way you would have on the original machine -- load the file into the editor and view it - you would have seen it was all corrupted. :) Alternately, look at the debug log and see what Classic99 was trying to do. :)
By default, files without a Windows extension are treated as DF128 (to match the TIFILES behaviour) - there is an option on the disk config to treat them as text files, which would fix your _o "extension". The only way to make ".o" read as a Windows text file in Classic99 is to apply the file type override: DSK1.?W.FILE.O (?W - read as Windows Text). The log will always tell you what it tried to open.
  • 2 months later...
Is there an easier way to extract the MSB and LSB of an address in WinAsm99/Asm994a than this (example from a repeating sound list)?
SNDLST BYTE ...
       BYTE 0
       BYTE SNDLST/256,-SNDLST/256*256+SNDLST
       BYTE -1
Note that you cannot simply use:
       DATA SNDLST
because this will be adjusted to an even address.
SNDLST BYTE ...
       BYTE 0
       BYTE -1
       DATA SNDLST
I ran into this problem when I was creating sound lists for my CRPG, the even/odd address issue. I fixed it by using base address and labels for each sound effect in a pure byte list, and created a data-address table at the start to store the exact location of each sound.
Repeating sounds, though, I still had to calculate a literal address... there just isn't another way to do that cleanly with labels.
Adamantyr
SNDLST BYTE ...
       BYTE 0
       BYTE -1
       DATA SNDLST
Can you elaborate on what your meaning is. Looks like your trying to save a byte?
No, I'm, trying to create a sound list that can be relocated, without counting bytes in order to make sure that the loop address is located at an even address, which it would have to be if you used a DATA directive. If you use a DATA directive and the address is not even, WinAsm99 inserts a zero byte before the loop address, which breaks the sound list. Anyway, my method for calculating the MSB and LSB in this parenthesis free expression language works, but WinAsm99 has several undocumented features (e.g conditional assembly, longer labels) so it might have a secret way of getting the MSB and LSB of a labelled address.
Your embedding an address in your list.... Got it although I don't understand the math for the second byte. Seem like it should always be zero
It's the same as the expression SNDLST- (SNDLST div 256) * 256 but without the parentheses. Div is integer division.
  • 2 weeks later...
This looks cool, too bad I do not have the skillset to use it.....
* The following source code is intended to be a support routine for
* SUPER-CART programmers who need stand-alone support for their programs
* which reside in the >6000 to >7FFF cartridge space. It definitely
* supports KSCAN, VSBW, VMBW, VSBR, VMBR, VWTR, DSRLNK, XMLLNK and
* GPLLNK and these have been proven to work. It also has a CIF routine
* which I haven't had an opportunity to test. Probably much of it could
* be weeded out to conserve space. The bulk of the routines were kindly
* sent me by David Romer and consist of the UTILEQU, UTILRAM, and UTILROM
* files which I understand to be part of the (public domain) TI-FORTH
* source code. I also note that these same files were incorporated into
* Tom Knight's TK-WRITER source code. My contributions to this routine
* consist of the blocks whose comments are mainly written in upper case
* and this entire file is meant to be released to public domain for use
* and redistribution by anyone who wishes it. I had trouble getting the
* GPLLNK routine to work and with the kind permission of Paul Charlton,
* have incorporated his GPLLNK routines from his Fast-Term program which
* do work in this environment. See program comments for more details.
* I would certainly appreciate any feedback or corrections anyone finds and
* I hope this is helpful. Enjoy! Jim McCulloch, 9505 Drake Avenue,
* Evanston, IL 60203-1107 (CIS 74766,500)
* SUPER-CART SKELETON ROUTINE: for SUPER-CART programmers to hang their
* routines on and flesh it out more. This version done 14 December 1985.
DEF PROG3,PROG4,PROG5,PROG6,PROG7,PROG8,PROG9
* THERE ARE SPACES FOR 9 MENU SELECTIONS WITH TI-BASIC
* AND E/A TAKING UP THE FIRST TWO. PROGRAMS 3-9 ARE
* YOURS.
AORG >6000 THIS IS THE BEGINNING OF THE SUPER-CART SPACE IN MEMORY
SCNKEY EQU >000E
XMLTAB EQU >0CFA XML tables (base)
PAB EQU >1000 PERIPHERAL ACCESS BLOCK
FLAG2 EQU >8349
FAC EQU >834A USED BY THE CIF ROUTINE AS WELL AS GPLLNK, ETC.
SCLEN EQU >8355
SCNAME EQU >8356
SUBSTK EQU >8373
STATUS EQU >837C GPL STATUS REGISTER
CRULST EQU >83D0
SADDR EQU >83D2
GPLWS EQU >83E0 GPL/EXTENDED BASIC workspace
PAD EQU >8300
VDPRD EQU >8800 VDP read data address
VDPSTA EQU >8802 VDP RAM status
VDPWD EQU >8C00 VDP write data address
VDPWA EQU >8C02 VDP write address address
R0LB EQU >83E1
R1LB EQU >83E3
R3LB EQU >83E7
GRMWD EQU >9C00 GROM/GRAM write data
GRMWA EQU >9C02 GROM/GRAM write address
GRMRD EQU >9800 GROM/GRAM read data
GRMRA EQU >9802 GROM/GRAM read address
DATA >AA01 VALIDATES THIS TO BE A VALID CARTRIDGE HEADER
DATA 0
DATA 0
DATA CHAIN POINTER TO DATA CHAIN WHICH SHOWS THAT THERE ARE MENU
* SELECTIONS TO BE DISPLAYED AND MADE
DATA 0
DATA 0
CHAIN DATA LINKA POINTER TO NEXT DATA LINK
DATA P9 LABEL POINTS TO BRANCH TO PROGRAM. NOTE THAT THE BOTTOM
* PROGRAM ON THE MENU DISPLAY IS PLACED FIRST AND THAT
* THEY THEN WORK UPWARD.
BYTE >04 NUMBER OF CHARACTERS TO BE DISPLAYED IN THE MENU LIST
TEXT 'EXIT' TITLE TO BE DISPLAYED IN THE MENU
P9 B @PROG9 BRANCH TO PROGRAM 9
LINKA DATA LINKB POINTER TO NEXT DATA LINK
DATA P8 POINTER TO PROGRAM BRANCH
BYTE >15 NUMBER OF CHARACTERS TO DISPLAY IN MENU LISTING
TEXT 'WIPE CARTRIDGE MEMORY' PROGRAM TITLE FOR MENU
P8 B @PROG8 BRANCH TO PROGRAM 8
LINKB DATA LINKC POINTER TO NEXT DATA LINK
DATA P7 POINTER TO PROGRAM BRANCH
BYTE >09 NUMBER OF CHARACTERS TO DISPLAY IN MENU LISTING
TEXT 'PROGRAM 7' TITLE TO BE DISPLAYED IN MENU
P7 B @PROG7 BRANCH TO PROGRAM 7
LINKC DATA LINKD POINTER TO NEXT DATA LINK
DATA P6 POINTER TO PROGRAM BRANCH
TEXT 'PROGRAM 6' TITLE TO BE DISPLAYED IN MENU
P6 B @PROG6 BRANCH TO PROGRAM 6
LINKD DATA LINKE POINTER TO NEXT DATA LINK
DATA P5 POINTER TO PROGRAM BRANCH
TEXT 'PROGRAM 5' TITLE TO BE DISPLAYED IN MENU
P5 B @PROG5 BRANCH TO PROGRAM 5
LINKE DATA LINKF POINTER TO NEXT DATA LINK
DATA P4 POINTER TO PROGRAM BRANCH
TEXT 'PROGRAM 4' TITLE TO BE DISPLAYED IN MENU
P4 B @PROG4 BRANCH TO PROGRAM 4
LINKF DATA 0 NO MORE PROGRAMS IN THE CHAIN!
DATA P3 POINTER TO PROGRAM BRANCH
TEXT 'PROGRAM 3' TITLE TO BE DISPLAYED IN MENU
P3 B @PROG3 BRANCH TO PROGRAM 3
WS BSS 32 WORKSPACE REGISTERS FOR MY PROGRAMS
SVGPRT DATA 0 Save GPL return address
SAVCRU DATA 0 CRU address of peripheral
SAVENT DATA 0 Entry address of DSR
SAVLEN DATA 0 Save device name length
SAVPAB DATA 0 Ptr into device name in PAB
SAVVER DATA 0 Version number of DSR
GRMSAV DATA 0 USED BY THE PREGPL AND GPLLNK ROUTINES
NAMBUF DATA 0,0,0,0
*** General utility workspace registers (Overlaps next WS)
UTILWS DATA 0,0
BYTE 0
R2LB BYTE 0
*** DSR link routine workspace registers (Overlaps prev. WS)
DLNKWS DATA 0,0,0,0,0
TYPE DATA 0,0,0,0,0,0,0,0,0,0,0
C100 DATA 100
H20 BYTE >20
EVEN
H2000 DATA >2000
DECMAL TEXT '.'
HAA BYTE >AA
CL BYTE >00 BYTE USED TO CLEAR @STATUS
EVEN
* Utility Vectors
GPLLNK DATA UTILWS,GLENTR Link to GROM routines
XMLLNK DATA UTILWS,XMLENT Link to ROM routines
KSCAN DATA UTILWS,KSENTR Keyboard scan
VSBW DATA UTILWS,VSBWEN VDP single byte write
VMBW DATA UTILWS,VMBWEN VDP multiple byte write
VSBR DATA UTILWS,VSBREN VDP single byte read
VMBR DATA UTILWS,VMBREN VDP multiple byte read
VWTR DATA UTILWS,VWTREN VDP write to register
DSRLNK DATA DLNKWS,DLENTR Link to device service routine
* PRE-GPLLNK ROUTINE: THIS INITIALLIZES A POINTER USED BY THE
* GPLLNK ROUTINE. IF YOU INTEND ON USING GPLLNK IN YOUR PROGRAM,
* MAKE SURE YOU INCLUDE A "BL @PREGPL" STATEMENT SOMETIME BEFORE
* INVOKING GPLLNK. (ONLY NEEDS TO BE DONE ONCE.) THIS CODE WAS
* TAKEN WITH PERMISSION FROM PAUL CHARLTON'S FAST-TERM SOURCE CODE
* AND IS ALSO CONSIDERED BY THE AUTHOR TO BE PUBLIC DOMAIN.
PREGPL CLR R0 START AT THE BEGINNING
LI R8,>0F00 R8h=GROM XMLLNK op-code
LI R9,>F000 R9h=acceptable XMLLNK parameter
AGAIN MOVB R0,@GRMWA get GROM byte
SWPB R0
MOVB R0,@GRMWA
SWPB R0
MOVB @GRMRD,R1
NOP
AGAIN1 CB R1,R8 is it XMLLNK op-code?
JEQ FNDLNK yes, check its parameter
INC R0 no,
JNO AGAIN check next byte
BLWP @>0000 return to system monitor
FNDLNK INC R0 found XMLLNK op-code
MOVB @GRMRD,R1 get next byte
CB R1,R9 is it the right XML vector?
JNE AGAIN1 no - jump back to see if current byte is opcode too
DEC R0 found whole XMLLNK call
MOV R0,@GRMSAV put address where GPLLNK can find it
RT
* LINK TO SYSTEM XML UTILITIES
XMLENT MOV *R14+,@GPLWS+2 Get argument
LWPI GPLWS Select GPL workspace
MOV R11,@UTILWS+22 Save GPL return address
MOV R1,R2 Make a copy of argument
CI R1,>8000 Direct address in ALC?
JH XML30 We have the address
SRL R1,12
SLA R1,1
SLA R2,4
SRL R2,11
A @XMLTAB(R1),R2
MOV *R2,R2
XML30 BL *R2
LWPI UTILWS GET BACK TO RIGHT WS
MOV R11,@GPLWS+22 Restore GPL return address
RTWP
*** Link to GPL utilities
* THIS GPLLNK CODE WAS TAKEN WITH PERMISSION FROM PAUL CHARLTON'S
* FAST-TERM SOURCE CODE AND IS CONSIDERED BY THE AUTHOR TO BE PUBLIC
* DOMAIN. BEFORE YOU INVOKE GPLLNK IN YOUR PROGRAM ("BLWP @GPLLNK"),
* BE SURE YOU INCLUDE A "BL @PREGPL" IN YOUR PROGRAM TO ESTABLISH AN
* ADDRESS WHICH THE GPLLNK ROUTINE USES.
GLENTR MOVB @SUBSTK,R1 Fetch GPL subroutine stack pointer
SRL R1,8 Make it an index
AI R1,>8302
MOV @GRMSAV,*R1 Push XML address for return
SWPB R1
MOVB R1,@SUBSTK adjust stack pointer
MOVB *R14+,@GRMWA Set up address to call
NOP
MOVB *R14+,@GRMWA and second byte, adjusting return
NOP
LI R0,RTFGPL
MOV R0,@PAD
LWPI GPLWS
B @>006A
*** Return to assembly language from GPL
RTFGPL LWPI UTILWS Select utility workspace
RTWP Return to calling AL routine
* KEYBOARD SCAN
KSENTR LWPI GPLWS
BL @SCNKEY
LWPI UTILWS
RTWP
* VDP UTILITIES
** VDP single byte write
VSBWEN BL @WVDPWA Write out address
MOVB @2(R13),@VDPWD Write data
RTWP Return to calling program
** VDP multiple byte write
VMBWEN BL @WVDPWA Write out address
VWTMOR MOVB *R1+,@VDPWD Write a byte
DEC R2 Decrement byte count
JNE VWTMOR More to write?
RTWP Return to calling Program
** VDP single byte read
VSBREN BL @WVDPRA Write out address
MOVB @VDPRD,@2(R13) Read data
** VDP multiple byte read
VMBREN BL @WVDPRA Write out address
VRDMOR MOVB @VDPRD,*R1+ Read a byte
JNE VRDMOR More to read?
** VDP write to register
VWTREN MOV *R13,R1 Get register number and value
MOVB @1(R13),@VDPWA Write out value
ORI R1,>8000 Set for register write
MOVB R1,@VDPWA Write out register number
** Set up to write to VDP
WVDPWA LI R1,>4000
JMP WVDPAD
** Set up to read VDP
WVDPRA CLR R1
** Write VDP address
WVDPAD MOV *R13,R2 Get VDP address
MOVB @R2LB,@VDPWA Write low byte of address
SOC R1,R2 Properly adjust VDP write bit
MOVB R2,@VDPWA Write high byte of address
MOV @2(R13),R1 Get CPU RAM address
MOV @4(R13),R2 Get byte count
RT Return to calling routine
* CIF - Convert integer to floating *
CIF LI R4,FAC Will convert into the FAC
MOV *R4,R0 Get integer into register
MOV R4,R6 Copy ptr to FAC to clear it
CLR *R6+ Clear FAC,FAC+1
CLR *R6+ in case had a string in FAC
MOV R0,R5 is integer equal to zero?
JEQ CIFRT yes - zero result and return
ABS R0 get ABS value of arg
LI R3,>40 get exponent bias
CLR *R6+ clear words in result that
CLR *R6 might not get a value
CI R0,100 is integer < 100?
JL CIF02 yes-just put in 1st fraction
* part
CI R0,10000 no-is arg < 100,2?
JL CIF01 yes-just 1 division necessary
* no - 2 divisions are necessary
INC R3 add 1 to exponent for 1st div
MOV R0,R1 put # in low order word for
* the divide
CLR R0 clear high order word for the
* divide
DIV @C100,R0 divide by the radix
MOVB @R1LB,@3(R4) move the radix digit in
CIF01
INC R3 add 1 to exponent for divide
MOV R0,R1 put in low order for divide
CLR R0 clear high order for divide
MOVB @R1LB,@2(R4) put next radix digit in
CIF02
MOVB @R0LB,@1(R4) put highest order radix digit
* in
MOVB @R3LB,*R4 put exponent in
INV R5 is result positive?
JLT CIFRT yes - sign is correct
NEG *R4 no - make it negative
CIFRT RT
*** Link to device service routine
DLENTR MOV *R14+,R5 Fetch program type for link
SZCB @H20,R15 Reset equal bit
MOV @SCNAME,R0 Fetch pointer into PAB
MOV R0,R9 Save pointer
AI R9,-8 Adjust pointer to flag byte
BLWP @VSBR Read device name length
MOVB R1,R3 Store it elsewhere
SRL R3,8 Make it a word value
SETO R4 Initialize a counter
LI R2,NAMBUF Point to NAMBUF
LNK$LP INC R0 Point to next char of name
INC R4 Increment character counter
C R4,R3 End of name?
JEQ LNK$LN Yes
BLWP @VSBR Read current character
MOVB R1,*R2+ Move it to NAMBUF
CB R1,@DECMAL Is it a decimal point?
JNE LNK$LP No
LNK$LN MOV R4,R4 Is name length zero?
JEQ LNKERR Yes, error
CI R4,7 Is name length > 7?
JGT LNKERR Yes, error
CLR @CRULST
MOV R4,@SCLEN-1 Store name length for search
MOV R4,@SAVLEN Save device name length
INC R4 Adjust it
A R4,@SCNAME Point to position after name
MOV @SCNAME,@SAVPAB Save pointer into device name
*** Search ROM CROM GROM for DSR
SROM LWPI GPLWS Use GPL workspace to search
CLR R1 Version found of DSR etc.
LI R12,>0F00 Start over again
NOROM MOV R12,R12 Anything to turn off
JEQ NOOFF No
SBZ 0 Yes, turn it off
NOOFF AI R12,>0100 Next ROM'S turn on
CLR @CRULST Clear in case we're finished
CI R12,>2000 At the end
JEQ NODSR No more ROMs to turn on
MOV R12,@CRULST Save address of next CRU
SBO 0 Turn on ROM
LI R2,>4000 Start at beginning
CB *R2,@HAA Is it a valid ROM?
JNE NOROM No
A @TYPE,R2 Go to first pointer
JMP SGO2
SGO MOV @SADDR,R2 Continue where we left off
SBO 0 Turn ROM back on
SGO2 MOV *R2,R2 Is address a zero
JEQ NOROM Yes, no program to look at
MOV R2,@SADDR Remember where we go next
INCT R2 Go to entry point
MOV *R2+,R9 Get entry address
*** See if name matches
MOVB @SCLEN,R5 Get length as counter
JEQ NAME2 Zero length, don't do match
CB R5,*R2+ Does length match?
JNE SGO No
SRL R5,8 Move to right place
LI R6,NAMBUF Point to NAMBUF
NAME1 CB *R6+,*R2+ Is character correct?
JNE SGO No
DEC R5 More to look at?
JNE NAME1 Yes
NAME2 INC R1 Next version found
MOV R1,@SAVVER Save version number
MOV R9,@SAVENT Save entry address
MOV R12,@SAVCRU Save CRU address
BL *R9 Match, call subroutine
JMP SGO Not right version
SBZ 0 Turn off ROM
LWPI DLNKWS Select DSRLNK workspace
MOV R9,R0 Point to flag byte in PAB
BLWP @VSBR Read flag byte
SRL R1,13 Just want the error flags
JNE IOERR Error!
RTWP
*** Error handling
NODSR LWPI DLNKWS Select DSRLNK workspace
LNKERR CLR R1 Clear the error flags
IOERR SWPB R1
MOVB R1,*R13 Store error flags in calling R0
SOCB @H20,R15 Indicate an error occured
RTWP Return to caller
****USER-AVAILABLE PROGRAM SPACE***(WITH 2 OF MY UTILITIES TOSSED IN)
PROG8 LWPI WS PROG8 IS MY VERSION OF A UTILITY TO WIPE THE 8K RAM
* SPACE AND PLACE ZEROS AT >6000->7FFF.
WIPED DATA >02E0,>A000,>0201,>6000 THIS IS THE ACTUAL OBJECT CODE FOR A
DATA >0202,>2000,>0203,>0000 PROGRAM (AT AORG >A000) TO PLACE ZEROS
DATA >CC43,>0642,>16FD,>04E0 AT ADDRESSES >6000 TO >7FFF AND THEN
DATA >837C,>02E0,>83E0,>0420 BRANCH TO THE POWER UP ROUTINE. IF YOU
DATA >0000 DON'T HAVE 32K, I GUESS IT WON'T WORK.
LI R1,WIPED LOAD STARTING ADDRESS OF ROUTINE IN R1
LI R3,>A020 ADDRESS TO BE WRITTEN TO
LI R5,>11 NUMBER OF WORDS TO MOVE
LOOPF MOV *R1+,*R3+ WRITE A WORD
DEC R5 SUBTRACT A WORD FROM THE COUNTER
JNE LOOPF ARE WE DONE? IF NOT, KEEP ON GOING
BLWP @XMLLNK I KNOW, I KNOW... THIS WOULD BE MORE SIMPLY DONE BY A
DATA >A020 "B @>A020" BUT I WANTED TO DEMONSTRATE THAT THE XMLLNK
* ROUTINE WORKS. THIS EXECUTES THE WIPE OF CARTRIDGE RAM.
PROG9 CLR @STATUS PROG9 IS MY VERSION OF "OOPS, I DIDN'T MEAN TO BE HERE"
LWPI GPLWS GO TO GPL
BLWP @>0000 AND START OVER
* 1 2 3 4 5 6 7 8
*2345678901234567890123456789012345678901234567890123456789012345678901234567890
PROG3 B @PROG9 FOR YOUR PROGRAM, REPLACE THE "PROG3 B @" PHRASE
* WITH "COPY DSKn.PROGRAMx" (NOTHING IN LABEL FIELD)
* WHERE "PROGRAMx" HAS "PROG3" AS ITS STARTING POINT.
PROG4 B @PROG9 DITTO FOR THE REST, USING DIFFERENT "PROGx" AS START.
PROG5 B @PROG9 " " " " " " " " "
PROG6 B @PROG9 " " " " " " " " "
PROG7 B @PROG9 " " " " " " " " "
END
  • 3 weeks later...
Does anyone have a code snippet for the equivalent of CALL FILES from assembler? I understand from the tech pages you need to call a subprogram >16 in the disk controller ROM.
Prior to calling DSRLNK with option 0Ah, you must set up a 2-byte PAB in VRAM with 0116h, put its address in PAD RAM at 8356h and store the number of simultaneous files you want to allow in PAD RAM at byte 834Ch. Off the top of my head, something like the following would probably work:
PAB    EQU  >1000           VRAM address of 2-byte Peripheral Access Block
NFILES DATA >0300           number of simultaneous files in left byte
PDATA  DATA >0116           DSR subprogram to run (FILES)
FILES  LI   R0,PAB
       LI   R1,PDATA
       LI   R2,2
       BLWP @VMBW           copy 2 bytes from PDATA (RAM) to PAB (VRAM)
       MOV  R0,@>8356       point to subroutine in DSR
       MOVB @NFILES,@>834C  #files argument for subroutine 016h
       BLWP @DSRLNK         call DSR with subprogram option
       DATA >0A
...lee
  • 5 months later...
I am currently working on a project that requires the adding of two 16 bit numbers together, and I have a couple of questions:
  • Does the 32 bit result get stored in 2 adjacent memory locations? What if I am using registers and I add say R1 to R2, is the result then in R2 and R3 (a la MPY or DIV)?
  • How do I add two 32 bit numbers together using registers?
It's in these situations that I miss the ease of use of a high level language :?
Sixteen-bit addition (A) does not give a 32-bit result. You must check the overflow and carry bits to manage results that exceed a 16-bit representation.
For 32-bit addition, you would need a short routine that first added the right 16 bits, then the left 16 bits, while handling the overflow and carry bits for each addition to get the correct result. I'm sure someone here has done it. In fact, the floating point routines do a pretty good job with 8 bytes and a radix of 100. I can post the routine if that would offer any insight—even though it is not binary.
...lee
Edited by Lee Stewart
Thanks for the pointers. I do now understand the concept and I can come up with the routine, but I found that I could get away with reducing the magnitude of the numbers by dividing them by 10 and thus keeping everything within 16 bits. This should not affect my application noticeably since I will be doing magnitude comparisons anyway. Besides, speed of computation is critical in my project and I want to minimize code gymnastics as much as possible.
