Fabrizio Caruso Posted November 9, 2023 Share Posted November 9, 2023 A totally different issue I had to patch is in Shuriken: https://github.com/Fabrizio-Caruso/CROSS-LIB/blob/master/src/games/shuriken/main.c#L804 where I had to patch the code with this: #if defined(BUGGY_GCC_TI99) uint16_t aux; aux = x_size*y_size; remaining_diamonds+=aux; #else remaining_diamonds +=x_size*y_size;; #endif because otherwise remaining_diamonds would be set to zero at the end of a loop invoking the above snippet. You can reproduce it in Cross-Lib by removing the #if defined(...) directive and running: xl clean && xl rebuild shuriken ti99 1 Quote Link to comment Share on other sites More sharing options...
Fabrizio Caruso Posted November 9, 2023 Share Posted November 9, 2023 I also have two more (probably similar) old issues that I may already posted long ago in this thread: These issues are about an error by 1 in a operation involving unsigned chars: in the Chase game (built with `xl clean && xl rebuild chase ti99`) https://github.com/Fabrizio-Caruso/CROSS-LIB/blob/master/src/games/chase/split_files/main.c#L595 and in the Shoot game (built with `xl clean && xl rebuild shoot ti99`) https://github.com/Fabrizio-Caruso/CROSS-LIB/blob/master/src/games/shoot/split_files/main.c#L694 Quote Link to comment Share on other sites More sharing options...
+MarkB Posted November 9, 2023 Share Posted November 9, 2023 Thanks @Fabrizio Caruso these are all related to ops on uint8_t values. As mentioned, I think the machine description code for handling bytes is a bit suspect. For example the test for zero for byte instructions md is: (define_insn "tstqi" [(set (cc0) (match_operand:QI 0 "nonimmediate_operand" "rR,Q"))] "" { output_asm_insn("jeq 0", operands); /* +0: No-op instruction with zero at +1 */ output_asm_insn("cb %0, @$-1", operands); /* +2: Compare value against the zero at +1 */ return(""); } [(set_attr "length" "4,6")]) which creates an assumption that the instruction immediately preceding the CB contains a zero as the last byte which I don't think is valid when the optimiser can remove or reorder instructions. Probably better just to use a MOVB %0,%0 to compare a memory location to zero and a MOV if the operand is a register. I just need to ensure that the compiler is zeroing the top byte of a register when doing byte ops with regs. If not, I'll make a copy to a scratch reg and do ANDI >00FF first. I'll do some more testing. We should focus on getting it functional first and fast second. 1 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted November 9, 2023 Share Posted November 9, 2023 1 hour ago, khanivore said: I just need to ensure that the compiler is zeroing the top byte of a register when doing byte ops with regs. If not, I'll make a copy to a scratch reg and do ANDI >00FF first. I'll do some more testing. We should focus on getting it functional first and fast second. Not sure if this is relevant but over on the Forth compiler side we have resorted to using SRL R?,8 after fetching a byte from memory with MOVB, to get the byte to the other side and clear the other bits in one instruction. 2 Quote Link to comment Share on other sites More sharing options...
+MarkB Posted November 9, 2023 Share Posted November 9, 2023 24 minutes ago, TheBF said: Not sure if this is relevant but over on the Forth compiler side we have resorted to using SRL R?,8 after fetching a byte from memory with MOVB, to get the byte to the other side and clear the other bits in one instruction. Yep, the "zero_extendqihi2" (extend byte to int) does exactly that. The compiler knows we are big-endian so it understands byte moves result in a high byte in a 16-bit reg. It seems intermediate ops on byte values are upgraded to 16-bit so just a MOV as compare will probably be ok for regs. But "tstqi" is just a compare to zero. The MOV works unoptimised but not when I apply -O2 so I just need to check the syntax of the machine def. 1 Quote Link to comment Share on other sites More sharing options...
+FarmerPotato Posted November 9, 2023 Share Posted November 9, 2023 4 hours ago, khanivore said: I just need to ensure that the compiler is zeroing the top byte of a register when doing byte ops with regs. If not, I'll make a copy to a scratch reg and do ANDI >00FF first. Size/speed trade off there: SB R0,R0 vs ANDI R0,>00FF Reading IOP is I think faster but takes 2 words. 2 Quote Link to comment Share on other sites More sharing options...
+MarkB Posted November 9, 2023 Share Posted November 9, 2023 3 hours ago, khanivore said: But "tstqi" is just a compare to zero. The MOV works unoptimised but not when I apply -O2 so I just need to check the syntax of the machine def. Debugging this, but have to sign off now. For some reason that I haven't bottomed out on yet, gcc barfs on the %0 because it thinks the parameter should be a constant, but it's a register (!?). Quick fix is just to delete the machine definition of tstqi (line 174 in gcc-4.4.0/gcc/config/tms9900/tms9900.md) which forces the compiler to do a comparison which works. Quote Link to comment Share on other sites More sharing options...
Fabrizio Caruso Posted November 9, 2023 Share Posted November 9, 2023 @khanivore I am trying to re-install the compiler on a new PC under Cygwin 64-bit what do I need to be able to use the install.sh script? wget is necessary It now fails with an error on patch. I suppose that is also necessary. Any other dependencies? Quote Link to comment Share on other sites More sharing options...
+MarkB Posted November 9, 2023 Share Posted November 9, 2023 3 minutes ago, Fabrizio Caruso said: @khanivore I am trying to re-install the compiler on a new PC under Cygwin 64-bit what do I need to be able to use the install.sh script? wget is necessary It now fails with an error on patch. I suppose that is also necessary. Any other dependencies? Can you pm me the error? Wget or curl is needed and couple of other libraries Quote Link to comment Share on other sites More sharing options...
Fabrizio Caruso Posted November 9, 2023 Share Posted November 9, 2023 @khanivore configure: error: Building GCC requires GMP 4.1+ and MPFR 2.3.2+. Try the --with-gmp and/or --with-mpfr options to specify their locations. Copies of these libraries' source code can be found at their respective hosting sites as well as at ftp://gcc.gnu.org/pub/gcc/infrastructure/. See also http://gcc.gnu.org/install/prerequisites.html for additional info. If you obtained GMP and/or MPFR from a vendor distribution package, make sure that you have installed both the libraries and the header files. They may be located in separate packages. === Failed to configure GCC === Quote Link to comment Share on other sites More sharing options...
+MarkB Posted November 9, 2023 Share Posted November 9, 2023 11 minutes ago, Fabrizio Caruso said: @khanivore configure: error: Building GCC requires GMP 4.1+ and MPFR 2.3.2+. Try the --with-gmp and/or --with-mpfr options to specify their locations. I'm afraid I don't know how to install those libs in cygwin. In debian/ubuntu it's just "apt install" but I don't think apt is part of cygwin. You built gcc before on cygwin though didn't you? That part of the build hasn't changed. 1 Quote Link to comment Share on other sites More sharing options...
lucien2 Posted November 9, 2023 Share Posted November 9, 2023 I wrote the needed Cygwin packages for myself 9 years ago: Category "Devel" - gcc-core - libiconv - make - patchutils Category "Libs" - libgmp-devel - libmpfr-devel Category "Interpreters" - m4 3 Quote Link to comment Share on other sites More sharing options...
Fabrizio Caruso Posted November 9, 2023 Share Posted November 9, 2023 @lucien2 Thanks! @khanivore You can install all packages with the very same original installer used to install Cygwin. The problem one may have is that the name of the packages could change. I have been able to install all the packages listed by @lucien2 through the setup installer. It is now building... I have read about apt-cyg that may work similarly to apt-get but I have no experience with it. It may be useful if the script could take care of all the dependencies also under Cygwin. Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted November 10, 2023 Share Posted November 10, 2023 curious why cygwin ? older windows? since there's the free ubuntu linux in windows 10/11 now.. Quote Link to comment Share on other sites More sharing options...
Fabrizio Caruso Posted November 10, 2023 Share Posted November 10, 2023 (edited) @arcadeshopper sure, for two reasons: 1. Why not? as Cygwin and MSYS2 are POSIX-like environments and I want to support all POSIX environments including non-Linux systems such as Free BSD, MacOS, Windows/Cygwin, Windows/MSYS2, etc. and not just Linux. I also support Windows Subsystem for Linux and of course Ubuntu. Whoever decides to try Cross-Lib won't be forced to switch to Linux. 2. I primarily develop under Windows/Cygwin because Cross-Lib is about 200 different machines some of which are very rare and a good and dev-friendly emulator is only available under Windows. Wine is not always a practical solution in these cases. Same issue with some tools such as for example handle disk/tape/cartridge images. For these two reasons I need the emulator working also under Cygwin. You can try Cross-Lib under Ubuntu and it should just work. Edited November 10, 2023 by Fabrizio Caruso Quote Link to comment Share on other sites More sharing options...
Fabrizio Caruso Posted November 10, 2023 Share Posted November 10, 2023 I tried to install again the compiler under Cygwin 64-bit together with libti99, and after a few attempts I manage to install both. Nevertheless it does not work and it requires more work 😞 When I try to build one of my games this is what I get: /tmp/ccwfWD73.s: Assembler messages: /tmp/ccwfWD73.s:1: Error: no such instruction: `pseg' /tmp/ccwfWD73.s:2: Error: no such instruction: `even' /tmp/ccwfWD73.s:4: Error: no such instruction: `def loc' /tmp/ccwfWD73.s:5: Error: no such instruction: `loc' /tmp/ccwfWD73.s:6: Error: no such instruction: `srl r1,8' /tmp/ccwfWD73.s:7: Error: no such instruction: `a @gImage,r1' /tmp/ccwfWD73.s:8: Error: no such instruction: `srl r2,>3' /tmp/ccwfWD73.s:9: Error: no such instruction: `andi r2,>FFE0' /tmp/ccwfWD73.s:10: Error: no such instruction: `a r2,r1' /tmp/ccwfWD73.s:11: Error: no such instruction: `b *r11' /tmp/ccwfWD73.s:12: Warning: .size pseudo-op used outside of .def/.endef: ignored. /tmp/ccwfWD73.s:12: Error: junk at end of line, first unrecognized character is `l' /tmp/ccwfWD73.s:14: Error: no such instruction: `ref gImage' make: *** [Makefile_common:2719: cross_lib/display/display_macros.o] Error 1 Quote Link to comment Share on other sites More sharing options...
Fabrizio Caruso Posted November 10, 2023 Share Posted November 10, 2023 Maybe the script does not build Assembler correctly for Cygwin 64-bit. I gave it all permissions. $ ls -l ./tms9900-as -rwxrwxrwx 1 User Aucun 5.7M Nov 10 07:33 ./tms9900-as* If I try to run the Assembler I get this: $ ./tms9900-as -bash: ./tms9900-as: cannot execute binary file: Exec format error Quote Link to comment Share on other sites More sharing options...
+mizapf Posted November 10, 2023 Share Posted November 10, 2023 Exec format error usually indicates that the architecture is wrong, or - particularly with cygwin - that you built for native Linux but try to run it in Cygwin. Ask Google. Can you try a "file tms9900-as"? Quote Link to comment Share on other sites More sharing options...
Fabrizio Caruso Posted November 10, 2023 Share Posted November 10, 2023 (edited) @mizapf $ file /opt/gcc4ti/bin/tms9900-as /opt/gcc4ti/bin/tms9900-as: MS-DOS executable This Assembler was somehow working yesterday because I managed to build libti99. So I don't know what happened... I am now trying to rebuild gcc for ti but the script won't rebuild it... Removing the target directory is not enough. I probably need to remove some temporary files. I hope all of this were simple... Edited November 10, 2023 by Fabrizio Caruso Quote Link to comment Share on other sites More sharing options...
Fabrizio Caruso Posted November 10, 2023 Share Posted November 10, 2023 After re-installing gcc 4 ti I now get: $ file /opt/gcc4ti/tms9900/bin/as.exe /opt/gcc4ti/tms9900/bin/as.exe: PE32+ executable (console) x86-64, for MS Windows, 19 sections which is better... I don't understand what went wrong... Maybe I mixed two different cygwin versions Quote Link to comment Share on other sites More sharing options...
Fabrizio Caruso Posted November 10, 2023 Share Posted November 10, 2023 I managed to get both gcc for ti and libti99 to work. I can build nearly all my games but none of them works now. I don't know what is wrong with my build-chain now... When I run them in Classic99 I get a black screen and a beeping sound. Quote Link to comment Share on other sites More sharing options...
Fabrizio Caruso Posted November 10, 2023 Share Posted November 10, 2023 (edited) After re-install gcc for ti, libti99 and having all ea5 tools set-up my new set-up under Cygwin 64-bit builds corrupted files. Could someone please help me figure out what is wrong? XBOMBER1 XBOMBER2 Edited November 10, 2023 by Fabrizio Caruso Quote Link to comment Share on other sites More sharing options...
Fabrizio Caruso Posted November 10, 2023 Share Posted November 10, 2023 The tests built by libti99 with my gcc for ti crash under classic99. TESTLIC TESTLID TESTLIB TESTLIB1 TESTLIB2 TESTLIB3 Quote Link to comment Share on other sites More sharing options...
+MarkB Posted November 10, 2023 Share Posted November 10, 2023 7 minutes ago, Fabrizio Caruso said: The tests built by libti99 with my gcc for ti crash under classic99. Ok sorry to hear that. Removing the byte compare may have broken something else. Can you hold off for now and I'll take a look when I get back from hols in a week? Quote Link to comment Share on other sites More sharing options...
Fabrizio Caruso Posted November 10, 2023 Share Posted November 10, 2023 The different between the good (right) and the bad (left) is just a couple of bytes (in my case here start around $0000E0): Quote Link to comment Share on other sites More sharing options...
