Fabrizio Caruso Posted Wednesday at 12:12 PM Share Posted Wednesday at 12:12 PM @MarkB I can see the issue in the game but if I isolate the code I showed above, I cannot see the issue. So the problem is somewhere else. It is going to be harder to investigate. In the game Horde, you start with number_of_arrows_per_shoot=1 and through several power-ups you get number_of_arrows_per_shoot=2 and the issue appears (arrows are not placed where they should). On the other hand the snippet of code above is compiled correctly and if I start the game with number_of_arrows_per_shoot=2, the issue is no longer visible. So maybe a register or a carry bit gets dirty somehow... It is hard for me to isolate it. Quote Link to comment Share on other sites More sharing options...
Willsy Posted Wednesday at 03:19 PM Share Posted Wednesday at 03:19 PM Just out of curiosity, what happens if you do: if((number_of_arrows_per_shot == 2) && i) { offset = (i - 2) * (bow_x & 1); } I'm just wondering if it's being compiled as i-(2*(bow_x & 1)) Quote Link to comment Share on other sites More sharing options...
Fabrizio Caruso Posted Wednesday at 04:54 PM Share Posted Wednesday at 04:54 PM The problem with the Horde (and Stinger) game is very weird. One arrow is position at a wrong position by 1 byte. This problem does not occur if you print the corresponding variable (see _XL_PRINTD command in the code below). Maybe something like a carry bit was not cleared and it is added. @Willsy, that code taken alone is correctly compiled. Something else breaks it. Maybe a peep-hole rule. How can I disable all peep-hole rules and optimizations ? Quote Link to comment Share on other sites More sharing options...
Fabrizio Caruso Posted Wednesday at 05:32 PM Share Posted Wednesday at 05:32 PM Using -O1 instead of -O2 fixes the issue with the wrongly places arrows in Horde but triggers a worse bug that makes it impossible to complete the version level (last zombie does not movie and cannot die). So I suppose I should use -O2. Is this what everyone is supposed to do? -O0 won't compile and produce errors about libti99. 1 Quote Link to comment Share on other sites More sharing options...
Fabrizio Caruso Posted Wednesday at 06:50 PM Share Posted Wednesday at 06:50 PM By the way, which thread should I use to discuss the new bugs? Quote Link to comment Share on other sites More sharing options...
+MarkB Posted Thursday at 06:40 AM Share Posted Thursday at 06:40 AM 11 hours ago, Fabrizio Caruso said: By the way, which thread should I use to discuss the new bugs? Let's use the new thread Quote Link to comment Share on other sites More sharing options...
+MarkB Posted Thursday at 06:42 AM Share Posted Thursday at 06:42 AM 13 hours ago, Fabrizio Caruso said: Using -O1 instead of -O2 fixes the issue with the wrongly places arrows in Horde but triggers a worse bug that makes it impossible to complete the version level (last zombie does not movie and cannot die). So I suppose I should use -O2. Is this what everyone is supposed to do? -O0 won't compile and produce errors about libti99. Both should work. Traditionally people used -O2 or -Os because -O0 was broken but also of course because they want want to squeeze as much performance as possible from the CPU. 1 Quote Link to comment Share on other sites More sharing options...
Fabrizio Caruso Posted Thursday at 04:04 PM Share Posted Thursday at 04:04 PM I have opened several issues for the new bugs in https://github.com/mburkley/tms9900-gcc/ I may open more issues because I have more new bugs in some other games. In particular I have opened one where 28 - 0 = 27 with a minimal example with source code, map file and EA5 binary: https://github.com/mburkley/tms9900-gcc/issues/62 Quote Link to comment Share on other sites More sharing options...
Fabrizio Caruso Posted Friday at 07:39 AM Share Posted Friday at 07:39 AM I can also confirm that Shoot game is miscompiled 😞 I can compiled Shoot now (by disabling some optional minor content). The source code is here: https://github.com/Fabrizio-Caruso/CROSS-LIB/tree/master/src/games/shoot So all my 9 games except the smallest 2 (Bomber, Trex) are miscompiled beyond repair in several places. For the moment the only way to get all my 9 games working is to build a version of GCC for the TI before the recent changes. For level=2 the function: ``` uint8_t innerVerticalWallLevel(void) { return ((level&7)==1) || ((level&7)==4) || ((level&7)==0); } ``` returns 1. This is fixed/triggered in unpredictable ways by commenting out totally unrelated functions as if the result depended on the binary size and/or the position in memory of the function and/or the program counter and/or something that has changed elsewhere. It can be reproduced and it is taking me very long to construct a minimal example for this other new bug because of the size of the game. For a minimal example please look at my **previous post** about 28 - 0 = 27. Quote Link to comment Share on other sites More sharing options...
TheMole Posted Friday at 11:39 AM Share Posted Friday at 11:39 AM (edited) @Fabrizio Caruso, just to be sure... Are you compiling libti99.a itself with the same version of gcc? If I recall correctly, Mark's changes produce binaries that are not compatible with binaries built by the old Insomnia version. *edit* nevermind, just saw the other thread... Edited Friday at 02:40 PM by TheMole Quote Link to comment Share on other sites More sharing options...
Fabrizio Caruso Posted Friday at 11:56 AM Share Posted Friday at 11:56 AM (edited) @TheMole Yes, I have recompiled both. Could you and/or someone else please double check these issues by just trying out the latest compiler with my short example? One short example that produces one of the many bugs is here: https://github.com/mburkley/tms9900-gcc/issues/62 Edited Friday at 12:48 PM by Fabrizio Caruso Quote Link to comment Share on other sites More sharing options...
