+arcadeshopper Posted August 12, 2014 Share Posted August 12, 2014 are there simple instructions for installing this? Quote Link to comment https://forums.atariage.com/topic/164295-gcc-for-the-ti/page/9/#findComment-3051628 Share on other sites More sharing options...
insomnia Posted August 19, 2014 Author Share Posted August 19, 2014 (edited) Hey everyone, I've been out of the loop for a while, but I'm making it a point to spend more time doing compiler stuff. First off, I've copied alll the build directions and latest patches to the first post in this thread. That should make it easier to find any changes or improvements. Also, I've added a script to automate the patch and build process in gcc-installer.tar.gz To use this, run the install.sh script and pass as an argument the directory. The script will download the unmodified files from gnu.org, patch, build, and copy the output files to the location specified. For example, after decompressing the archive, and running this script, tms9900-gcc and friends will be copied to /home/eric/tms9900/bin $ tar -xzf gcc-installer.tar.gz $ install.sh /home/eric/tms99900 Let me know if anyone sees any problems Edited August 19, 2014 by insomnia 4 Quote Link to comment https://forums.atariage.com/topic/164295-gcc-for-the-ti/page/9/#findComment-3056400 Share on other sites More sharing options...
TheMole Posted August 20, 2014 Share Posted August 20, 2014 (edited) Hey everyone, I've been out of the loop for a while, but I'm making it a point to spend more time doing compiler stuff. Welcome back. I just wanted to take the opportunity to thank you for the work you've done. I don't think I would've gotten back to programming the very first computer I've ever owned if it weren't for your gcc port. So thanks! Edited August 20, 2014 by TheMole 1 Quote Link to comment https://forums.atariage.com/topic/164295-gcc-for-the-ti/page/9/#findComment-3057465 Share on other sites More sharing options...
insomnia Posted August 20, 2014 Author Share Posted August 20, 2014 Wow, Thanks! I'm having fun working on this, but It's been amazing seeing all the projects that everyone else has made with these tools. I'm always so excited to see people be able to express their talent and creativity, and I'm proud to think I had some smalll part in helping to make that easier. Quote Link to comment https://forums.atariage.com/topic/164295-gcc-for-the-ti/page/9/#findComment-3057499 Share on other sites More sharing options...
RobertLM78 Posted August 20, 2014 Share Posted August 20, 2014 I never did get gcc working fully, even after watching Tursi's video . Quote Link to comment https://forums.atariage.com/topic/164295-gcc-for-the-ti/page/9/#findComment-3057542 Share on other sites More sharing options...
Asmusr Posted August 21, 2014 Share Posted August 21, 2014 Please, please please, could someone post a working Windows installation? Quote Link to comment https://forums.atariage.com/topic/164295-gcc-for-the-ti/page/9/#findComment-3057714 Share on other sites More sharing options...
+arcadeshopper Posted August 21, 2014 Share Posted August 21, 2014 Please, please please, could someone post a working Windows installation? Would a working vm with xubuntu do? you could run vmware player (free) Greg Quote Link to comment https://forums.atariage.com/topic/164295-gcc-for-the-ti/page/9/#findComment-3057724 Share on other sites More sharing options...
RobertLM78 Posted August 21, 2014 Share Posted August 21, 2014 (edited) You just need Cygwin. Here's Tursi's video. I think I was still missing some dependencies, and since I'm running Mint not Cygwin, I ran into trouble. Edited August 21, 2014 by RobertLM78 1 Quote Link to comment https://forums.atariage.com/topic/164295-gcc-for-the-ti/page/9/#findComment-3057728 Share on other sites More sharing options...
insomnia Posted October 10, 2014 Author Share Posted October 10, 2014 Well it's been a really long time, but here's another set of patches. I went through the comments posted since the last release and I think I fixed every issue mentioned here. To everyone who reported their problems, thank you. It's been incredibly helpfull. So here's what's new: Binutils ---------- Added support for numeric registers Correct handling of comments Added support for dwarf debugging information GCC ------- Changed order of jumps for less-than-or-equal tests to improve performance Fixed several integer type conversion bugs Corrected handling of variable shift by zero bits Fixed signed division Added support for dwarf debugging information For the assember, I wanted to make sure I was being as compatible as possible with Editor/Assembler. It should be able to compile anything that E/A can handle and produce identical output. The obvious defect here was with GAS being unable to handle the numeric registers typically seen in TI assembly (EX: mov 1,2). The other problem was in properly handling assembly comments. There were problems with ambiguous parsing when the "*" comment character was used. I was initially using a simple character search for this, but it turns out that a grammar parser was needed to intellegently determine what was code and what was comment. (For example: "ai r1, value * comment") Tricky, but that seems to be working great. There was more work needed in the compiler. The biggest problems here were yet more int-char type conversion failures (With any luck, we shouldn't see any more of these) and signed division gave nonsense results. Several comments were made about division, and much frustration was had. Sorry about that. The other big thing here is the new support for Dwarf2 debugging. For the longest time I wanted to be able to see mixed source output, with both the original source code and the resulting assembly on a line by line basis. Prior to this, knowing where an assembly instruction came from was a tedious and error-prone task for moderately complicated source code. Now it's much easier to identify inefficient algorithms, or debug tricky logic. (I suppose it would also help to be able to find compiler bugs. If there were any. Which there aren't.) The debug information can be used to view assembly at compile time or to view the source code of compiled programs. The other binutils programs (most importantly readelf and objdump) know how to work with these sections. The elf2cart and elf2ea5 programs I posted earlier will ignore these sections, so there's no problem doing development with debug on. I should mention that a lot of additional non-TI-compliant text will be added to the assembly file if debugging is used. This clutter could make it harder to read, and the file will only compile with GAS. Just something to be aware of if you are using an exotic build method. I've updated the first post with new attachments and the gcc installer has been updated to build this latest version. If anyone has problems or finds any bugs, please post them here. I love bug reports, keep 'em coming. As always, there are more details on my blog. 5 Quote Link to comment https://forums.atariage.com/topic/164295-gcc-for-the-ti/page/9/#findComment-3089458 Share on other sites More sharing options...
+Ksarul Posted October 11, 2014 Share Posted October 11, 2014 Thank you for the update! Quote Link to comment https://forums.atariage.com/topic/164295-gcc-for-the-ti/page/9/#findComment-3089606 Share on other sites More sharing options...
Willsy Posted October 11, 2014 Share Posted October 11, 2014 Yeah this is really cool! Quote Link to comment https://forums.atariage.com/topic/164295-gcc-for-the-ti/page/9/#findComment-3089744 Share on other sites More sharing options...
Tursi Posted October 12, 2014 Share Posted October 12, 2014 Fantastic!! Thank you so much! Quote Link to comment https://forums.atariage.com/topic/164295-gcc-for-the-ti/page/9/#findComment-3090189 Share on other sites More sharing options...
TheMole Posted October 12, 2014 Share Posted October 12, 2014 Excellent news, and good thing you mentioned your blog! I hadn't thought of visiting it again, and it's an interesting read. Quote Link to comment https://forums.atariage.com/topic/164295-gcc-for-the-ti/page/9/#findComment-3090340 Share on other sites More sharing options...
Asmusr Posted October 12, 2014 Share Posted October 12, 2014 I won't ask my usual question about whether anyone has a working installation for Windows they would like to share. Oops, I guess I asked it again... 1 Quote Link to comment https://forums.atariage.com/topic/164295-gcc-for-the-ti/page/9/#findComment-3090350 Share on other sites More sharing options...
TheMole Posted October 12, 2014 Share Posted October 12, 2014 I won't ask my usual question about whether anyone has a working installation for Windows they would like to share. Oops, I guess I asked it again... I know I promised you this a while back, but in the mean time I've gone completely Windows-less (work allowed me to upgrade to a Mac) so it's becoming less likely that I'll be able to help you with this. I know Tursi is a Windows/GCC user, so he might be able to help out. Just curious though, does the new install script that Insomnia provides not work for you? At least on Mac it seems to work pretty much flawlessly. Quote Link to comment https://forums.atariage.com/topic/164295-gcc-for-the-ti/page/9/#findComment-3090355 Share on other sites More sharing options...
Asmusr Posted October 12, 2014 Share Posted October 12, 2014 Just curious though, does the new install script that Insomnia provides not work for you? At least on Mac it seems to work pretty much flawlessly. No. Are they supposed to work on Windows? I guess I just have to try my luck with Tursi's video again. Last time I had to give up half way through. Quote Link to comment https://forums.atariage.com/topic/164295-gcc-for-the-ti/page/9/#findComment-3090366 Share on other sites More sharing options...
unhuman Posted October 12, 2014 Share Posted October 12, 2014 Yeah, if you're going to develop on Windows, you'll need Cygwin, for sure. Cygwin tends to screw up file permissions, so the first thing I always do is this: https://cygwin.com/cygwin-ug-net/using-filemodes.html The relevant change is: Open /etc/fstab and enter following line: none /cygdrive cygdrive binary,noacl,posix=0,user 0 0 Quote Link to comment https://forums.atariage.com/topic/164295-gcc-for-the-ti/page/9/#findComment-3090393 Share on other sites More sharing options...
Tursi Posted October 12, 2014 Share Posted October 12, 2014 ooooh, so that's what happened to my system! Thanks unhuman, I actually didn't know that! Been dealing with random file permission changes on and off for a long while now. Rasmus: I won't get to rebuild my own toolchain till probably next weekend, but if you haven't done it before me, I can zip up mine for you. 2 Quote Link to comment https://forums.atariage.com/topic/164295-gcc-for-the-ti/page/9/#findComment-3090653 Share on other sites More sharing options...
Asmusr Posted October 15, 2014 Share Posted October 15, 2014 This is what I get when I try to make binutils under cygwin. I have no idea what it means. Rasmus@RHLA5603A ~/binutils-2.19.1 $ make all make[1]: Entering directory '/home/Rasmus/binutils-2.19.1' make[2]: Entering directory '/home/Rasmus/binutils-2.19.1/libiberty' make[3]: Entering directory '/home/Rasmus/binutils-2.19.1/libiberty/testsuite' make[3]: Nothing to be done for 'all'. make[3]: Leaving directory '/home/Rasmus/binutils-2.19.1/libiberty/testsuite' make[2]: Leaving directory '/home/Rasmus/binutils-2.19.1/libiberty' make[2]: Entering directory '/home/Rasmus/binutils-2.19.1/intl' rm -f stamp-h1 /bin/sh ./config.status config.h config.status: creating config.h config.status: config.h is unchanged test -f config.h || (rm -f stamp-h1 && make stamp-h1) make[2]: Leaving directory '/home/Rasmus/binutils-2.19.1/intl' make[2]: Entering directory '/home/Rasmus/binutils-2.19.1/bfd' Making info in doc make[3]: Entering directory '/home/Rasmus/binutils-2.19.1/bfd/doc' make chew.exe make[4]: Entering directory '/home/Rasmus/binutils-2.19.1/bfd/doc' make[4]: 'chew.exe' is up to date. make[4]: Leaving directory '/home/Rasmus/binutils-2.19.1/bfd/doc' ./chew.exe -f ../.././bfd/doc/doc.str <../.././bfd/doc/../targets.c >targets.tmp /bin/sh ../.././bfd/doc/../../move-if-change targets.tmp targets.texi restore=: && backupdir=".am$$" && \ rm -rf $backupdir && mkdir $backupdir && \ if (makeinfo --split-size=5000000 --split-size=5000000 --version) >/dev/null 2>& 1; then \ for f in bfd.info bfd.info-[0-9] bfd.info-[0-9][0-9] bfd.i[0-9] bfd.i[0-9][0-9 ]; do \ if test -f $f; then mv $f $backupdir; restore=mv; else :; fi; \ done; \ else :; fi && \ if makeinfo --split-size=5000000 --split-size=5000000 -I ../.././bfd/doc \ -o bfd.info `test -f 'bfd.texinfo' || echo '../.././bfd/doc/'`bfd.texinfo; \ then \ rc=0; \ else \ rc=$?; \ $restore $backupdir/* `echo "./bfd.info" | sed 's|[^/]*$||'`; \ fi; \ rm -rf $backupdir; exit $rc bfd.texinfo:326: unknown command `colophon' bfd.texinfo:337: unknown command `cygnus' ./elf.texi:11: raising the section level of @subsubsection which is too low Makefile:394: recipe for target 'bfd.info' failed make[3]: *** [bfd.info] Error 1 make[3]: Leaving directory '/home/Rasmus/binutils-2.19.1/bfd/doc' Making info in po make[3]: Entering directory '/home/Rasmus/binutils-2.19.1/bfd/po' make[3]: Nothing to be done for 'info'. make[3]: Leaving directory '/home/Rasmus/binutils-2.19.1/bfd/po' make[3]: Entering directory '/home/Rasmus/binutils-2.19.1/bfd' make[3]: Nothing to be done for 'info-am'. make[3]: Leaving directory '/home/Rasmus/binutils-2.19.1/bfd' Makefile:1094: recipe for target 'info-recursive' failed make[2]: *** [info-recursive] Error 1 make[2]: Leaving directory '/home/Rasmus/binutils-2.19.1/bfd' Makefile:3100: recipe for target 'all-bfd' failed make[1]: *** [all-bfd] Error 2 make[1]: Leaving directory '/home/Rasmus/binutils-2.19.1' Makefile:722: recipe for target 'all' failed make: *** [all] Error 2 Quote Link to comment https://forums.atariage.com/topic/164295-gcc-for-the-ti/page/9/#findComment-3092845 Share on other sites More sharing options...
lucien2 Posted October 18, 2014 Share Posted October 18, 2014 (edited) This is what I get when I try to make binutils under cygwin. I have no idea what it means. I had the same error with the latest version of cygwin, so I compiled it with an older version (2.738): http://lb3.one/public/TI99-GCC-1.9.zip It seems to be a problem with texinfo: https://dev.haiku-os.org/ticket/9482 I love bug reports, keep 'em coming. I found these two years ago (compiled with size optimization -Os): void show_mem(char l,unsigned char* c,int n) { int i; *(volatile char*)0x8C02=l*32; *(volatile char*)0x8C02=l*32>>8|0x40; for(i=0;i<n*2;i++) { unsigned char c2; if(i%2)c2=c[i/2]&0x0F; else c2=c[i/2]>>4; if(c2<10)c2+=0x30; else c2+=0x37; *(volatile char*)0x8C00=c2; } } char ar1[8]; void bug1() { //R0 is used for the "indexed memory" addressing mode "@>XX(R0)" //when all the other registers are used int i; for(i=0;i<8;i++) { asm( "nop 0" :: :"r1","r2","r3","r4","r5","r6","r7","r8","r12" ); ar1[i]=i; } //ar=7,0,0,0,0,0,0,0 instead of 0,1,2,3,4,5,6,7 } char bug2(char c) { //when "c" is -1, R1 is >FFFF because of "SETO" //two's complement (NEG) is >0001 (byte value = 0) //-1 should be >FF00 (two's complement = >0100) return -c; } //int bug_3=0xABCD; char bug3(char c) { /*when a switch instruction is compiled with a data table (CSWTCH table in the generated assembly) and the source file has no global initilization, CSWTCH is declared in the "cseg" segment instead of the "pseg" segment. And the "cseg" segment is not pointed by "_init_data" in "crt0_cart.asm" and "crt0_ea5.asm". (try to uncomment the "bug_3" declaration). */ char ret=1; switch(c) { case 0: ret=3; break; case 1: ret=2; break; } return ret; } void main() { volatile char c; //Should display 01020304050607 instead of 07000000000000 bug1(); show_mem(0,ar1,; //Should display 01 instead of 00 c=-1; char c2=bug2(c); show_mem(1,&c2,1); //Should display 02 instead of 00 c=1; char c3=bug3(c); show_mem(2,&c3,1); while(1); } Edited October 10, 2016 by lucien2 Quote Link to comment https://forums.atariage.com/topic/164295-gcc-for-the-ti/page/9/#findComment-3094983 Share on other sites More sharing options...
lucien2 Posted October 19, 2014 Share Posted October 19, 2014 The assembler does not work with labels and intructions on the same line anymore. I had to do things like that: lbl1 mov r1,r2 lhl2 equ >ffff lbl3 data >0000 Quote Link to comment https://forums.atariage.com/topic/164295-gcc-for-the-ti/page/9/#findComment-3095002 Share on other sites More sharing options...
lucien2 Posted November 4, 2014 Share Posted November 4, 2014 (edited) I compiled all my programs with the new version and I found no new bugs. Rush hour does not compile correctly (It did with gcc patch 1.6 / binutils patch 1.4). There is an R0 used for indirect addressing in the function "move_block" (bug #1 in my list of October 18th). With bug#2 from my list, that's only 2 bugs for a total of 4058 lines of C source code compiled! Edited November 4, 2014 by lucien2 Quote Link to comment https://forums.atariage.com/topic/164295-gcc-for-the-ti/page/9/#findComment-3106464 Share on other sites More sharing options...
insomnia Posted December 4, 2014 Author Share Posted December 4, 2014 OK, who's up for new patches? First, a huge thank you to Lucien2 for tracking down these compiler bugs and making test cases for them. That was super helpful. Here are the latest changes: Binutils --------- Restored ability to have label and code on same lineMinor code cleanup GCC ------- Prevented use of R0 as an address baseMoved jump tables into text segment to free up space for variablesFixed bug which put initialized data in bss sectionFixed negation of byte quantitiesMinor code cleanup Basically, all the bugs here are the result of me making dumb mistakes. Sorry about that. But the good news is that If these were the most visible bugs still rattling around in the code, the compiler must be getting pretty darn stable. I'm really happy that as more projects are being worked on, the list of problems seems to be drying up. The number of untested edge cases (each potentially hiding a bug or two) must be pretty smalll at this point. I feel kind of bad that I haven't been able to help anyone having problems with Cygwin, or Windows stuff in general. I do all my development in Linux, and don't really have any useful advice for those people. Another big thank you to everyone who has been able to provide that help. At any rate, the patches and gcc installler have been updated in the first post. If anyone is interested there are more development details on my blog. As always, please let me know if you have any problems or see anything that could be improved. 6 Quote Link to comment https://forums.atariage.com/topic/164295-gcc-for-the-ti/page/9/#findComment-3126060 Share on other sites More sharing options...
TheMole Posted December 4, 2014 Share Posted December 4, 2014 Excellent, very cool updates. I'm going to build this as soon as I get home 'cause I think I may have been bitten by the segment bug you talked about on your blog. I just never attributed it to the compiler, but it from your description it could be it (hope so!). Quote Link to comment https://forums.atariage.com/topic/164295-gcc-for-the-ti/page/9/#findComment-3126110 Share on other sites More sharing options...
TheMole Posted December 4, 2014 Share Posted December 4, 2014 (edited) I'm having a problem building this on OS X 10.10 (using LLVM). Usually I have to fiddle with some things a little bit to get things working, but here I'm stumped as to what might be going wrong. This is as far as I get (and the modifications I did to get this far): Patches apply fine Binutils compiles fine GCC starts to compile: first I had to amend the ./configure line to point to where libgmp and friends can be found. Then I had to modify a GCC version check to fix a compile error (and later link error) in toplev.c (simple #ifdef gcc-ism I had to strip out, nothing that should impact the code in the end) Then I run into the error I can't seem to solve below: /Users/danny/Documents/dev/build/gcc-4.4.0/build/./gcc/xgcc -B/Users/danny/Documents/dev/build/gcc-4.4.0/build/./gcc/ -B/Users/danny/Documents/dev/build/tms9900/bin/ -B/Users/danny/Documents/dev/build/tms9900/lib/ -isystem /Users/danny/Documents/dev/build/tms9900/include -isystem /Users/danny/Documents/dev/build/tms9900/sys-include -g -O2 -O2 -g -O2 -DIN_GCC -DCROSS_DIRECTORY_STRUCTURE -W -Wall -Wwrite-strings -Wstrict-prototypes -Wmissing-prototypes -Wcast-qual -Wold-style-definition -isystem ./include -g -DIN_LIBGCC2 -D__GCC_FLOAT_NOT_NEEDED -Dinhibit_libc -I. -I. -I../.././gcc -I../../../libgcc -I../../../libgcc/. -I../../../libgcc/../gcc -I../../../libgcc/../include -DHAVE_CC_TLS -o _absvhi2.o -MT _absvhi2.o -MD -MP -MF _absvhi2.dep -DL_absvsi2 -c ../../../libgcc/../gcc/libgcc2.c \ -DLIBGCC2_UNITS_PER_WORD=2 In file included from ../.././gcc/tm.h:5, from ../../../libgcc/../gcc/libgcc2.c:31: ../../../libgcc/../gcc/config/tms9900/tms9900.h:1132: error: expected ‘)’ before ‘*’ token make[1]: *** [_absvhi2.o] Error 1 make: *** [all-target-libgcc] Error 2 === Failed to build GCC === I looked at tms9900.h, tm.h and libgcc2.c and can't see any obvious mistakes (definitions seem to be complete and match up and all that...). Any ideas? *edit* I want to add that I did get it to compile in the past with the LLVM that comes with XCode 5, but since upgrading to Yosemite and XCode 6 I hadn't tried recompiling the code base. The LLVM version is reported as follows: Dannys-Mac-mini:dev danny$ gcc -v Configured with: --prefix=/Applications/Xcode.app/Contents/Developer/usr --with-gxx-include-dir=/usr/include/c++/4.2.1 Apple LLVM version 6.0 (clang-600.0.54) (based on LLVM 3.5svn) Target: x86_64-apple-darwin14.0.0 Thread model: posix Edited December 4, 2014 by TheMole Quote Link to comment https://forums.atariage.com/topic/164295-gcc-for-the-ti/page/9/#findComment-3126171 Share on other sites More sharing options...
