Rex Dart Posted July 18, 2010 Share Posted July 18, 2010 Hi, just wondering what the specs are on the power supply for the 7800-styled Flashback unit. Also, is there another readily-available power supply that's compatible, or will I want to use a universal supply? Quote Link to comment Share on other sites More sharing options...
Nesbroslash Posted July 18, 2010 Share Posted July 18, 2010 Meh, it's AC isn't it? Pretty much any universal adapter will work fine. Quote Link to comment Share on other sites More sharing options...
Rex Dart Posted July 18, 2010 Author Share Posted July 18, 2010 Meh, it's AC isn't it? Pretty much any universal adapter will work fine. So do I, but I would need to know the specs to configure it to.... hence the topic. Quote Link to comment Share on other sites More sharing options...
Nesbroslash Posted July 18, 2010 Share Posted July 18, 2010 Hmmmm, I don't have the original, but would the power specs be higher than the FB2 since it's NOAC as compared to regular 2600 guts on the FB2? It says it is 120 volts on the plug-in, so I'd assume the FB1 is about the same. Quote Link to comment Share on other sites More sharing options...
Rex Dart Posted July 18, 2010 Author Share Posted July 18, 2010 Yes, I know the power supplies plug into the wall outlets. Can anybody help me here? Quote Link to comment Share on other sites More sharing options...
awace Posted July 19, 2010 Share Posted July 19, 2010 (edited) the pOWER PACK FOR THE FLASHBACK II is a just a dc power pack although all you need is 5vDC to run the Flashback II I have since put my flashback II inside a old Atari 2600 case and am using a 9v DC 500Ma power pack and the lm3905 voltage regulator and the original atari 2600 capacitor to get it to 5v DC for the power input but the flashback II is a 9v DC 200Ma power pack I would suggest using a 500Ma power pack If you plan to do the mod since the atari carts and 2732/64/256 chips take more power but if you dont do the Cart mod you should be fine w a 9vDC 200Ma I would just get a 500Ma power pack check youre thrift or Good will they usually have lots of {(ansewering machines just make shure + in the middle and DC some answering machines power packs are AC 9v and would need a rectifire bridge and capacitor to make DC way to mutch work when you could just find a DC power pack.) or cordless phones with power packs all over the place.. GOOD LUCK. oh ps I remembered where I saw one http://www.atariage.com/forums/topic/151738-anyone-have-a-fb2-power-supply-pic/ it was here a long time ago in the picture!! Also there is a 5v voltage regulator inside the flashback II thats why I opted to reuse a broken 2600 for its cart slot and its power capacitor and the fact that I had a old funvision power pack witch is a 9v 500ma power pack that plugs into a 2600 nicely its kind of a pain but if youre going to do the cart mod you might as whell put the whole thing inside a old non working 2600 .. I just used the b/w switch on the old 2600 for built in/cart and the ch3 switch for b/w it was almost as hard to solder the cart wires as it was to solder the joystick inputs.. at least the a/b switches just short to gnd.. Edited July 19, 2010 by awace Quote Link to comment Share on other sites More sharing options...
Rex Dart Posted July 19, 2010 Author Share Posted July 19, 2010 It's not a Flashback II. Will that work? The guy who owns this has tried an NES power supply with no luck, and that's all I know about its power requirements. Quote Link to comment Share on other sites More sharing options...
onmode-ky Posted July 21, 2010 Share Posted July 21, 2010 I was not going to reply, since I don't have the data you seek, but considering how helpful the responses have been, I'm almost inclined to say something equally useless just to continue the pattern. Maybe: "You should look at the specs on the one that it came with." Or perhaps: "Try just using it without the power supply." And then there's the always popular "My cat's breath smells like cat food." On the more helpful side of things, I suggest you send a message to AtariAge user "Curt Vendel" asking your question, since he's the guy who designed the thing. onmode-ky Quote Link to comment Share on other sites More sharing options...
