Animation and Special Effect Contest
matthew180
I wrote this a while back, in TurboForth. Here is the video:
http://www.youtube.com/watch?v=qBdGd52A3gs
( ** StarField Sprite Demo ** )
VARIABLE RND HERE RND ! ( seed )
VARIABLE StringSpace
82 CHARS ALLOT 	        ( create a string buffer )
StringSpace 84 32 FILL 	( initialise it to ASCII 32 )
S" The Power Of Forth!" ( addr len )
StringSpace 		( addr len addr )
SWAP 			( addr addr len )
CMOVE> 			( move string into buffer )
0 VALUE FlipFlop
( ascii codes for small, medium, and big stars )
64 CONSTANT Sml*
65 CONSTANT Med*
66 CONSTANT Big*
( keyboard codes )
CHAR E CONSTANT KeyE
CHAR S CONSTANT KeyS
CHAR D CONSTANT KeyD
CHAR X CONSTANT KeyX
( define colours )
15 CONSTANT White
9  CONSTANT TEN
( set up user defined graphics for the 3 star sizes )
: UDG 8000$    0  0 0 4 Sml* DCHAR ( define small star )
     40E0$ 4000$ 0 0 4 Med* DCHAR ( define medium star )
     70F8$ F870$ 0 0 4 Big* DCHAR ( define large star ) ;
: RANDOM ( limit -- rnd )
 RND @ 31421 * 6927 + DUP RND ! ABS SWAP MOD ;
( generate a random Y coordinate )
: RndY 180 RANDOM ;
( generate a random X coordinate )
: RndX 256 RANDOM ;
( set up our sprites. 10 small, 10 medium, 10 large )
: 10Small TEN FOR I       RndY RndX Sml* White SPRITE NEXT ;
: 10Med   TEN FOR I 10 +  RndY RndX Med* White SPRITE NEXT ;
: 10Big   TEN FOR I 20 +  RndY RndX Big* White SPRITE NEXT ;
( set up the sprite movement list for each direction )
: GoLeft  TEN FOR I       0 -1 SMLIST NEXT
         TEN FOR I 10 +  0 -2 SMLIST NEXT
  TEN FOR I 20 +  0 -3 SMLIST NEXT ;
: GoRight TEN FOR I       0  1 SMLIST NEXT
         TEN FOR I 10 +  0  2 SMLIST NEXT
  TEN FOR I 20 +  0  3 SMLIST NEXT ;
: GoUp    TEN FOR I      -1  0 SMLIST NEXT
         TEN FOR I 10 + -2  0 SMLIST NEXT
  TEN FOR I 20 + -3  0 SMLIST NEXT ;
: GoDown  TEN FOR I       1  0 SMLIST NEXT
         TEN FOR I 10 +  2  0 SMLIST NEXT
  TEN FOR I 20 +  3  0 SMLIST NEXT ;
: Delay 100 FOR NEXT ;
: DoFlipFlop FlipFlop NOT DUP TO FlipFlop ;
: ScanKeys
  KEY? CASE
   KeyE OF GoUp    ENDOF
     KeyS OF GoLeft  ENDOF
     KeyD OF GoRight ENDOF
     KeyX OF GoDown  ENDOF
  ENDCASE
  BREAK?
: Scroll
  DoFlipFlop IF
    [ StringSpace 83 + LITERAL ] C@
    [ StringSpace LITERAL StringSpace 1+ LITERAL ] 83 CMOVE>
    [ StringSpace LITERAL ] C!
    0  0 GOTOXY [ StringSpace 32 + LITERAL ] 31 TYPE
    0 23 GOTOXY [ StringSpace 32 + LITERAL ] 31 TYPE
    ScanKeys
  THEN
: Setup
   1 GMODE  0 SCREEN  UDG  10Small 10Med 10Big GoRight ;
: GO
   Setup BEGIN 0 30 SPRMOV Scroll Delay AGAIN ;
:cool:
And Sometimes.... That flip effect is very intriguing!!
icon_smile.gif If you arrange characters(/font) and colors, then the effect could be something like with my 5 year old demo ...
The still effect of things or text reflecting in water has been used for more than one hundred years.
Edited by sometimes99er
I can't compete with you Assembly gurus but here is a little XB routine that I developed to use with a game I am developing at the moment (on and off anyway....). For the purpose of this thread I named it XB-SCROLL. This is my best attempt at "high res" smooth scrolling in BASIC.
1 ! XB-SCROLL
100 CALL CLEAR :: DISPLAY AT(2,11):"XB-SCROLL" :: CALL CHAR(128,RPT$("F",16),129,"00C0E0FEC778")
110 FOR I=96 TO 127 STEP 4 :: READ A$ :: CALL CHAR(I,A$) :: A=A+1 :: FOR D=0 TO 3 :: B$(A)=B$(A)&CHR$(I+D) :: NEXT D :: NEXT I
120 DISPLAY AT(16,1):RPT$(B$(1),7);RPT$(CHR$(128),224) :: CALL SPRITE(#1,129,16,100,30)
130 FOR I=1 TO 8 :: DISPLAY AT(16,1):RPT$(B$(I),7) :: B$(I)=SEG$(B$(I),2,3)&SEG$(B$(I),1,1) :: NEXT I :: GOTO 130
140 DATA 0000001D3F7FFFFF002078FDFFFFFFFF000E3FFFFFFFFFFF0000C0E0F0FEFFFF,0000003B7FFFFFFF0040F0FBFFFFFFFF001C7FFFFFFFFFFF000080C0E0FCFFFF
150 DATA 00000177FFFFFFFF0080E0F7FFFFFFFF0038FFFFFFFFFFFF00000080C0F9FFFF,000103EFFFFFFFFF0000C1EFFFFFFFFF0070FEFFFFFFFFFF0000000081F3FFFF
160 DATA 000207DFFFFFFFFF000083DFFFFFFFFF00E0FCFEFFFFFFFF0000000103E7FFFF,00040FBFFFFFFFFF000107BFFFFFFFFF00C0F8FCFEFFFFFF0000000307CFFFFF
170 DATA 00081E7FFFFFFFFF00030F7FFFFFFFFF0080F0F8FCFFFFFF000000070F9FFFFF,00103CFEFFFFFFFF00071FFFFFFFFFFF0000E0F0F8FFFFFF0000000E1F3FFFFF
Edited by Bones-69
1 ! "XB-SCROLL"
Wow ! That's excellent scrollin' ! :thumbsup:
That is some pretty good scrolling! I wonder if it might be even faster to just change the patterns of the characters instead of redrawing the line each time through the loop?
I suspect I could speed the scrolling up, and therefore the smoothness, by at least double (maybe more) - at the cost of a longer program initialisation and using more memory by converting the entire process to strings in advance and then just calling each string in a loop rather than calculating the display each time. I will throw something together later as an example.... In a program environment (if memory allowed), it would certainly be the better way to do it.
I managed to speed it up a little. Almost smooth now, but at the cost of a little more memory...
100 ! XB-SCROLL-2
110 ! BONES
120 DIM C$(32) :: CALL CLEAR :: DISPLAY AT(2,11):"XB-SCROLL" :: CALL CHAR(128,RPT$("F",16),129,"00C0E0FEC778")
130 FOR I=96 TO 127 STEP 4 :: READ A$ :: CALL CHAR(I,A$) :: A=A+1 :: FOR D=0 TO 3 :: B$(A)=B$(A)&CHR$(I+D) :: NEXT D :: NEXT I
140 DISPLAY AT(16,1):RPT$(B$(1),7);RPT$(CHR$(128),224) :: A=0
150 FOR I=1 TO 8 :: B$(I)=SEG$(B$(I),2,3)&SEG$(B$(I),1,1) :: A=A+1 :: C$(A)=RPT$(B$(I),7) :: IF A=32 THEN 170
160 NEXT I :: GOTO 150
170 FOR I=1 TO 32 :: DISPLAY AT(16,1):C$(I) :: NEXT I :: GOTO 170
180 DATA 0000001D3F7FFFFF002078FDFFFFFFFF000E3FFFFFFFFFFF0000C0E0F0FEFFFF,0000003B7FFFFFFF0040F0FBFFFFFFFF001C7FFFFFFFFFFF000080C0E0FCFFFF
190 DATA 00000177FFFFFFFF0080E0F7FFFFFFFF0038FFFFFFFFFFFF00000080C0F9FFFF,000103EFFFFFFFFF0000C1EFFFFFFFFF0070FEFFFFFFFFFF0000000081F3FFFF
200 DATA 000207DFFFFFFFFF000083DFFFFFFFFF00E0FCFEFFFFFFFF0000000103E7FFFF,00040FBFFFFFFFFF000107BFFFFFFFFF00C0F8FCFEFFFFFF0000000307CFFFFF
210 DATA 00081E7FFFFFFFFF00030F7FFFFFFFFF0080F0F8FCFFFFFF000000070F9FFFFF,00103CFEFFFFFFFF00071FFFFFFFFFFF0000E0F0F8FFFFFF0000000E1F3FFFFF
Edited by Bones-69
The circle demo is very cool :cool:
Could imagine using it for something similar as seen in the below WIP MSX1 shooter "Core Crisis". Look starting at 1:10 min :)
http://www.youtube.com/watch?v=Rzz4ZNc675Y
edit: I'd love to add a "special effects" library to spectra2 once I have the basic functionality rolling.
I'm hoping I get the permission to use the circle routine and some of Karsten's routines :)
Edited by retroclouds
Awww come on retroclouds... You know you wanna use my color cycling (post 19). :) hehehehe.... Just kidding.
@adamantyr... That circles demo is pretty awesome. You say this is to be a special effect in "Realms?". That will be pretty wicked man. :) I love battle graphic animations, specifically on old systems. :thumbsup:
