Programming tricks: Better bit flags
GroovyBee
Lets say you have four bit flags that you want to perform a single action on if any one of them is set.
You might handle the decision code something like this :-
   mvi SomeFlags, r0
   movr r0, r1
   andi #$0001, r1
   bne HandleAction1
   movr r0, r1
   andi #$0002, r1
   bne HandleAction2
   movr r0, r1
   andi #$0004, r1
   bne HandleAction3
   movr r0, r1
   andi #$0008, r1
   bne HandleAction4
Or if you wanted to be more efficient you could use double shifts :-
   mvi SomeFlags, r0
   movr r0, r1
   rrc r1, 2
   bc HandleAction1
   bov HandleAction2
   rrc r1, 2
   bc HandleAction3
   bov HandleAction4
The problem with both of these solutions is that you need to find a temporary register to hold the original value should you want to clear the bit flags later.
For ultimate speed its possible to use a technique often used in the ARM microcontroller world. The CP1600 allows the contents (arithmetic result flags only) of its status register to be directly read from and written to using the GSWD and RSWD instructions respectively. The status register's four arithmetic bit flags are Carry, Overflow, Zero and Sign.
The GSWD instruction writes the status register's contents to the top most four bits of each byte in the destination register as follows (where x is zero to aid clarity) :-
1 1 1 1 1 1
5 4 3 2 1 0 9 8 7 6 5 4 3 2 1 0
|S|Z|O|C|x|x|x|x|S|Z|O|C|x|x|x|x|
The RSWD instruction reads the status register's new value from the least significant byte of the source register as follows (where x is don't care) :-
7 6 5 4 3 2 1 0
|S|Z|O|C|x|x|x|x|
Thus if we move our flags of interest to the upper four bits of the least significant byte and we move that register into the status register we can directly affect the arithmetic flags and the code sequence can be optimised to the following :-
   mvi SomeFlags, r0
   rswd r0
   bc HandleAction1 ; Bit 4 set?
   bov HandleAction2 ; Bit 5 set?
   bze HandleAction3 ; Bit 6 set?
   bmi HandleAction4 ; Bit 7 set?
If you want to detect if a bit flag is zero then the "opposite sense" branch instructions of bnc, bnov, bnze and bpl can be used instead.
The need for a temporary register has gone too.
   mvi SomeFlags, r0
   rswd r0
Awesome! I now will go hunt through my current game code to change the double SARC shifts for this trick, where applicable. That's very cool.
-dZ.
Edited by DZ-Jay
Thus if we move our flags of interest to the upper four bits of the least significant byte and we move that register into the status register...
I just realized something, if the bit vector is right-justified on the word, then this means that you still need to shift it into the upper four bits of the Least Significant Byte of the register. This removes any advantage over the second method you mentioned (shifting/rotating into Carry and Overflow), unless the vector was already there, of course.
-dZ.
Yep! The optimisation is dependent on the data given. If you are only interested in 2 to 4 bits its a good solution. Preparing the data in advance is the key. For example where you'd do :-
   xori #$01, r0
Change it to :-
   xori #$10, r0
And you avoid the shifts because the bit flags are already where you need them.
   xori #$01, r0
Change it to :-
   xori #$10, r0
Yes, that's true. I'll take that into consideration in the future when I'm preparing my vectors.
-dZ.
   mvi SomeFlags, r0
   rswd r0
That is handy, although often a lookup table is faster (if larger). ie.
       ADDI    #@@tbl, R1
       MVI@    R1,     PC
@@tbl:  DECLE   NoAction
       DECLE   HandleAction1    ; bit 0 is leftmost bit set
       DECLE   HandleAction2    ; bit 1 is leftmost bit set
       DECLE   HandleAction3    ; bit 2 is leftmost bit set
       DECLE   HandleAction4    ; bit 3 is leftmost bit set
Like I said, larger (19 vs 11 words), but a little bit faster.
You can get a little more bang-for-the-buck out of SLLC or SARC too, in case your flags are formatted differently. If your flags are in the four MSBs and the rest of the word is 0s, you can do:
   SLLC R0, 2
   BC   bit15_set
   BOV  bit14_set
   BMI  bit13_set
   BNEQ bit12_set
SARC is a little weirder, because it grabs the sign bit from bit 7 of the result, not bit 15.
   SARC R0, 2
   BC   bit0_set
   BOV  bit1_set
   BMI  bit9_set
   ; Z bit isn't very useful
Edited by intvnut
