Unsigned 16 bit division
GroovyBee
For my latest game I needed a modulo operation. This is the code I came up with. The speed of the function isn't critical to me because its only called a few times during screen initialisation.
On entry r0 should contain the divisor and r1 the dividend. The remainder is returned r2 and the quotient in r3.
There is no check for division by zero.
; DivideU16ByU16
; Division for 16bit unsigned integers.
; In :-
; r0 - Divisor (unsigned 16bit integer).
; r1 - Dividend (unsigned 16bit integer).
; r5 - Return address.
; Out :-
; r2 - Remainder (unsigned 16bit integer).
; r3 - Quotient (unsigned 16bit integer).
; Trashes :-
; r1, r2, r3, r4
; Notes :-
; 1) No division by 0 check.
DivideU16ByU16: PROC
   clrr r2             ; Remainder=0
   clrr r3             ; Quotient=0
   mvii #16, r4        ; Number of bits in dividend.
DivideU16ByU16Loop:
   sllc r1, 1          ; Dividend=dividend*2
   rlc r2, 1           ; Remainder=(remainder*2)+Carry
   cmpr r0, r2         ; Is remainder>=divisor?
   bnc DivideU16ByU16QuotientMultiplyOnly ; Yes... Skip subtraction.
   subr r0, r2         ; Remainder=remainder-divisor.
DivideU16ByU16QuotientMultiplyOnly:
   rlc r3, 1           ; Quotient=(quotient*2)+Carry
   decr r4             ; Repeat for all 16 bits...
   bne DivideU16ByU16Loop ; ...In the dividend
   movr r5, pc         ; All done!
   ENDP
Use as follows :-
; E.g. 7899/45
   mvii #45, r0
   mvii #7899, r1
   call DivideU16ByU16
If it's only called a few times during screen init, is there a reason you can't use the "MOD" assembler operator?
