stringfellow Posted October 18, 2010 Share Posted October 18, 2010 This may or may not have been posted before but here goes. What is the difference between the two? Aside from the obvious that is. I have both and I thought that they might be interchangeable but it seems I was wrong. My paddle controllers need repair so I can't play breakout with them. I thought that I could use my driving controller instead but when I try nothing works. Is there anything I can do to make the driving controller work? Quote Link to comment Share on other sites More sharing options...
OldAtarian Posted October 18, 2010 Share Posted October 18, 2010 Driving controllers can be turned infinitely in either direction, paddles have stops. Driving controllers are single, paddles are wired in pairs. Other than that I would have to say that the pot inside is different and the combination of the pot and the way the controller is wired sends a completely different signal through the joystick port depending on which type of controller you are using. Quote Link to comment Share on other sites More sharing options...
BigO Posted October 18, 2010 Share Posted October 18, 2010 (edited) Paddles use a potentiometer aka variable resistor. The position of this controller is read by the console. Their range of rotation is limited to approximately 330 degrees, though few (if any) games use even half of the rotational range. Driving controllers use a rotary encoder. The change in position of this controller is detected by the console. Their range of rotation is limitless, but only 16 positional changes can be represented by one rotation of the knob. They are entirely different technologies and can not be interchanged unless the game software provides a means of using each type of controller. Only one driving controller can be used per port, so only 2 driving controllers can be used in a game. 2 paddle controllers can be used per port so a game can have up to 4 controllers. This definitely has been discussed a number of times so you should be able to find more detail by poking around on the forums here. Some terms that you may never have heard of which would turn up technical discussions on the driving controller: - rotary encoder - gray (or grey) code Edited October 18, 2010 by BigO Quote Link to comment Share on other sites More sharing options...
Rybags Posted October 18, 2010 Share Posted October 18, 2010 Driving controllers don't have Pots. They're like a single-axis mouse, they send various values on 2 of the joystick directional bits. Software can then interpret the changes in values to deduce what movement is occurring. Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted October 18, 2010 Share Posted October 18, 2010 Driving controllers don't use a potentiometer, they send gray code. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted October 18, 2010 Share Posted October 18, 2010 Driving controllers don't use a potentiometer, they send gray code. Yup, just like the Trak ball does for each axis. But with a much lower resolution than the Trak Ball. Quote Link to comment Share on other sites More sharing options...
stringfellow Posted October 19, 2010 Author Share Posted October 19, 2010 Ok, I think I got it. Thanks for the help. How difficult is it to change the pot in the paddle controller? Quote Link to comment Share on other sites More sharing options...
BigO Posted October 19, 2010 Share Posted October 19, 2010 (edited) Ok, I think I got it. Thanks for the help. How difficult is it to change the pot in the paddle controller? Mr. Hawke, It's not very difficult. If you can solder then there's not much challenge at all. The trickiest part would be finding a compatible replacement. I don't recall exactly what it is, but I remember hearing that there's something slightly unusual about the pots used in the paddles. Maybe the shape of the shaft, the flat side shaped into it? Do you have broken paddles that you're trying to repair? It's not at all uncommon for paddles to "jitter" and that can usually be fixed without replacing the pot. Edited October 19, 2010 by BigO Quote Link to comment Share on other sites More sharing options...
highinfidelity Posted October 19, 2010 Share Posted October 19, 2010 Yes, unless the potentiometer had been physically damaged, use some spray deoxidizer for electronics FIRST. Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted October 19, 2010 Share Posted October 19, 2010 Check Longhorn Engineer's guide to Fix Atari Controllers Quote Link to comment Share on other sites More sharing options...
Rex Dart Posted October 19, 2010 Share Posted October 19, 2010 I've lost the link, but there was one website where a guy explained how to repair 2600 paddles. Only I didn't trust him for a second, because the thought the purpose of the rosin core in the solder was to "smell good". 1 Quote Link to comment Share on other sites More sharing options...
BigO Posted October 19, 2010 Share Posted October 19, 2010 I've lost the link, but there was one website where a guy explained how to repair 2600 paddles. Only I didn't trust him for a second, because the thought the purpose of the rosin core in the solder was to "smell good". Heh. Quote Link to comment Share on other sites More sharing options...
Fixitguy74 Posted October 19, 2010 Share Posted October 19, 2010 I've lost the link, but there was one website where a guy explained how to repair 2600 paddles. Only I didn't trust him for a second, because the thought the purpose of the rosin core in the solder was to "smell good". You mean thats not what it's for? LOL! Quote Link to comment Share on other sites More sharing options...
SlowCoder Posted October 19, 2010 Share Posted October 19, 2010 Right. Unless there's damage to the controllers, a good cleaning is all that's required. There are tutorials all over the net. If you can weild a screwdriver and read, it's pretty easy. Quote Link to comment Share on other sites More sharing options...
stringfellow Posted October 20, 2010 Author Share Posted October 20, 2010 excellent, I'll have to see what I have that I can clean them with. Good to know that I might not have to replace anything. You guys sure are a helpful bunch around here. Quote Link to comment Share on other sites More sharing options...
SlowCoder Posted October 20, 2010 Share Posted October 20, 2010 excellent, I'll have to see what I have that I can clean them with. Good to know that I might not have to replace anything. You guys sure are a helpful bunch around here. All you should need is some high percentage Isopropyl alcohol (90%+) and cotton swabs, a phillips screwdriver, and a pair of needlenose pliers. And, thanks for the props to all of us! Quote Link to comment Share on other sites More sharing options...
A.J. Franzman Posted October 21, 2010 Share Posted October 21, 2010 All you should need is some high percentage Isopropyl alcohol (90%+) and cotton swabs, a phillips screwdriver, and a pair of needlenose pliers. I would add to that list, a proper wrench (or "spanner" for you Brits) to loosen and tighten the nut which holds the pot to the case top. Those nuts were made in a couple of different sizes IIRC; something like 1/2 inch on the heavy sixer style and 9/16 inch on the later ones. Quote Link to comment Share on other sites More sharing options...
JingleJoe Posted October 22, 2010 Share Posted October 22, 2010 Ok, I think I got it. Thanks for the help. How difficult is it to change the pot in the paddle controller? Mr. Hawke, It's not very difficult. If you can solder then there's not much challenge at all. The trickiest part would be finding a compatible replacement. I don't recall exactly what it is, but I remember hearing that there's something slightly unusual about the pots used in the paddles. Maybe the shape of the shaft, the flat side shaped into it? Do you have broken paddles that you're trying to repair? It's not at all uncommon for paddles to "jitter" and that can usually be fixed without replacing the pot. There is nothing unusual about the paddle controller pots, they are connected like rheostats (only middle and one other terminal used) Value: 1 Mega-ohm, linear. Pretty easy to find replacements for However cleaning out ye olde Atari pots saves money, parts and is pretty easy to do, so I'd advise you try what the chaps who posted above suggested before buying a new pot. Quote Link to comment Share on other sites More sharing options...
A.J. Franzman Posted October 22, 2010 Share Posted October 22, 2010 There is nothing unusual about the paddle controller pots, they are connected like rheostats (only middle and one other terminal used) Value: 1 Mega-ohm, linear. Pretty easy to find replacements for Guess again. Those pots haven't been made since about 2 seconds after Atari stopped using them. The exact shaft style is obsolete and the only place I know of to get the right ones is Best Electronics, if they even have them anymore. Quote Link to comment Share on other sites More sharing options...
SlowCoder Posted October 22, 2010 Share Posted October 22, 2010 Is it a good idea to grease the pots? Di-electric grease? Quote Link to comment Share on other sites More sharing options...
JingleJoe Posted October 23, 2010 Share Posted October 23, 2010 There is nothing unusual about the paddle controller pots, they are connected like rheostats (only middle and one other terminal used) Value: 1 Mega-ohm, linear. Pretty easy to find replacements for Guess again. Those pots haven't been made since about 2 seconds after Atari stopped using them. The exact shaft style is obsolete and the only place I know of to get the right ones is Best Electronics, if they even have them anymore. Oh, mere technicalities I agree, of course, the exact same type will be hard to find again, but a suitable replacement is easy to come by. Quote Link to comment Share on other sites More sharing options...
psquare75 Posted October 25, 2010 Share Posted October 25, 2010 I got some from Best a few months ago, they still had em then. Quote Link to comment Share on other sites More sharing options...
Crimefighter Posted October 29, 2010 Share Posted October 29, 2010 Here's a difference that you can see - plug in a game that uses joysticks then plug in the paddle controller and try to move around - the fire buttons control the left and right movement - the knob does nothing. Plug in the driving controller - the fire button fires but turning the knob you can only move up and down. There ya go. Quote Link to comment Share on other sites More sharing options...
