gamer2 Posted October 27, 2010 Share Posted October 27, 2010 Ok, I have a sega Genesis model 1 that will not read carts, I have tried cleaning the connector with Cotton Swabs, I have even tried cheese cloth and a credit card. Are there any other ways to clean cart slots that are much more effective? Quote Link to comment Share on other sites More sharing options...
zylon Posted October 27, 2010 Share Posted October 27, 2010 My weapon of last resort is 400 grit autobody sandpaper folded over a couple times. Check for bent pins in the slot first. Quote Link to comment Share on other sites More sharing options...
Koopa64 Posted October 27, 2010 Share Posted October 27, 2010 You tried cleaning the slot with cotton swabs? How did you get those cotton fibers out of there? Well, either way, my most recommended solution is the easiest: Take a cartridge wet it's edge connector in rubbing alcohol insert and remove the cartridge from the console several times dry off the cartridge wet it again repeat lines 3, 4 and 5 a couple more times let everything dry for 5 - 10 minutes 2 Quote Link to comment Share on other sites More sharing options...
gamer2 Posted October 27, 2010 Author Share Posted October 27, 2010 You tried cleaning the slot with cotton swabs? How did you get those cotton fibers out of there? Well, either way, my most recommended solution is the easiest: Take a cartridge wet it's edge connector in rubbing alcohol insert and remove the cartridge from the console several times dry off the cartridge wet it again repeat lines 3, 4 and 5 a couple more times let everything dry for 5 - 10 minutes I think I may have found the issue. Jumpers 2 and 4 are not making a connection like it should (the solder looks like it chipped away and is not touching the trace). I am gonna try a manual bridge for the jumpers using wires and see how that works. Quote Link to comment Share on other sites More sharing options...
Hatta Posted October 27, 2010 Share Posted October 27, 2010 Blast the shit out of it with some contact cleaner or mass airflow sensor cleaner (automotive). Do this outside, of course. Then insert a cartridge a few times like Koopa said. Maybe wrap an old t-shirt (thin and not linty) around the edge and wet it down with solvent too. Repeat a few times. Dry thoroughly. Contact cleaner is a better solvent than alcohol, and it's under pressure so there's a mechanical advantage too. Worst case scenario, if nothing else works and the pins aren't bent, put it in the dishwasher. Quote Link to comment Share on other sites More sharing options...
