BASIC / XB Translator (TidBit)
matthew180
Okay, I've been trying to find all my old code inside 3 hard drives, several USB sticks and a bunch of online storage locations. Got most of it off my laptop hard drive.
My first attempt at using TIdBiT was the following.
Code In:
REM MENU
A: CALL CLEAR :: CALL SCREEN(2)
   DISPLAY AT(1,4):"THIS IS A MENU TEST";"   FOR BERYL REICHARDT";
   DISPLAY AT(8,1):"PRESS 1 FOR WEAPONS";"PRESS 2 FOR STATS";"PRESS 3 TO EXIT";
K: CALL KEY(0,K,S):: IF S=0 THEN GOTO K
   IF K>51 THEN GOTO K ELSE IF K<49 THEN GOTO K
   ON K-48 GOTO W,S,E
W: CALL CLEAR :: PRINT "WEAPONS" :: PRINT "PRESS ENTER TO EXIT"
W1:  CALL KEY(0,K,S):: IF S=0 THEN GOTO W1
   IF K=13 THEN GOTO A ELSE W
S: CALL CLEAR :: PRINT "STATS" :: PRINT "PRESS ENTER TO EXIT"
S1: CALL KEY(0,K,S):: IF S=0 THEN GOTO S1
   IF K=13 THEN GOTO A ELSE S
E: CALL CLEAR :: GOTO 150
Code Out:
1000 CALL CLEAR :: CALL SCREEN(2)
1010 DISPLAY AT(1,4):"THIS IS A MENU TEST";"   FOR BERYL REICHARDT";
1020 DISPLAY AT(8,1):"PRESS 1 FOR WEAPONS";"PRESS 2 FOR STATS";"PRESS 3 TO EXIT";
1030 CALL KEY(0,K,S):: IF S=0 THEN GOTO 1030
1040 IF K>51 THEN GOTO 1030 ELSE IF K<49 THEN GOTO 1030
1050 ON K-48 GOTO 1060,1090,1120
1060 CALL CLEAR :: PRINT "WEAPONS" :: PRINT "PRESS ENTER TO EXIT"
1070 CALL KEY(0,K,S):: IF S=0 THEN GOTO 1070
1080 IF K=13 THEN GOTO 1000 ELSE 1060
1090 CALL CLEAR :: PRINT "STATS" :: PRINT "PRESS ENTER TO EXIT"
1100 CALL KEY(0,K,S):: IF S=0 THEN GOTO 1100
1110 IF K=13 THEN GOTO 1000 ELSE 1090
1120 CALL CLEAR :: GOTO 150
This was relatively simple and it was my first test to make a simple menu skeleton.
As you can see, I needed to have multiple sections of the same chunk of code (W,W1,S,S1) in order to handle what would happen if certain conditions were met. It worked very well (although I do not believe this particular example works anymore... since it was put into the game code {hybridized} I had to make some changes)... You can see the structure there. Love what TIdBiT did to the code, even though it looks wonky to me, it works beautifully.
So, I have lots of GOSUBS leading into other GOSUBS with multiple returns and the like in this Beryl code. It might get even more messy when I tear it apart and put it back together again... We will see. To give you a sense of what I'm talking about, I'll post the current incarnation of the code here.... pre-RESequence.
I have not found my completely-commented Notepad++ file yet, but here's the working code for the game as it stands.
To do next:
Work on status menu for the characters using the same "ALEV=RLEV" type plug-in conversion as in item menu
Also, FIX THE MENU ITEMS!!!!  LOOKING LIKE CRAP, WILL NOT CLEAR SCREEN BEFORE DISPLAYING MENU ITEM INFO
100 REM    LINK UP TO LOAD DATA INTO MEMORY
200 CALL LDAT
300 REM       DESIGNATE MAP AND CHARACTER START POINT
400 MX=1 :: MY=1
500 PX=18 :: PY=8
600 SPX=(PX-1)*8+1 :: SPY=(PY-1)*8+17
650 REM REMEMBER TO CHANGE HPO, MPO, and ELI in existing code
700 REM STATISTICS FOR PARTY
800 GLD=100 :: HPO=4 :: MPO=4 :: ELI=4 :: SCR=0
900 REM REPEATED STRINGS AND ITEMS
1000 EX$="PRESS ENTER TO EXIT"
1100 BS$="BROADSWORD"
1200 EXU$="^^^^^^^^^^^^^^^^^^^"
1300 REM PARTY BATTLE STATS FOR BERYL, REPTO, SKYLAR, and MARKUS
1400 BMHP=20 :: BHP=15 :: BMMP=20 :: BMP=5 :: BDEF=10 :: BATK=10 :: BMDEF=7 :: BMATK=4
1500 RMHP=16 :: RHP=5 :: RMMP=40 :: RMP=20 :: RDEF=3 :: RATK=4 :: RMDEF=10 :: RMATK=12
1600 MMHP=25 :: MHP=18 :: MMMP=0 :: MMP=0 :: MDEF=15 :: MATK=15 :: MMDEF=5 :: MMATK=0
1700 SMHP=12 :: SHP=5 :: SMMP=20 :: SMP=12 :: SDEF=5 :: SATK=4 :: SMDEF=9 :: SMATK=8
1710 REM LEVELS
1720 BLEV=1 :: RLEV=1 :: MLEV=1 :: SLEV=1
1800 REM       SET UP SCREEN AND BORDER FOR EXPLORATION
1900 CALL CLEAR
2000 CALL SCREEN(2)
2100 CALL HCHAR(9,1,101,32):: CALL HCHAR(24,1,101,32):: CALL VCHAR(9,1,97,16):: CALL VCHAR(9,32,97,16)
2200 CALL HCHAR(9,1,98):: CALL HCHAR(9,32,100):: CALL HCHAR(24,1,99):: CALL HCHAR(24,32,96)
2300 CALL CHAR(42,"193DD9FFD91924C3"):: CALL COLOR(2,16,2)
2400 GOSUB 10700
2500 REM       Beginning of main game loop
2600 CALL SETMAP(MX,MY)
2700 CALL SPRITE(#1,42,16,SPX,SPY)
2800 REM       CHARACTER ON SCREEN
2900 REM DISPLAY AT(PX,PY):CHR$(42);
3000 SPX=(PX-1)*8+1 :: SPY=(PY-1)*8+17
3100 CALL LOCATE(#1,SPX,SPY)
3200 REM       KEYBOARD SCAN
3300 CALL KEY(0,K,S):: IF S=0 THEN 3300
3400 REM   must add 2 to each column to compensate for the DISPLAY/GCHAR offset
3500 IF K=69 THEN CALL GCHAR(PX-1,PY+2,Q):: IF Q>104 THEN 3300 ELSE PX=PX-1 :: GOTO 4300
3600 IF K=83 THEN CALL GCHAR(PX,PY+1,Q):: IF Q>104 THEN 3300 ELSE PY=PY-1 :: GOTO 4300
3700 IF K=68 THEN CALL GCHAR(PX,PY+3,Q):: IF Q>104 THEN 3300 ELSE PY=PY+1 :: GOTO 4300
3800 IF K=88 THEN CALL GCHAR(PX+1,PY+2,Q):: IF Q>104 THEN 3300 ELSE PX=PX+1 :: GOTO 4300
3900 REM CHECK FOR THE MENU AND EXAMINE COMMANDS (space bar and "M" key)
4000 IF K=32 THEN GOSUB 5500
4100 IF K=77 THEN GOTO 7100
4200 GOTO 3300
4300 REM       this determines the boundaries onscreen and sets the map to be drawn by assembly routine
4400 REM       PX, PY are the current player's position on the screen
4500 REM       MX, MY are the designations for which map will be drawn
4600 IF PX<11 THEN PX=22 :: MY=MY-1 :: GOTO 5100
4700 IF PX>22 THEN PX=11 :: MY=MY+1 :: GOTO 5100
4800 IF PY<1 THEN PY=28 :: MX=MX-1 :: GOTO 5100
4900 IF PY>28 THEN PY=1 :: MX=MX+1 :: GOTO 5100
5000 GOTO 3000
5100 IF MX<1 THEN MX=1 ELSE IF MX>2 THEN MX=2
5200 IF MY<1 THEN MY=1 ELSE IF MY>6 THEN MY=6
5300 CALL DELSPRITE(#1)
5400 GOTO 2600
5500 REM "EXAMINE"
5600 DISPLAY AT(1,1):" ":" ":" ":" ":" ":" ":" ":" "
5700 DISPLAY AT(1,1):"WHICH DIRECTION?";
5800 CALL KEY(0,K,S):: IF S=0 THEN 5800
5900 IF K=69 THEN CALL GCHAR(PX-1,PY+2,Q):: GOSUB 6400 :: RETURN
6000 IF K=83 THEN CALL GCHAR(PX,PY+1,Q):: GOSUB 6400 :: RETURN
6100 IF K=68 THEN CALL GCHAR(PX,PY+3,Q):: GOSUB 6400 :: RETURN
6200 IF K=88 THEN CALL GCHAR(PX+1,PY+2,Q):: GOSUB 6400 :: RETURN
6300 GOTO 5800
6400 IF Q=115 THEN IT$=BS$ :: GOTO 6600
6500 DISPLAY AT(1,1):" " :: GOSUB 10700 :: RETURN
6600 DISPLAY AT(1,1):"YOU FOUND A ";IT$;:"ADD TO INVENTORY? (Y/N)";
6700 CALL KEY(0,K,S):: IF S=0 THEN 6700
6800 IF K=89 THEN DISPLAY AT(1,1):" ":" " :: GOSUB 10700 :: RETURN
6900 IF K=78 THEN DISPLAY AT(1,1):" ":" " :: GOSUB 10700 :: RETURN
7000 GOTO 6700
7100 REM  MENU
7200 CALL CLEAR :: CALL SCREEN(2):: CALL DELSPRITE(#1)
7300 CALL HCHAR(5,1,101,32):: CALL HCHAR(20,1,101,32):: CALL VCHAR(5,1,97,15):: CALL VCHAR(5,32,97,15)
7400 CALL HCHAR(5,1,98):: CALL HCHAR(5,32,100):: CALL HCHAR(20,1,99):: CALL HCHAR(20,32,96)
7500 GOSUB 10100:: GOSUB 10400
7600 DISPLAY AT(8,1):"1) ITEMS":"2) ARMOR":"3) WEAPONS":"4) SPELLS":"5) STATUS";
7700 CALL KEY(0,K,S):: IF S=0 THEN GOTO 7700
7750 IF K=13 THEN CALL CLEAR :: GOTO 2100
7800 IF K>54 THEN GOTO 7700 ELSE IF K<49 THEN GOTO 7700
7900 ON K-48 GOTO 8000,8400,8900,9300,9700
8000 REM ITEM MENU
8010 GOSUB 10100
8100 DISPLAY AT(1,12):"ITEMS";:: DISPLAY AT(2,12):"^^^^^" :: GOSUB 10400
8110 DISPLAY AT(8,1):"USE ON WHICH CHARACTER?";:"1) BERYL";:"2) REPTOSLICER";:"3) MARKUS";:"4) SKYLAR";
8111 CALL KEY(0,K,S):: IF S=0 THEN GOTO 8111
8112 IF K=13 THEN GOTO 7500
8113 IF K>52 THEN GOTO 8111 ELSE IF K<49 THEN GOTO 8111
8114 ON K-48 GOSUB 8125,8135,8145,8155
8115 GOTO 8000
8120 REM ACN=name, ANSP=name starting point, ANL=name length
8125 REM BERYL
8126 AMHP=BMHP :: AHP=BHP :: AMMP=BMMP :: AMP=BMP :: ACN$="BERYL" :: ANSP=12 :: ANL=5
8128 GOSUB 8177
8131 BHP=AHP :: BMP=AMP :: RETURN
8135 REM REPTO
8136 AMHP=RMHP :: AHP=RHP :: AMMP=RMMP :: AMP=RMP :: ACN$="REPTOSLICER" :: ANSP=9 :: ANL=11
8138 GOSUB 8177
8141 RHP=AHP :: RMP=AMP :: RETURN
8145 REM MARKUS
8146 AMHP=MMHP :: AHP=MHP :: AMMP=MMMP :: AMP=MMP :: ACN$="MARKUS" :: ANSP=12 :: ANL=6
8148 GOSUB 8177
8151 MHP=AHP :: MMP=AMP :: RETURN
8155 REM SKYLAR
8156 AMHP=SMHP :: AHP=SHP :: AMMP=SMMP :: AMP=SMP :: ACN$="SKYLAR" :: ANSP=12 :: ANL=6
8158 GOSUB 8177
8161 SHP=AHP:: SMP=AMP :: RETURN
8176 REM **THIS IS THE MEAT OF THE ITEM MENU CODE**
8177 GOSUB 10100 :: DISPLAY AT(1,ANSP):ACN$;:: CALL HCHAR(2,ANSP+2,94,ANL)
8179 GOSUB 10400
8181 DISPLAY AT(8,1):"1) POTION";HPO;:"2) ETHER";MPO;:"3) ELIXIR";ELI;
8183 DISPLAY AT(3,1):"HP:";AHP;"/";AMHP;:: DISPLAY AT(3,16):"MP:";AMP;"/";AMMP;
8184 CALL KEY(0,K,S):: IF S=0 THEN GOTO 8184
8185 IF K=13 THEN GOTO 8000
8187 IF K>51 THEN GOTO 8183 ELSE IF K<49 THEN GOTO 8183
8189 ON K-48 GOSUB 8195,8201,8207
8191 CALL SCREEN(16):: FOR I=1 TO 20 :: NEXT I :: CALL SCREEN(2)
8192 DISPLAY AT(3,1):"HP:";AHP;"/";AMHP;:: DISPLAY AT(3,16):"MP:";AMP;"/";AMMP;
8193 DISPLAY AT(8,1):"1) POTION";HPO;:"2) ETHER";MPO;:"3) ELIXIR";ELI;:: FOR I=1 TO 400 :: NEXT I
8194 RETURN
8195 IF HPO<1 THEN CALL SOUND(30,440,1):: HPO=0 :: GOTO 8181
8197 HPO=HPO-1 :: AHP=AHP+10 :: IF AHP>AMHP THEN AHP=AMHP
8199 RETURN
8201 IF MPO<1 THEN CALL SOUND(30,440,1):: MPO=0 :: GOTO 8181
8203 MPO=MPO-1 :: AMP=AMP+10 :: IF AMP>AMMP THEN AMP=AMMP
8205 RETURN
8207 IF ELI<1 THEN CALL SOUND(30,440,1):: ELI=0 :: GOTO 8181
8209 ELI=ELI-1 :: AHP=AHP+5 :: IF AHP>AMHP THEN AHP=AMHP
8211 AMP=AMP+5 :: IF AMP>AMMP THEN AMP=AMMP
8213 RETURN
8400 REM ARMOR MENU
8500 GOSUB 10100:: DISPLAY AT(1,12):"ARMOR";:: DISPLAY AT(2,12):"^^^^^" :: GOSUB 10400
8600 CALL KEY(0,K,S):: IF S=0 THEN GOTO 8600
8700 IF K=13 THEN GOTO 7500 ELSE 8600
8800 GOSUB 10100
8899 REM WEAPONS MENU
8900 GOSUB 10100 :: DISPLAY AT(1,11):"WEAPONS";:: DISPLAY AT(2,11):"^^^^^^^" :: GOSUB 10400
9000 CALL KEY(0,K,S):: IF S=0 THEN GOTO 9000
9100 IF K=13 THEN GOTO 7500 ELSE 9000
9200 GOSUB 10100
8299 REM SPELLS MENU
9300 GOSUB 10100 :: DISPLAY AT(1,12):"SPELLS";:: DISPLAY AT(2,12):"^^^^^^" :: GOSUB 10400
9400 CALL KEY(0,K,S):: IF S=0 THEN GOTO 9400
9500 IF K=13 THEN GOTO 7500 ELSE 9400
9600 GOSUB 10100
**** NEXT AREA OF WORK****
9696 REM STATUS MENU
9697 REM THIS IS THE NEXT AREA OF FOCUS... GET WORKING STATUS MENU GOING BY LOADING THE "A" SET WITH CHAR'S INFO
9698 REM **USE THESE: ALEV=BLEV :: AMHP=BMHP :: AHP=BHP :: AMMP=BMMP :: AMP=BMP :: ADEF=BDEF :: AATK=BATK :: AMDEF=BMDEF
9699 REM **AMATK=BMATK :: ACN$="BERYL" :: ANSP=14 :: ANL=5
9700 GOSUB 10100 :: DISPLAY AT(1,12):"STATUS";:: DISPLAY AT(2,12):"^^^^^^" :: GOSUB 10400
9800 CALL KEY(0,K,S):: IF S=0 THEN GOTO 9800
9900 IF K=13 THEN GOTO 7500 ELSE 9800
10000 CALL CLEAR :: GOTO 2100
10100 REM     CLEAR MENU INFO
10200 DISPLAY AT(8,1):" ":" ":" ":" ":" ":" " :: DISPLAY AT(1,1):" ":" ":" " :: DISPLAY AT(22,1):" ":" "
10300 RETURN
10400 REM MENU RETURN GAME STRING
10500 DISPLAY AT(22,5):EX$;:: DISPLAY AT(23,5):EXU$;
10600 RETURN
10700 REM SCREEN INFO DISPLAY
10800 DISPLAY AT(1,9):"FORESTIA"
10900 DISPLAY AT(2,1):"BERYL":"HP:";BHP:"MP:";BMP :: DISPLAY AT(2,9):"^^^^^^^^";
11000 DISPLAY AT(2,18):"REPTOSLICER" :: DISPLAY AT(3,18):"HP:";RHP :: DISPLAY AT(4,18):"MP:";RMP
11100 DISPLAY AT(6,1):"SKYLAR":"HP:";SHP:"MP:";SMP
11200 DISPLAY AT(6,18):"MARKUS" :: DISPLAY AT(7,18):"HP:";MHP :: DISPLAY AT(8,18):"MP:";MMP
11300 RETURN
11400 REM       **END MAIN GAME LOOP**
11500 REM       **SUB TO CALL THE ASSEMBLY ROUTINE TO LOAD MAP INTO MEMORY**
11600 SUB LDAT
11700 CALL INIT
11800 CALL LOAD("DSK1.NEWFORO")
11900 SUBEND
12000 REM       **SUB TO DRAW THE MAP ONSCREEN**
12100 SUB SETMAP(MX,MY)
12200 X=MX :: Y=MY
12300 IF ADR<>0 THEN 12600
12400 CALL PEEK(16382,P,Q)
12500 ADR=P*256+Q+2
12600 Y=Y-1 :: MAP=Y*2+X
12700 IF MAP<1 OR MAP>12 THEN SUBEXIT
12800 CALL LOAD(ADR,0,MAP)
12900 CALL LINK("DRAW")
13000 SUBEND
Not asking anyone to actually read the whole thing, but hopefully this will help give some sense of what I'm about to try here. :)
Again, thanks for TIdBiT... It'll make my life so much easier AFTER it makes my life a living hell for a while. LOL!!!
Lines 700-1720 are in-game variables
Lines 1900-2400 make up the primary display block
Lines 2600-5400 are the main game loop
Lines 5500-7000 make up the the "examine" block
Lines 7100-10000 are all the Menu block
Lines 10100-13000 are SUBs.
Like I said, no need to examine it all unless you're completely bored, but you can see some funky stuff Like:
Line 4000 GOSUBs Line 5500--which conditionally GOSUBs 6400, which GOSUBs 10700 which returns, returns, returns, all the way back to 4000. :)
Edited by Opry99er
Owen, you're still not taking advantage of the main strengths of TidBit: descriptive long comments and indentation. Remember you can break up long statements with a .. at the end of each so you can indent them, and yet they will still come out as a single statement in the final conversion. Here's what your code could look like. I did not tackle the labels though. It does make for longer listings, but IMHO much clearer and easier to follow ones.
// MENU
K: CALL KEY(0,K,S):: ..
   IF S=0 THEN ..
       GOTO K
   IF K>51 THEN ..
       GOTO K ..
   ELSE ..
       IF K<49 THEN ..
           GOTO K
   ON K-48 GOTO W,S,E
W: CALL CLEAR :: ..
   PRINT "WEAPONS" :: ..
W1: CALL KEY(0,K,S):: ..
    IF S=0 THEN ..
        GOTO W1
    IF K=13 THEN ..
        GOTO A ..
    ELSE ..
        W
S: CALL CLEAR :: ..
   PRINT "STATS" :: ..
S1: CALL KEY(0,K,S):: ..
    IF S=0 THEN ..
        GOTO S1
    IF K=13 THEN ..
        GOTO A ..
    ELSE ..
        S
E: CALL CLEAR :: ..
   GOTO 150
Yeah, longer labels would make it a lot more readable. Especially if you're coming back to your code at a later point in time and you have to figure out what each label stood for.
Something like this might make sense maybe?
// MENU
PRINT_MENU:	CALL CLEAR :: CALL SCREEN(2)
SELECT_ITEM: 	CALL KEY(0,K,S):: ..
		IF S=0 THEN ..
    			GOTO SELECT_ITEM
		IF K>51 THEN ..
       			GOTO SELECT_ITEM ..
   		ELSE ..
       			IF K<49 THEN ..
           			GOTO SELECT_ITEM
   		ON K-48 GOTO PRINT_WEAPONS, STATS, EXIT_MENU
PRINT_WEAPONS:	CALL CLEAR :: ..
SELECT_WEAPON: 	CALL KEY(0,K,S):: ..
		IF S=0 THEN ..
        		GOTO SELECT_WEAPON
    		IF K=13 THEN ..
        		GOTO PRINT_MENU ..
    		ELSE ..
        		PRINT_WEAPONS
PRINT_STATS:	CALL CLEAR :: ..
   		PRINT "STATS" :: ..
SELECT_STAT: 	CALL KEY(0,K,S):: ..
    		IF S=0 THEN ..
        		GOTO SELECT_STAT
    		IF K=13 THEN ..
        		GOTO PRINT_MENU ..
    		ELSE ..
        		PRINT_STATS
EXIT_MENU:	CALL CLEAR :: ..
   		GOTO 150
The funny thing is, At first glance, I understood your BASIC listing more clearly than the TIdBiT source, Vorticon... But thats because of my lack of knowledge of higher level languages.
When I translate this over myself, however, I have a feeling I.will grasp it so much better... And moving forward, I'll likely do all my XB in TIdBiT.
Edited by Opry99er
Owen, have you ever programmed in anything other than TI BASIC/XB? If not, you will need to unlearn a lot of inherent bad that comes with any ROM BASIC from the 80's computers. Formatting you code helps you read it and keep the parts of it logically organized. Formatting code is for humans (the computer does not care) and is arguably as important as structuring written text. Imagine trying to read a book that has no sentence, paragraph, or chapter structure.
Some format tips:
Use descriptive labels. TidBit replaces labels with line numbers, so their length has no impact on your code or memory use. This is not the case for variables though, and unfortunately shorter is better in that case (a side effect of using a ROM BASIC.)
Put labels on their own line. A label simply "names" a point in your code that you can refer to.
Use indentation to help you see what code gets executed based on a logical path. An "IF-THEN" is the easiest example:
IF A<1 THEN ..
    A=1 ..
ELSE IF A>32 THEN ..
   A=32
ENDIF
To most people that is easier to read than:
IF A<1 THEN A=1 ELSE IF A>32 THEN A=32
Arguably this is not a very complex example, so the advantage might not be as clear. Loops make it more clear though.
10 RUNNING=1
20 IF RUNNING<>1 THEN 100
20 FOR Y=1 TO 24
30 FOR X=1 TO 32
40 CALL HCHAR(X,Y,32)
50 NEXT X
60 NEXT Y
70 INKEY$(0,K,S)
80 IF S<>0 THEN RUNNING=0
90 GOTO 20
100 END
Again, smaller examples are not quite as tedious to read, but still, with a little formatting is is easier to follow the flow (and see the simulated "while" loop that TI XB does not have):
RUNNING=1
// Main Loop
main_while: IF RUNNING<>1 THEN main_while_end
    FOR Y=1 TO 24
        FOR X=1 TO 32
            CALL HCHAR(X,Y,32)
        NEXT X
    NEXT Y
    INKEY$(0,K,S)
    GOTO main_while
main_while_end:
END
It is easier to see what happens inside each loop, especially when the loop body grows and you can't always see the "NEXT" on the same screen as the FOR. Anyway, these are small and contrived examples, but it will make a difference as you code grows.
Actually, BASIC is a high-level language. Language "level" typically refers to how *close* to assembly language (i.e. the CPU and direct hardware access) the language is. A language's syntax and/or formatting have nothing to do with its "level".
Got a chunk converted over tonight.... No indentation yet, but what's there WILL convert (I'm hoping)
It's actually going more quickly than I thought.... But I really haven't gotten into the real spaghetti of the code yet.
In the code box below, you can see I started at the top of the code, doing sections of subroutines as they got referenced in the loop. The ones I haven't done yet are the biggies... Examine and Menu. Most of the other stuff will get very simplified as I go forward. Let me know what you think so far!
Beryl Reichardt TIdBiT transfer workstation:
3/18/15
// first  thing to do is call the link up to load the map data into memory
InitLoad MapData:
CALL LDAT
PlayerStartup:
// Give player a "place to start"
// MX and MY are which map in the world are going to be drawn.  In this case, it's 1,1
// PX&PY are the players' X location and Y location on the screen, SPX and SPY are the location of the SPRITE corresponding to the character position
MX=1 :: MY=1
PX=18 :: PY=8
// These are party inventory... Starting with 100 gold, 4 health potions, 4 magic potions, 4 Elixirs, and zero scrolls
// These are repeated strings.  Currently there are only two, but there will be many more to come
BS$="BROADSWORD"
// These are Individual statistics for Beryl, Skylar, and Markus.
// MHP is max health power, HP is current health power
// MMP is max magic power, MP is current magic power
// DEF and ATK are the current stats for defense and attack
// MDEF and MATK are max stats for defense and attack
//These are the player "levels".  When the player level goes up, so will most of the maximum stats above.
Setscreen:
// set up screen and border for exploration routines
CALL CLEAR
CALL SCREEN(2) !black screen
CALL HCHAR(9,1,101,32):: CALL HCHAR(24,1,101,32):: CALL VCHAR(9,1,97,16):: CALL VCHAR(9,32,97,16) !border around viewport
CALL HCHAR(9,1,98):: CALL HCHAR(9,32,100):: CALL HCHAR(24,1,99):: CALL HCHAR(24,32,96) !corners
CALL CHAR(42,"193DD9FFD91924C3"):: CALL COLOR(2,16,2) !CHAR(42) is the little character representation so far... may change soon
GOSUB TopInfo
TopGameLoop:
// This is the very top of the game loop.
CALL SETMAP(MX,MY)
MidGameLoop:
// midpoint for returns from bottom of loop
// displays the character on screen based on player position
MidgameLoop Keyscan:
GOSUB KeyScan
//upon keypress, up down, left, right checking for tiles in the direction selected
//must be a tile below (lower than)CHR$(104)  to allow motion
//must add 2 to each column to compensate for the DISPLAY/GCHAR offset
IF K=69 THEN CALL GCHAR(PX-1,PY+2,Q):: IF Q>104 THEN GOTO MidgameLoop Keyscan ELSE PX=PX-1 :: GOTO CheckBoundary
IF K=83 THEN CALL GCHAR(PX,PY+1,Q):: IF Q>104 THEN GOTO MidgameLoop Keyscan ELSE PY=PY-1 :: GOTO CheckBoundary
IF K=68 THEN CALL GCHAR(PX,PY+3,Q):: IF Q>104 THEN GOTO MidgameLoop Keyscan ELSE PY=PY+1 :: GOTO CheckBoundary
IF K=88 THEN CALL GCHAR(PX+1,PY+2,Q):: IF Q>104 THEN GOTO MidgameLoop Keyscan ELSE PX=PX+1 :: GOTO CheckBoundary
//If M is pressed, goto menu block, if space bar, goto examine block
IF K=32 THEN GOSUB Examine
IF K=77 THEN GOTO MainMenu
CheckBoundary:
// this determines the boundaries onscreen and sets the map to be drawn by assembly routine
// PX, PY are the current player's position on the screen
// MX, MY are the designations for which map will be drawn
IF PX<11 THEN PX=22 :: MY=MY-1 :: GOTO CheckMap !if player walks off top of screen, place character on opposite side of screen
IF PX>22 THEN PX=11 :: MY=MY+1 :: GOTO CheckMap !if player walks off bottom of screen, place character on opposite side of screen
IF PY<1 THEN PY=28 :: MX=MX-1 :: GOTO CheckMap !if player walks off left of screen, place character on opposite side of screen
IF PY>28 THEN PY=1 :: MX=MX+1 :: GOTO CheckMap !if player walks off right of screen, place character on opposite side of screen
GOTO MidGameLoop
CheckMap:
CALL DELSPRITE(#1)
GOTO TopGameLoop
//End game Loop!!!!!!!!!!!!//
//Subroutines follow
TopInfo:
//this displays all necessary information at the top of the screen during gameplay
RETURN
Keyscan:
CALL KEY(0,K,S):: IF S=0 THEN Keyscan
RETURN
**This is the remainder of the code I have**
**not converted yet.  Most of these lines **
**or sections of lines are referenced in  **
**the lines above, which are already      **
**converted.                              **
5500 REM "EXAMINE"
6300 GOTO 5800
7000 GOTO 6700
7100 REM  MENU
8000 REM ITEM MENU
8010 GOSUB 10100
8115 GOTO 8000
8125 REM BERYL
8128 GOSUB 8177
8135 REM REPTO
8138 GOSUB 8177
8145 REM MARKUS
8148 GOSUB 8177
8155 REM SKYLAR
8158 GOSUB 8177
8179 GOSUB 10400
8194 RETURN
8199 RETURN
8205 RETURN
8213 RETURN
8400 REM ARMOR MENU
8800 GOSUB 10100
9200 GOSUB 10100
9600 GOSUB 10100
10300 RETURN
10600 RETURN
11300 RETURN
11600 SUB LDAT
11700 CALL INIT
11900 SUBEND
12200 X=MX :: Y=MY
12500 ADR=P*256+Q+2
13000 SUBEND
Edited by Opry99er
The first thing that jumps out at me is that you are using spaces in some of your labels. Since humans use space to denote separation between words, that characteristic almost always transfers to programming languages. Labels can have A..Z, a..z, 0..9, -, _ and must start with a non-numeric character. They are also case sensitive (I think).
The other thing you can do to help you find translation problems is to add your code in chunks. Get the fist 50 lines or so working, then add another 50, etc.
Switched the MidgameLoop Keyscan and InitLoad MapData to eliminate the " " character. These were the only offending labels.
I'll be working more on this tonight... Hopefully get it done and tested by Saturday night. Sure will make life easier. :)
Edited by Opry99er
Hmm... Ill try that, for sure...
I had my old Notepad++ dialed in just the way I wanted it with indentation, spacing, and syntax highlighting.
(Indentation was primarily on the REM comments that didnt have a line number associated with them)
Edited by Opry99er
Tried different indentation method, also changed incorrect labels, finished converting the "Examine" function. Let me know how this looks (so far)
3/18/15
InitLoad-MapData:
     CALL LDAT
PlayerStartup:
          // SPX and SPY are the location of the SPRITE corresponding to the character position
     MX=1 :: MY=1
     PX=18 :: PY=8
     BS$="BROADSWORD"
Setscreen:
     CALL CLEAR
     GOSUB TopInfo
                ****BEGIN GAME LOOP****
TopGameLoop:
     CALL SETMAP(MX,MY)
MidGameLoop:
MidgameLoop-Keyscan:
     GOSUB KeyScan
     IF K=69 THEN CALL GCHAR(PX-1,PY+2,Q):: IF Q>104 THEN GOTO MidgameLoop-Keyscan ELSE PX=PX-1 :: GOTO CheckBoundary
     IF K=83 THEN CALL GCHAR(PX,PY+1,Q):: IF Q>104 THEN GOTO MidgameLoop-Keyscan ELSE PY=PY-1 :: GOTO CheckBoundary
     IF K=68 THEN CALL GCHAR(PX,PY+3,Q):: IF Q>104 THEN GOTO MidgameLoop-Keyscan ELSE PY=PY+1 :: GOTO CheckBoundary
     IF K=88 THEN CALL GCHAR(PX+1,PY+2,Q):: IF Q>104 THEN GOTO MidgameLoop-Keyscan ELSE PX=PX+1 :: GOTO CheckBoundary
CheckBoundary:
     GOTO MidGameLoop
CheckMap:
     CALL DELSPRITE(#1)
     GOTO TopGameLoop
          //END GAME LOOP!!!!!!!!!!!!//
          ***SUBROUTINES BELOW***
          //BEGIN EXAMINE LOOP//
Examine:
ExamineKeyscan:
     GOSUB Keyscan
     IF K=69 THEN CALL GCHAR(PX-1,PY+2,Q):: GOSUB ExamineCheck :: RETURN
     IF K=83 THEN CALL GCHAR(PX,PY+1,Q):: GOSUB ExamineCheck :: RETURN
     IF K=68 THEN CALL GCHAR(PX,PY+3,Q):: GOSUB ExamineCheck :: RETURN
     IF K=88 THEN CALL GCHAR(PX+1,PY+2,Q):: GOSUB ExamineCheck :: RETURN
     GOTO ExamineKeyscan
ExamineCheck:
          //This is the "YES" or "correct tile, IS an item" bit
     IF Q=115 THEN IT$=BS$ :: GOTO ItemYesFlag
          //This is the "NO" or "incorrect tile, is not an item" bit
     DISPLAY AT(1,1):" " :: GOSUB TopInfo :: RETURN
ItemYesFlag:
MidExamineLoop-Keyscan:
     GOSUB Keyscan
     IF K=89 THEN DISPLAY AT(1,1):" ":" " :: GOSUB TopInfo :: RETURN
     IF K=78 THEN DISPLAY AT(1,1):" ":" " :: GOSUB TopInfo :: RETURN
     GOTO MidExamineLoop-Keyscan
     //END EXAMINE LOOP//
TopInfo:
     RETURN
Keyscan:
     RETURN
**converted.                              **
7100 REM  MENU
8000 REM ITEM MENU
8010 GOSUB 10100
8115 GOTO 8000
8125 REM BERYL
8128 GOSUB 8177
8135 REM REPTO
8138 GOSUB 8177
8145 REM MARKUS
8148 GOSUB 8177
8155 REM SKYLAR
8158 GOSUB 8177
8179 GOSUB 10400
8194 RETURN
8199 RETURN
8205 RETURN
8213 RETURN
8400 REM ARMOR MENU
8800 GOSUB 10100
9200 GOSUB 10100
9600 GOSUB 10100
10300 RETURN
10600 RETURN
11300 RETURN
11600 SUB LDAT
11700 CALL INIT
11900 SUBEND
12200 X=MX :: Y=MY
12500 ADR=P*256+Q+2
13000 SUBEND
Edited by Opry99er
This looks much better Owen :)
In the end it all comes down to personal preference. For me, I prefer not to overload the code lines, and therefore put every statement on its own line which I find clearer to read, at the expense of longer listings.
Regardless, I'm really glad to see you coding again. Your enthusiasm is contagious!
"Mongo only pawn--in game of life"
I am in the company of giants... I wish only to contribute in whatever small way I can.
Beryl will take a while... My project game plan is underway, code is getting reorganized,then I get to start work on my maps in Magellan.
TIdBiT is going to allow for much more flexibility. Then I can expand it freely without line number restrictions. :)
Total freedom.
Well, tonight I should be able to finish the conversion and do some testing and debugging. Assuming, of course, I do not get off work too late. When I get it working, I'll post up the source and TIdBiT output code. Hopefully this little tangent in this thread will help future users convert their code to TIdBiT as well.
It is looking pretty good. Something you might want to consider is the line continuation feature (double period):
This code:
Can be written like this:
    // if player walks off top of screen, place character on opposite side of screen
    IF PX<11 THEN ..
        PX=22 :: ..
        MY=MY-1 :: ..
        GOTO CheckMap
    ENDIF
    // if player walks off bottom of screen, place character on opposite side of screen
    IF PX>22 THEN ..
        PX=11 :: ..
        MY=MY+1 :: ..
        GOTO CheckMap
    ENDIF
    // if player walks off left of screen, place character on opposite side of screen
    IF PY<1 THEN ..
        PY=28 :: ..
        MX=MX-1 :: ..
        GOTO CheckMap
    ENDIF
    // if player walks off right of screen, place character on opposite side of screen
    IF PY>28 THEN ..
        PY=1 :: ..
        MX=MX+1 :: ..
        GOTO CheckMap
    ENDIF
The ENDIF if totally optional and is a TidBit specific keyword that is just ignored, however it helps keep track of the end of a logical block (kind of like the "NEXT" in a for/next loop, etc).
