+adamantyr Posted December 12, 2010 Share Posted December 12, 2010 Here's another obscure game. It was one of the first games we played regularly on the TI, loading it from cassette. I found it pretty fun as a kid, and it's still rather challenging now. As to where it came from, I can't remember... we must have gotten it from a friend on cassette. The game was adapted for the TI from another source, and the names of the adapters are on it as well. Anyway, this is another surprisingly deep BASIC game with good game play and some challenging victory conditions. And if you think I'm lying, go ahead and try it and see what happens when you hit an underground spring... As a special treat, I have two versions: the original BASIC and a version that works in Extended BASIC by forcing the use of the extra character sets through a clever set of machine language routines. This was a MERGE script I got from the Yahoo 99'ers group some time ago. Not sure where it's gotten off to... BASIC version: 100 REM ********* 110 REM * MINER * 120 REM ********* 130 REM TRANSLATED BY SAM PINCUS 140 REM REVISED BY SEAN MCGUINESS 150 REM ENHANCED BY SEAN MCGUINESS & TYLER CARLSON ADAPTED FOR 99/4A BY LEIF COLSON,EVERGREEN,CO.80439 160 RANDOMIZE 170 DIM C(15,27) 180 GOSUB 1900 190 CALL CLEAR 200 GOSUB 2090 210 Y=5 220 X=20 230 CALL KEY(1,I,ST) 240 IF ST=0 THEN 230 250 IF I=1 THEN 2800 260 IF(I+1=1)+(I=2)+(I=3)+(I=5)THEN 270 ELSE 230 270 IF(X>30)*(I=3)THEN 230 280 IF(Y=5)*(I=5)THEN 230 290 IF Y>5 THEN 630 300 REM ABOVE GROUND 310 IF X<13 THEN 490 320 REM NOT IN BANK 330 IF(X=31)*(I+1=1)THEN 690 340 Z=32-70*(X=31) 350 CALL HCHAR(5,X,Z) 360 X=X+(I=2)-(I=3) 370 IF X=31 THEN 410 380 IF X<13 THEN 430 390 CALL HCHAR(5,X,101) 400 GOTO 230 410 CALL HCHAR(5,31,103) 420 GOTO 230 430 REM BANK 440 CALL SOUND(250,220,4) 450 CALL SOUND(500,262,2) 460 CALL SOUND(125,220,4) 470 CALL SOUND(375,233,2) 480 CALL SOUND(600,262,2) 490 X=12 500 IF GC=0 THEN 580 510 FOR I=1 TO GC 520 CALL SOUND(100,1760,6,2638,6,-5,6) 530 CALL SOUND(125,44377,30) 540 NEXT I 550 M=M+GC*GP 560 GC=0 570 GOSUB 1740 580 IF I<>3 THEN 230 590 X=13 600 CALL HCHAR(5,13,101) 610 GOTO 230 620 REM UNDERGROUND 630 IF(I=2)+(I=3)THEN 910 640 REM MOVE VERTICALLY 650 IF X<31 THEN 810 660 REM IN ELEVATOR 670 IF Y<20 THEN 690 680 IF I+1=1 THEN 230 690 CALL SOUND(1000,110,4,-7,16) 700 Z=32-112*(Y>5) 710 CALL HCHAR(Y,X,Z) 720 Y=Y+(I=5)-(I+1=1) 730 CALL HCHAR(Y,31,146) 740 IF Y=5 THEN 780 750 CALL VCHAR(5,31,105) 760 IF Y<7 THEN 780 770 CALL VCHAR(6,31,148,Y-6) 780 EP=Y 790 GOTO 230 800 REM IN MINE 810 IF(Y=20)*(I+1=1)+(Y=6)*(I=5)THEN 230 820 IF(X=4)*(I=2)THEN 880 830 IF X=31 THEN 860 840 CALL HCHAR(Y,X,144) 850 Y=Y+(I=5)-(I+1=1) 860 X=X+(I=2)-(I=3) 870 ON C(Y-6,X-4)+1 GOTO 1070,1150,1130,950 880 CALL HCHAR(Y,X,147) 890 GOTO 230 900 REM MOVE HORIZONTALLY 910 Z=144-(X=31) 920 CALL HCHAR(Y,X,Z) 930 IF(X>29)*(I=3)THEN 1000 940 GOTO 810 950 X=X-(I=2)+(I=3) 960 Y=Y-(I=5)+(I+1=1) 970 CALL HCHAR(Y,X,147) 980 GOTO 230 990 REM MOVE INTO ELEVATOR 1000 IF Y<>EP THEN 1030 1010 CALL HCHAR(Y,X,144) 1020 X=31 1030 Z=146-(X<31) 1040 CALL HCHAR(Y,X,Z) 1050 GOTO 230 1060 REM DIG 1070 M=M-5 1080 FOR I=1 TO 3 1090 CALL SOUND(100,-7,4) 1100 CALL SOUND(250,44377,30) 1110 NEXT I 1120 GOSUB 1820 1130 GOTO 1700 1140 REM PROSPECT 1150 FOR I=1 TO 3 1160 CALL SOUND(100,-7,4) 1170 CALL SOUND(250,44377,30) 1180 NEXT I 1190 Z=INT(RND*5)+1 1200 ON Z GOTO 1210,1280,1310,1360,1490 1210 A$="EASY DIGGING" 1220 M=M-1 1230 GOSUB 2610 1240 GOSUB 1740 1250 A$=" " 1260 GOSUB 2610 1270 GOTO 1700 1280 A$="SOLID ROCK" 1290 M=M-25 1300 GOTO 1230 1310 I=INT(RND*3)+1 1320 A$=STR$(I)&" OZ. NUGGET" 1330 M=M-5 1340 GC=GC+I 1350 GOTO 1230 1360 A$="UNDERGROUND SPRING" 1370 M=M-5 1380 GOSUB 2610 1390 FOR V=20 TO Y+1 STEP-1 1400 FOR H=4 TO 30 1410 IF C(V-6,H-4)<>2 THEN 1450 1420 CALL HCHAR(V,H,136) 1430 C(V-6,H-4)=3 1440 CALL SOUND(-550,-5,2) 1450 NEXT H 1460 NEXT V 1470 GOTO 1240 1480 REM 1490 A$="CAVE IN" 1500 M=M-1 1510 FOR I=1 TO 2 1520 CALL SOUND(300,-1,2) 1530 CALL SOUND(500,-3,6) 1540 NEXT I 1550 IF INT(RND*5)<>1 THEN 1580 1560 A$=A$&", LOST ALL YOUR GOLD" 1570 GC=0 1580 GOSUB 2610 1590 FOR V=Y-8 TO Y-4 1600 IF(V<0)+(V>15)THEN 1670 1610 FOR H=X-6 TO X-2 1620 IF(H>27)+(H<0)THEN 1660 1630 IF C(V,H)<>2 THEN 1660 1640 C(V,H)=0 1650 CALL HCHAR(V+6,H+4,96) 1660 NEXT H 1670 NEXT V 1680 GOTO 1240 1690 REM DUG OUT PROSPECT 1700 CALL HCHAR(Y,X,147) 1710 C(Y-6,X-4)=2 1720 GOTO 230 1730 REM DISPLAY $ ROUTINE 1740 GP=INT(RND*600)+300 1750 IF GP<501 THEN 1740 1760 A$=STR$(GP) 1770 B$=STR$(GC)&" " 1780 FOR I=1 TO 3 1790 CALL HCHAR(22,15+I,ASC(SEG$(A$,I,1))) 1800 CALL HCHAR(23,15+I,ASC(SEG$(B$,I,1))) 1810 NEXT I 1820 C$=STR$(M)&" " 1830 FOR I=1 TO 4 1840 CALL HCHAR(23,24+I,ASC(SEG$(C$,I,1))) 1850 NEXT I 1860 IF M>7000 THEN 2670 1870 IF M<=0 THEN 2830 1880 RETURN 1890 REM START UP 1900 CALL CLEAR 1901 CALL SCREEN(4) 1910 CALL CHAR(152,"3C7EFFFFFFFF7E3C") 1920 CALL COLOR(16,11,1) 1930 PRINT TAB(12);"MINER": : : : : : : : : 1940 PRINT " TI-99/4 TRANSLATION BY":" SEAN MCGUINESS": :"REVISED BY: SEAN MCGUINESS" 1950 PRINT: :"ENHANCED BY: SEAN MCGUINESS AND TYLER CALSON":"2/20/85": :" ADAPTED FOR TI-99/4A":"" 1960 FOR I=1 TO 1000 1970 NEXT I 1971 INPUT " NEED INSTRUCTIONS(Y/N)?":A$ 1972 IF A$<>"Y" THEN 2080 1980 CALL CLEAR 1990 PRINT "YOU HAVE INHERITED A MINE WITH 30 POSSIBLE VEINS OF ORE(";CHR$(152);"). IF YOU CAN PROVE THE" 2000 PRINT "MINE IS WORTHWHILE, YOU CAN SELL IT TO A BIG MINING CO. YOU CAN ONLY GET UNDERGROUND" 2010 PRINT "VIA ELEVATOR. YOU CANNOT DIGWHEN YOU ARE ABOVE GROUND." 2020 PRINT "USE THE 4 ARROW KEYS TO MOVETHE MINER. USE THE UP AND DOWN ARROWS TO CONTROL THE" 2030 PRINT "ELEVATOR (AT THE RIGHT OF THE SCREEN). BEWARE: YOU CANBE TRAPPED. IF YOU GIVE UP," 2040 PRINT "HIT KEY(A) FOR AID. IT COSTS$5 EVERY TIME YOU DIG. IF YOU FIND ANY GOLD, BRING IT TO THE BANK." 2050 PRINT:" GOOD LUCK":" PRESS ANY KEY TO CONTINUE" 2060 CALL KEY(0,KE,ST) 2070 IF ST=0 THEN 2060 2080 RETURN 2090 CALL CHAR(96,"FFFFFFFFFFFFFFFF") 2100 CALL CHAR(100,"01010101010101FF") 2110 CALL COLOR(9,2,1) 2120 CALL CHAR(97,"8080808080808080") 2130 CALL CHAR(98,"00000000000000FF") 2140 CALL CHAR(99,"0101010101010101") 2150 CALL CHAR(144,"0") 2160 CALL COLOR(15,2,16) 2170 A$="FF010101010101FF" 2180 CALL CHAR(102,A$) 2190 CALL CHAR(145,A$) 2200 A$="FF313179B5B549FF" 2210 CALL CHAR(103,A$) 2220 CALL CHAR(146,A$) 2240 CALL CHAR(101,"183C183C5A5A2442") 2250 CALL CHAR(147,"183C183C5A5A2442") 2260 A$="1010101010101010" 2270 CALL CHAR(105,A$) 2280 CALL CHAR(148,A$) 2290 EP=0 2300 M=250 2310 CALL COLOR(14,5,5) 2320 CALL CLEAR 2330 CALL COLOR(16,11,2) 2340 PRINT " 1ST BANK": : : : : : : : : : : : : : : : : : :"$/OZ OF GOLD=" 2350 PRINT " GOLD OUNCES=";TAB(18);"CASH=" 2360 CALL HCHAR(6,1,96,480) 2370 CALL VCHAR(6,32,144,15) 2380 CALL VCHAR(6,31,144,15) 2390 CALL HCHAR(1,3,98,10) 2400 CALL VCHAR(2,3,97,4) 2410 CALL VCHAR(2,12,99,4) 2420 CALL HCHAR(3,12,100) 2430 CALL VCHAR(4,11,99,2) 2440 CALL HCHAR(5,20,101) 2450 CALL HCHAR(5,31,102) 2460 CALL HCHAR(4,31,98) 2470 CALL HCHAR(5,32,97) 2480 FOR I=1 TO 30 2490 H=INT(RND*15) 2500 V=INT(RND*26) 2510 CALL SOUND(-200,330+20*I,INT(H/5)) 2520 IF C(H,V)THEN 2490 2530 C(H,V)=1 2540 CALL HCHAR(H+6,V+4,152) 2550 NEXT I 2560 CALL SOUND(800,262,1,524,0,796,1) 2570 CALL SOUND(900,262,0,796,1,349,0) 2580 GOSUB 1740 2590 REM PRINT A LINE 2600 RETURN 2610 CALL HCHAR(24,3,32,29) 2620 FOR I=1 TO LEN(A$) 2630 CALL HCHAR(24,4+I,ASC(SEG$(A$,I,1))) 2640 NEXT I 2650 RETURN 2660 REM WON 2670 CALL CLEAR 2680 FOR I=1 TO 20 2690 CALL SCREEN(3+INT(RND*12)) 2700 PRINT TAB(I);"CASH $" 2710 CALL SOUND(80,330+20*I,0) 2720 NEXT I 2730 CALL CLEAR 2740 PRINT "! ! ! Y I P P E E ! ! !" 2750 CALL SOUND(700,262,1,524,0,796,1) 2760 CALL SOUND(800,262,0,796,1,349,0) 2770 PRINT "YOU CAN NOW SELL THIS CLAIM FOR LOTS OF MONEY TO A BIG MINING CO. AND RETIRE ON THEROYALTIES!": : : 2780 PRINT " PLAY AGAIN (Y/N)?" 2785 CALL SCREEN(4) 2786 GOTO 2840 2790 REM QUIT 2800 CALL CLEAR 2810 PRINT "TOO BAD, THE OLD MINE JUST DIDN'T PAN OUT.": : : : : : 2820 REM BANKRUPT 2830 PRINT "YOU WENT BANKRUPT, DO YOU WANT TO TRY AGAIN(Y/N)?" 2840 CALL KEY(2,KE,ST) 2850 IF ST=0 THEN 2840 2860 IF KE=15 THEN 2960 2870 IF KE=18 THEN 2890 2880 GOTO 2840 2890 CALL CLEAR 2900 FOR I=0 TO 14 2910 FOR J=0 TO 26 2920 C(I,J)=0 2930 NEXT J 2940 NEXT I 2950 GOTO 190 2960 STOP Extended BASIC version: 1 CALL VDPUTIL3 100 REM ********* 110 REM * MINER * 120 REM ********* 130 REM TRANSLATED BY SAM PINCUS 140 REM REVISED BY SEAN MCGUINESS 150 REM ENHANCED BY SEAN MCGUINESS & TYLER CARLSON ADAPTED FOR 99/4A BY LEIF COLSON,EVERGREEN,CO.80439 160 RANDOMIZE 170 DIM C(15,27) 180 GOSUB 1900 190 CALL CLEAR 200 GOSUB 2090 210 Y=5 220 X=20 230 CALL KEY(1,I,ST) 240 IF ST=0 THEN 230 250 IF I=1 THEN 2800 260 IF(I+1=1)+(I=2)+(I=3)+(I=5)THEN 270 ELSE 230 270 IF(X>30)*(I=3)THEN 230 280 IF(Y=5)*(I=5)THEN 230 290 IF Y>5 THEN 630 300 REM ABOVE GROUND 310 IF X<13 THEN 490 320 REM NOT IN BANK 330 IF(X=31)*(I+1=1)THEN 690 340 Z=32-70*(X=31) 350 CALL HCHAR(5,X,Z) 360 X=X+(I=2)-(I=3) 370 IF X=31 THEN 410 380 IF X<13 THEN 430 390 CALL HCHAR(5,X,101) 400 GOTO 230 410 CALL HCHAR(5,31,103) 420 GOTO 230 430 REM BANK 440 CALL SOUND(250,220,4) 450 CALL SOUND(500,262,2) 460 CALL SOUND(125,220,4) 470 CALL SOUND(375,233,2) 480 CALL SOUND(600,262,2) 490 X=12 500 IF GC=0 THEN 580 510 FOR I=1 TO GC 520 CALL SOUND(100,1760,6,2638,6,-5,6) 530 CALL SOUND(125,44377,30) 540 NEXT I 550 M=M+GC*GP 560 GC=0 570 GOSUB 1740 580 IF I<>3 THEN 230 590 X=13 600 CALL HCHAR(5,13,101) 610 GOTO 230 620 REM UNDERGROUND 630 IF(I=2)+(I=3)THEN 910 640 REM MOVE VERTICALLY 650 IF X<31 THEN 810 660 REM IN ELEVATOR 670 IF Y<20 THEN 690 680 IF I+1=1 THEN 230 690 CALL SOUND(1000,110,4,-7,16) 700 Z=32-112*(Y>5) 710 CALL HCHAR(Y,X,Z) 720 Y=Y+(I=5)-(I+1=1) 730 CALL HCHAR(Y,31,146) 740 IF Y=5 THEN 780 750 CALL VCHAR(5,31,105) 760 IF Y<7 THEN 780 770 CALL VCHAR(6,31,148,Y-6) 780 EP=Y 790 GOTO 230 800 REM IN MINE 810 IF(Y=20)*(I+1=1)+(Y=6)*(I=5)THEN 230 820 IF(X=4)*(I=2)THEN 880 830 IF X=31 THEN 860 840 CALL HCHAR(Y,X,144) 850 Y=Y+(I=5)-(I+1=1) 860 X=X+(I=2)-(I=3) 870 ON C(Y-6,X-4)+1 GOTO 1070,1150,1130,950 880 CALL HCHAR(Y,X,147) 890 GOTO 230 900 REM MOVE HORIZONTALLY 910 Z=144-(X=31) 920 CALL HCHAR(Y,X,Z) 930 IF(X>29)*(I=3)THEN 1000 940 GOTO 810 950 X=X-(I=2)+(I=3) 960 Y=Y-(I=5)+(I+1=1) 970 CALL HCHAR(Y,X,147) 980 GOTO 230 990 REM MOVE INTO ELEVATOR 1000 IF Y<>EP THEN 1030 1010 CALL HCHAR(Y,X,144) 1020 X=31 1030 Z=146-(X<31) 1040 CALL HCHAR(Y,X,Z) 1050 GOTO 230 1060 REM DIG 1070 M=M-5 1080 FOR I=1 TO 3 1090 CALL SOUND(100,-7,4) 1100 CALL SOUND(250,44377,30) 1110 NEXT I 1120 GOSUB 1820 1130 GOTO 1700 1140 REM PROSPECT 1150 FOR I=1 TO 3 1160 CALL SOUND(100,-7,4) 1170 CALL SOUND(250,44377,30) 1180 NEXT I 1190 Z=INT(RND*5)+1 1200 ON Z GOTO 1210,1280,1310,1360,1490 1210 A$="EASY DIGGING" 1220 M=M-1 1230 GOSUB 2610 1240 GOSUB 1740 1250 A$=" " 1260 GOSUB 2610 1270 GOTO 1700 1280 A$="SOLID ROCK" 1290 M=M-25 1300 GOTO 1230 1310 I=INT(RND*3)+1 1320 A$=STR$(I)&" OZ. NUGGET" 1330 M=M-5 1340 GC=GC+I 1350 GOTO 1230 1360 A$="UNDERGROUND SPRING" 1370 M=M-5 1380 GOSUB 2610 1390 FOR V=20 TO Y+1 STEP-1 1400 FOR H=4 TO 30 1410 IF C(V-6,H-4)<>2 THEN 1450 1420 CALL HCHAR(V,H,136) 1430 C(V-6,H-4)=3 1440 CALL SOUND(-550,-5,2) 1450 NEXT H 1460 NEXT V 1470 GOTO 1240 1480 REM 1490 A$="CAVE IN" 1500 M=M-1 1510 FOR I=1 TO 2 1520 CALL SOUND(300,-1,2) 1530 CALL SOUND(500,-3,6) 1540 NEXT I 1550 IF INT(RND*5)<>1 THEN 1580 1560 A$=A$&", LOST ALL YOUR GOLD" 1570 GC=0 1580 GOSUB 2610 1590 FOR V=Y-8 TO Y-4 1600 IF(V<0)+(V>15)THEN 1670 1610 FOR H=X-6 TO X-2 1620 IF(H>27)+(H<0)THEN 1660 1630 IF C(V,H)<>2 THEN 1660 1640 C(V,H)=0 1650 CALL HCHAR(V+6,H+4,96) 1660 NEXT H 1670 NEXT V 1680 GOTO 1240 1690 REM DUG OUT PROSPECT 1700 CALL HCHAR(Y,X,147) 1710 C(Y-6,X-4)=2 1720 GOTO 230 1730 REM DISPLAY $ ROUTINE 1740 GP=INT(RND*600)+300 1750 IF GP<501 THEN 1740 1760 A$=STR$(GP) 1770 B$=STR$(GC)&" " 1780 FOR I=1 TO 3 1790 CALL HCHAR(22,15+I,ASC(SEG$(A$,I,1))) 1800 CALL HCHAR(23,15+I,ASC(SEG$(B$,I,1))) 1810 NEXT I 1820 C$=STR$(M)&" " 1830 FOR I=1 TO 4 1840 CALL HCHAR(23,24+I,ASC(SEG$(C$,I,1))) 1850 NEXT I 1860 IF M>7000 THEN 2670 1870 IF M<=0 THEN 2830 1880 RETURN 1890 REM START UP 1900 CALL CLEAR 1901 CALL SCREEN(4) 1910 CALL CHAR(152,"3C7EFFFFFFFF7E3C") 1920 CALL COLOR(16,11,1) 1930 PRINT TAB(12);"MINER": : : : : : : : : 1940 PRINT " TI-99/4 TRANSLATION BY":" SEAN MCGUINESS": :"REVISED BY: SEAN MCGUINESS" 1950 PRINT: :"ENHANCED BY: SEAN MCGUINESS AND TYLER CALSON":"2/20/85": :" ADAPTED FOR TI-99/4A":"" 1960 FOR I=1 TO 1000 1970 NEXT I 1971 INPUT " NEED INSTRUCTIONS(Y/N)?":A$ 1972 IF A$<>"Y" THEN 2080 1980 CALL CLEAR 1990 PRINT "YOU HAVE INHERITED A MINE WITH 30 POSSIBLE VEINS OF ORE(";CHR$(152);"). IF YOU CAN PROVE THE" 2000 PRINT "MINE IS WORTHWHILE, YOU CAN SELL IT TO A BIG MINING CO. YOU CAN ONLY GET UNDERGROUND" 2010 PRINT "VIA ELEVATOR. YOU CANNOT DIGWHEN YOU ARE ABOVE GROUND." 2020 PRINT "USE THE 4 ARROW KEYS TO MOVETHE MINER. USE THE UP AND DOWN ARROWS TO CONTROL THE" 2030 PRINT "ELEVATOR (AT THE RIGHT OF THE SCREEN). BEWARE: YOU CANBE TRAPPED. IF YOU GIVE UP," 2040 PRINT "HIT KEY(A) FOR AID. IT COSTS$5 EVERY TIME YOU DIG. IF YOU FIND ANY GOLD, BRING IT TO THE BANK." 2050 PRINT:" GOOD LUCK":" PRESS ANY KEY TO CONTINUE" 2060 CALL KEY(0,KE,ST) 2070 IF ST=0 THEN 2060 2080 RETURN 2090 CALL CHAR(96,"FFFFFFFFFFFFFFFF") 2100 CALL CHAR(100,"01010101010101FF") 2110 CALL COLOR(9,2,1) 2120 CALL CHAR(97,"8080808080808080") 2130 CALL CHAR(98,"00000000000000FF") 2140 CALL CHAR(99,"0101010101010101") 2150 CALL CHAR(144,"0") 2160 CALL COLOR(15,2,16) 2170 A$="FF010101010101FF" 2180 CALL CHAR(102,A$) 2190 CALL CHAR(145,A$) 2200 A$="FF313179B5B549FF" 2210 CALL CHAR(103,A$) 2220 CALL CHAR(146,A$) 2240 CALL CHAR(101,"183C183C5A5A2442") 2250 CALL CHAR(147,"183C183C5A5A2442") 2260 A$="1010101010101010" 2270 CALL CHAR(105,A$) 2280 CALL CHAR(148,A$) 2290 EP=0 2300 M=250 2310 CALL COLOR(14,5,5) 2320 CALL CLEAR 2330 CALL COLOR(16,11,2) 2340 PRINT " 1ST BANK": : : : : : : : : : : : : : : : : : :"$/OZ OF GOLD=" 2350 PRINT " GOLD OUNCES=";TAB(18);"CASH=" 2360 CALL HCHAR(6,1,96,480) 2370 CALL VCHAR(6,32,144,15) 2380 CALL VCHAR(6,31,144,15) 2390 CALL HCHAR(1,3,98,10) 2400 CALL VCHAR(2,3,97,4) 2410 CALL VCHAR(2,12,99,4) 2420 CALL HCHAR(3,12,100) 2430 CALL VCHAR(4,11,99,2) 2440 CALL HCHAR(5,20,101) 2450 CALL HCHAR(5,31,102) 2460 CALL HCHAR(4,31,98) 2470 CALL HCHAR(5,32,97) 2480 FOR I=1 TO 30 2490 H=INT(RND*15) 2500 V=INT(RND*26) 2510 CALL SOUND(-200,330+20*I,INT(H/5)) 2520 IF C(H,V)THEN 2490 2530 C(H,V)=1 2540 CALL HCHAR(H+6,V+4,152) 2550 NEXT I 2560 CALL SOUND(800,262,1,524,0,796,1) 2570 CALL SOUND(900,262,0,796,1,349,0) 2580 GOSUB 1740 2590 REM PRINT A LINE 2600 RETURN 2610 CALL HCHAR(24,3,32,29) 2620 FOR I=1 TO LEN(A$) 2630 CALL HCHAR(24,4+I,ASC(SEG$(A$,I,1))) 2640 NEXT I 2650 RETURN 2660 REM WON 2670 CALL CLEAR 2680 FOR I=1 TO 20 2690 CALL SCREEN(3+INT(RND*12)) 2700 PRINT TAB(I);"CASH $" 2710 CALL SOUND(80,330+20*I,0) 2720 NEXT I 2730 CALL CLEAR 2740 PRINT "! ! ! Y I P P E E ! ! !" 2750 CALL SOUND(700,262,1,524,0,796,1) 2760 CALL SOUND(800,262,0,796,1,349,0) 2770 PRINT "YOU CAN NOW SELL THIS CLAIM FOR LOTS OF MONEY TO A BIG MINING CO. AND RETIRE ON THEROYALTIES!": : : 2780 PRINT " PLAY AGAIN (Y/N)?" 2785 CALL SCREEN(4) 2786 GOTO 2840 2790 REM QUIT 2800 CALL CLEAR 2810 PRINT "TOO BAD, THE OLD MINE JUST DIDN'T PAN OUT.": : : : : : 2820 REM BANKRUPT 2830 PRINT "YOU WENT BANKRUPT, DO YOU WANT TO TRY AGAIN(Y/N)?" 2840 CALL KEY(2,KE,ST) 2850 IF ST=0 THEN 2840 2860 IF KE=15 THEN 2960 2870 IF KE=18 THEN 2890 2880 GOTO 2840 2890 CALL CLEAR 2900 FOR I=0 TO 14 2910 FOR J=0 TO 26 2920 C(I,J)=0 2930 NEXT J 2940 NEXT I 2950 GOTO 190 2960 STOP 32714 SUB VDPUTIL3 32715 CALL CLEAR :: CALL INIT :: CALL LOAD(8196,63,232) 32716 CALL LOAD(16360,80,79,75,69,82,32,38,12,80,79,75,69,86,32,37,164,80,69,69,75,86,32,37,36) 32717 CALL LOAD(9491,100) 32718 CALL LOAD(9508,2,224,37,20,3,0,0,0,2,0,0,100,200,0,37,18,4,192,2,1,0,1,4,3,2,32,12,4,32) 32719 CALL LOAD(9536,32,24,18,184,192,32,131,74,2,1,37,0,208,160,131,18,9,130,2,34,255,255,4,32,32,44) 32720 CALL LOAD(9562,4,197,209,34,36,255,9,132,19,21,4,195,60,224,37,18,200,5,131,76,200,5,131,78,200,5) 32721 CALL LOAD(9588,131,80,2,5,64,0,161,68,2,131,0,1,17,6,2,5,65,0,161,67,6,196,200,4,131,76) 32722 CALL LOAD(9614,200,5,131,74,4,192,192,66,5,129,4,37,254) 32723 CALL LOAD(9636,2,224,37,20,3,0,0,0,4,192,2,1,0,1,200,1,37,18,4,32,32,12,4,32,32,24,18,184) 32724 CALL LOAD(9664,200,32,131,74,37,0,184,32,131,18,37,19,2,3,0,2) 32725 CALL LOAD(9680,4,192,192,67,4,32,32,12,4,32,32,24,18,184,216,224,131,75,37,0,5,131,136,3) 32726 CALL LOAD(9704,37,18,22,242,192,32,37,0,2,1,37,2,192,131,2,34,255,254,4,32,32,36) 32727 CALL LOAD(9726,4,192,216,0,131,124,2,224,131,224,4,96,0,112) 32728 CALL LOAD(9740,3,0,0,0,4,192,2,1,0,1,4,32,32,12,200,32,131,74,37,18,2,1,0,2,4,32,32,12,4,32) 32729 CALL LOAD(9770,32,24,18,184,192,32,131,74,208,32,37,19,4,32,32,48,4,91) 32730 CALL LOAD(8194,39,04) 32731 SUBEND 32732 SUB CHAR(A,A$) :: L=LEN(A$) 32733 A$=A$&RPT$("0",16-L) 32734 FOR I=1 TO 16 STEP 2 32735 A1$=SEG$(A$,I,1) 32736 A2$=SEG$(A$,I+1,1) 32737 IF A1$<":" THEN A1=VAL(A1$)*16 ELSE A1=(ASC(A1$)-55)*16 32738 IF A2$<":" THEN A1=A1+VAL(A2$)ELSE A1=A1+ASC(A2$)-55 32739 CALL LINK("POKEV",767+8*A+(I+1)/2,A1) 32740 NEXT I 32741 SUBEND 32742 SUB COLOR(A,B,C) 32743 CALL LINK("POKEV",2063+A,(B-1)*16+C-1) 32744 SUBEND Adamantyr Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted December 12, 2010 Share Posted December 12, 2010 Quite nice. My 2 year old son asked a lot of questions, explained the colors and more. The flood was fun. Quote Link to comment Share on other sites More sharing options...
InfernalKeith Posted December 12, 2010 Share Posted December 12, 2010 Cute game. Thanks for sharing it, I love stuff like this. Was there a similar game in 99'er at one point? I seem to recall another game with an elevator, where you could get blocked from returning to the surface. Quote Link to comment Share on other sites More sharing options...
unhuman Posted December 12, 2010 Share Posted December 12, 2010 Yeah - the duration of the sounds sort of make the game unplayable for me... I am far too impatient. Might negative / shorten them to see if that helps at some point. Not quite seeing why this game requires extended chars, alas, doesn't really matter - I assume that the XB modification breaks sprites? Interestingly (in classic99) I put on a sprite and started moving it on line 2 - and it did just that - but then the motion stopped... -H Quote Link to comment Share on other sites More sharing options...
JonArkanix Posted December 13, 2010 Share Posted December 13, 2010 Ah, Miner ... we played a similar version in school on our PETs. Looking around, found a video of the game here -> Hmm, we also played Lemonade and Artillery on those PETs besides our own homebrew Rogue-likes and text adventures. Quote Link to comment Share on other sites More sharing options...
+adamantyr Posted December 13, 2010 Author Share Posted December 13, 2010 (edited) Ah, Miner ... we played a similar version in school on our PETs. Looking around, found a video of the game here -> Hmm, we also played Lemonade and Artillery on those PETs besides our own homebrew Rogue-likes and text adventures. Cool, thanks Jon! I figured it was from another platform. The TI version is scaled back in places (shorter text messages, less elaborate elevator and bank graphics), but also has non-ASCII graphics and colors. Not a bad port, really. Additional: While 99'ers occasionally complain about the sound on their machine, at least in comparison to the SID chip, WOW is that PET machine chalkboard-scratch NASTY... *wince* Adamantyr Edited December 13, 2010 by adamantyr Quote Link to comment Share on other sites More sharing options...
JonArkanix Posted December 13, 2010 Share Posted December 13, 2010 Yeah, PETs are a business machine ... the sound is nasty, no redefined characters possible, no real smooth scrolling (until recently), etc. We had one C64 in the back office and everyone fought for time on the machine. Quote Link to comment Share on other sites More sharing options...
