[AQUARIUS] Machine Language Programming on the Aquarius
jaybird3rd
Please find version 2 of the Bootloader attached. It will now also handle BASIC files upto 16K (16K is limit of Aquarius ROM specs).
It does this by injecting two BASIC REM lines with the necessary machine code at the right place in memory (at 0xE000)
The Caq2Bootload.vbs Visual Basic script has the "intelligence" to do this, so this script has now become more important.
The usage is still same: create your Aquarius BASIC program and save it, using the Virtual Aquarius, as a CAQ file.
Place the files BOOTLDR.DAT and Caq2Bootload.vbs in the same folder (e.g. your desktop)
Drag your CAQ file over Caq2Bootload.vbs and drop it.
A file with the extension .BIN will be created in the same folder as the .CAQ file
Or by command prompt:
C> cscript Caq2Bootload.vbs bomber_bas.caq
See also the README file within the ZIP archive.
BootLDRv2.zip
Any comments are welcome.
Enjoy!
Regs,
Martin
Edited by mvdsteenoven
BootLDRv2.zip
Enjoy!
Regs,
Martin
This is great, 16K is even better to play around with!
Yes, indeed! Excellent work, Martin!
I still haven't had time to try this myself (just as soon as school is over!), so this may be a "dumb question", but I'm wondering: if a program is developed in BASIC on a 16K machine, real or emulated, and if that program is then converted to a 16K cartridge image and burned to a real cartridge, will it still require the 16K of RAM, or will the cartridge run on a stock Aquarius?
I've added some more configuration options to my new SuperCart boards, so they can now support 8K/16K cartridge ROMs, in addition to the larger bankswitched ones. At my first opportunity, I'll try them with an image generated by this program, but I fully expect that it will work.
The memory variables are still stored in Ram, I believe a number uses 10 bytes, so you could create about 170 number variables (without strings) on a stock Aquarius with 1.7k ram. That should be more than enough.But if the programmer has written his own machinecode to read the handcontrollers then he would probally put this in the upper 16k and then it will not work on a stock Aquarius.
So a pure BASIC program could run from ROM on a stock Aquarius, but you should check for machinecoded routines.
Regs,
Martin
  • 3 months later...
Hi,
I am new to this forum purely because I was unaware of any Aquarius collectors. It's good to see things move on, I can remember when I had my Aquarius over 20 years ago, programming machine code in decimal (no assembler's to hand then). I had a go with the emulator yesterday and it all came flooding back, good work. I wrote Aquapede back then, but it didn't sell in great number's as the Aquarius's life was pretty short. It's possible a copy still exist's at my parents house and if so I will make it available to all. Mattel or Radofin were very good to me then by giving me all the tech info on the machine which made the job a bit easier. If memory serves me correctly, taking into account the memory constraint's I had to work with, movements were done using screen memory scans and moving characters either left or right or up and down and a storage area for the screen so I could replace the items under moving characters, All good fun. It would be good to see it again. I also modified a zx81 memory expansion to fit my aquarius. It wasn't at all elegant but done the job. I didn't mind that the Aquarius wasn't high res, but user definable character set would have made a difference. I always remembered it as a solid reliable machine and quite a lot of fun at the time. I am following this thread with great interest and will probably have a go at programming z80 code again. Keep up the good work.
  • Like 4
Thanks for posting, and welcome! It's always great to hear from people who are "rediscovering" the Aquarius (and other classic computers, for that matter!) thanks to emulation and the other tools we have available today. I'd love to see Aquapede, if you still happen to have a copy.
Yes, if you look inside the Virtual Aquarius archive, you'll find some subfolders which include utilities for converting from WAV files to CAQ files, and vice-versa. I've used WAV2CAQ successfully to convert raw cassette data that I recorded into my PC sound card using an ordinary cassette player, so if these tapes are the ones you're looking for, let us know if you have trouble with the conversion.
Hi again, Anyone know if a DOS version of Virtual Aquarius exist's. Just an idea, I have a HP thin client and used it as a BBC Micro emulator under DOS. It was totally solid state and supported USB as that is what it booted from. An ideal candidate for Aquarius emulator, getting the sound card maybe a bit tricky though.
I am unaware of a DOS version! The only other emulators I know of are Aqemu and MESS, but these are also window based! Edited by Aquaman
There is an old DOS binary of MESS floating around (I don't remember the exact version; somewhere in the 0.8X range), but the Aquarius driver is probably in a fairly primitive state. I know that the character set has been fixed in more recent versions, because I dumped the Aquarius Character Generator ROM image that MESS now uses. I suppose you could compile a recent version of MESS for DOS, if you really wanted to.
The thing I like about MESS is that, unlike Virtual Aquarius and AqEmu, it's still being actively developed, it's multi-platform, and it has a good built-in debugger. I think the sound and hand controller support is probably better in Virtual Aquarius, and Virtual Aquarius also has "QuickType" and WAV2CAQ and other convenient features and tools. But of course, nothing beats having the real hardware! :)
Are any of your hardware projects going to bring remapping the character set to the Aquarius? Something like that could make smooth scrolling games possible.
Also, I heard somewhere that James the Animal Tamer used his own font for Virtual Aquarius and had that under pubic domain. Is there any way to extract that font with one of your tools?
I'd like to include that in my upgraded Mini Expander. It originally started as an idea for a standalone upgrade (see here), but I've since decided that making it a part of the Mini Expander would make for an easier installation.
He probably re-drew the character set (or had someone else do it) because a dump of the original Character Generator ROM wasn't available at the time. If the replacement set isn't a separate file, it's probably inside the emulator binary, and whether it can be extracted would depend on how it is stored. The easiest way to capture it would probably be to write a quick BASIC program which prints out every character in the set on the screen. Then, all you'd have to do is run it inside Virtual Aquarius and take a screenshot.
  • 1 month later...
  • 1 month later...
Hi, Thank's for your comments, I should receive the cassettes from my mother in a few day's so hopefully it is there. I will check out the Aquarius user site and will have to find an Aquarius again.
Hi, Any news regarding those cassettes and any luck scoring an Aquarius?
  • 4 weeks later...
  • 2 weeks later...
  • 3 weeks later...
Ok I got my AquariusmanAdventureHacked.asm* all set to go when I get shut down by the 64 bit incompatibility with TASM.
So I DosBox to the C drive and try it there and get a failed compile on CScript error from Make.bat
I then spend an hour or two bent over a teenaged Sony Viao with windows professional 2000 moving files by
thumbdrive, mostly its fighting that trackpad and damnable UI.
I run the make.bat and it spits out a bunch of info including some Data lines.
But the virtual aquarius 7.5 doesn't recognize the .caq files at all in the file selector.
Won't load them as 'all files"
It sees the original quest_a.caq but doesn't load it.
What's the best Aquarius assembler workflow workaround on 64 bit windows 7?
***Awesome Aquarius Man on Adventure machine code wizardry*
http://atariage.com/forums/topic/174798-aquarius-man-goes-on-holiday/?hl=%2Bpanscr&do=findComment&comment=2173637
Edited by Pset
