+Stephen Posted September 26, 2011 Share Posted September 26, 2011 Back in business. After some sleepless nights the BBS is up and running again. The userlog has been restored by combining the corrupted original with a corrupted (1 day old) back-up so nothing is lost in this part and it's up to date. It now runs from a 4GB Flash Memory Card using a SCM PCD-50b card reader with modified firmware to make it a reader AND writer. Runs fine when connected to a slightly modified Black Box. A secondary SD card will be added as soon as I found a solution to easily make back-ups of all Black Box data (complete partitions, partition tables and configuration data). If you notice anything weird (apart from the regular weirdness), leave me a detailed feedback on there. More info on Thunderdome BBS. Awesome job on the recovery! I'll try to log in later this evening. Quote Link to comment Share on other sites More sharing options...
Fox-1 / mnx Posted September 26, 2011 Share Posted September 26, 2011 I'll try to log in later this evening. I hope it works as it should. It's not tested that thoroughly yet. I'll check it tomorrow after I've got some sleep :-) Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted September 26, 2011 Share Posted September 26, 2011 Yay! Congratulations. Quote Link to comment Share on other sites More sharing options...
Fox-1 / mnx Posted September 27, 2011 Share Posted September 27, 2011 Let's waste some space with pics. Changing media... Take an old (and damaged) SF314 external Atari ST disk drive: -------------------------------------------------------- Remove the inner parts and replace with more recent stuff: -------------------------------------------------------- Add some switches and indicators: -------------------------------------------------------- Dig out the required cables: -------------------------------------------------------- And the result is a little box which fits 10 memory cards to serve two separate Atari 130XE's and only requires a single 5V power source to feed it. The lower device runs the BBS while the upper one is for none BBS usage. -------------------------------------------------------- It's SCSI so it can be connected to any SCSI I/SCSI II bus (ST/Falcon/whatever) as long as the host provides termination power and the parity bit. Works for me. It's a pity that the front-top of my case is a bit damaged. I was hoping this little crack would be removed anyways when modifying the case but it didn't. OTOH, it's all made of scrap I had laying around anyways. Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted September 27, 2011 Share Posted September 27, 2011 Nice pics, thanks. Even with the crack/damage, that's a pretty awesome setup, nice innovative use of dead hardware. Quote Link to comment Share on other sites More sharing options...
Fox-1 / mnx Posted September 27, 2011 Share Posted September 27, 2011 Now it's at least in use for something, otherwise it was just laying around, taking up space. While recovering the message bases I came across a message (1998?) from someone who was searching for network tools for his BBS Express ST set-up to network with 8-bit Pro BBS'. That must be you I guess :-) Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted September 27, 2011 Share Posted September 27, 2011 Easily possible. Quote Link to comment Share on other sites More sharing options...
bf2k+ Posted September 28, 2011 Share Posted September 28, 2011 Very cool mod... Quote Link to comment Share on other sites More sharing options...
atari frank Posted October 1, 2011 Share Posted October 1, 2011 I logged into the thunderdome bbs today via prison board dial up,when I get to the thunderdome any time I enter a letter it comes up twice,I have even changed the duplex mode and that don't help either,out of ideas here,any help would be appreciated thx Frank p.s. system 800xl(stock) two 1050 drives supra modem 2400 256k icd mio software=bobterm v1.21 Quote Link to comment Share on other sites More sharing options...
Fox-1 / mnx Posted October 1, 2011 Share Posted October 1, 2011 (edited) Must be a "local echo" setting at your side. Try to turn it off. (b.t.w: what's prison board?) Edited October 1, 2011 by Fox-1 / mnx Quote Link to comment Share on other sites More sharing options...
atari frank Posted October 1, 2011 Share Posted October 1, 2011 Must be a "local echo" setting at your side. Try to turn it off. (b.t.w: what's prison board?) The prison board is a bbs in texas that still has a dial up modem,I call into there and then take a telnet link over to the thunderdome,Don't know what to turn off, I did try turning things off and on but nothing changed still same problem. Quote Link to comment Share on other sites More sharing options...
bf2k+ Posted October 2, 2011 Share Posted October 2, 2011 Is Thunderdome a dial-up BBS on a modem or is it telnettable (is that a word ) from the internet? Quote Link to comment Share on other sites More sharing options...
Fox-1 / mnx Posted October 2, 2011 Share Posted October 2, 2011 (edited) The prison board is a bbs in texas that still has a dial up modem,I call into there and then take a telnet link over to the thunderdome,Don't know what to turn off, I did try turning things off and on but nothing changed still same problem. I think you make it too complicated to connect. On most modern systems it requires a single click to connect as it will start-up a default telnet client in most cases. This means you likely can connect with a non-default telnet client too, like Bobterm in an emulator, or by using Bobterm on a real Atari while exchanging the modem for a PC/Mac-system and use APE (for SIO) or a general telnet-modem tool (with null-modem) to connect. Using an external solution (like another BBS) makes it more difficult as you don't know whats going on that BBS and you probably also can't change the local-echo setting that easy. Ask the Sysop of Prison for help if you want to connect his way. With the right settings it should work too. or is it telnettable (is that a word ) It's a word now! :-) Thunderdome switched from dial-up to telnet in 2004. Edited October 2, 2011 by Fox-1 / mnx Quote Link to comment Share on other sites More sharing options...
bf2k+ Posted October 2, 2011 Share Posted October 2, 2011 Thunderdome switched from dial-up to telnet in 2004. So what's the URL? Quote Link to comment Share on other sites More sharing options...
Fox-1 / mnx Posted October 2, 2011 Share Posted October 2, 2011 I'll prefer not to publish it in direct clickable form as I get hit by port scanners too much already but I guess you'll get it. Use "telnet://" and add "thunderdome DOT homeip DOT net:471" As you can see, it's not on port "23" but "471" in stead. Quote Link to comment Share on other sites More sharing options...
doctorclu Posted October 2, 2011 Share Posted October 2, 2011 I'll try to log in later this evening. I hope it works as it should. It's not tested that thoroughly yet. I'll check it tomorrow after I've got some sleep :-) Got on to Thunderdome via the Prison Board BBS tonight. Welcome back Thunderdome! Missed your "experimental" BBS. Quote Link to comment Share on other sites More sharing options...
Fox-1 / mnx Posted October 2, 2011 Share Posted October 2, 2011 Do I still have "experimental" listed somewhere? It's about time to remove that :-) Quote Link to comment Share on other sites More sharing options...
bf2k+ Posted October 2, 2011 Share Posted October 2, 2011 Do I still have "experimental" listed somewhere? It's about time to remove that :-) Your web page says experimental. I tried a few mins ago but I guess it is busy. Quote Link to comment Share on other sites More sharing options...
Fox-1 / mnx Posted October 3, 2011 Share Posted October 3, 2011 Ah, the web page. Didn't think about that. And it was probably busy indeed. There are days without callers and suddenly there are 4 in an hour. b.t.w: your are a "validated user" at the meanwhile so more enabled features and less text during log-in. 1 Quote Link to comment Share on other sites More sharing options...
w1k Posted October 3, 2011 Share Posted October 3, 2011 btw, irc.atarichat.net:800 is down? i cant connect to this host with atari.. Quote Link to comment Share on other sites More sharing options...
Joey Z Posted October 20, 2011 Share Posted October 20, 2011 (edited) telnet://99.63.207.190 Edited October 20, 2011 by Joey Z Quote Link to comment Share on other sites More sharing options...
Joey Z Posted October 24, 2011 Share Posted October 24, 2011 (edited) telnet://99.63.207.190 UPDATE: I now have free DNS hosting from http://freedns.afraid.org the new web is telnet://anticbbs.strangled.net Edited October 24, 2011 by Joey Z Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted October 24, 2011 Share Posted October 24, 2011 Hmm, is this an actual Atari board? I mean, Atari hardware and software? Thanks, just curious... Quote Link to comment Share on other sites More sharing options...
Joey Z Posted October 26, 2011 Share Posted October 26, 2011 Hmm, is this an actual Atari board? I mean, Atari hardware and software? Thanks, just curious... my bbs? no, its a PC. although, it is supposed to be atari related. Quote Link to comment Share on other sites More sharing options...
Fox-1 / mnx Posted October 27, 2011 Share Posted October 27, 2011 PC? That doesn't count. If PC, you should at least run it on an Atari ABC. Quote Link to comment Share on other sites More sharing options...
