lucifershalo Posted February 3, 2011 Share Posted February 3, 2011 I finally have a E/A cart and tried some of the programs from http://tigameshelf.net/asm.htm but every time I tried to load it it says "I/O error code 0" does it mean that it cant access the NanoPEB? thanks Quote Link to comment Share on other sites More sharing options...
matthew180 Posted February 3, 2011 Share Posted February 3, 2011 Hmm, error code 0. That's a new one. I have a CF7 but I have not messed around with it much. Tell me the exact steps you are going through and I'll see if I can duplicate the problem. Quote Link to comment Share on other sites More sharing options...
lucifershalo Posted February 3, 2011 Author Share Posted February 3, 2011 nanopeb on computer on select editor-assembly I choose option 3 or 5 and type the program name like dsk1.major and I have the message I/0 error code 0 Quote Link to comment Share on other sites More sharing options...
matthew180 Posted February 3, 2011 Share Posted February 3, 2011 How did you get the file from the TI Game Shelf to the CF7? What did you download, and did you do any conversion with something like TI-Dir? Quote Link to comment Share on other sites More sharing options...
lucifershalo Posted February 3, 2011 Author Share Posted February 3, 2011 I used Ti99dir to put them on the CF but didnt make any conversion, do I have to? Quote Link to comment Share on other sites More sharing options...
matthew180 Posted February 3, 2011 Share Posted February 3, 2011 I don't know, that's why I was asking exactly what did you download and how you got it on to the CF card. The only formats I see on the Game Shelf are emulator files, so I assume you would have to do some sort of conversion, like stripping the TI-Files header or something? Like I said, I have not messed with my CF7 beyond looking through the menu of stuff that came with it. Hmm. The Game Shelf is timing out for me right now. I think there were two files to download for Major, a TI-Files and T9 which says only works with Classic99. Which did you download? Quote Link to comment Share on other sites More sharing options...
lucifershalo Posted February 3, 2011 Author Share Posted February 3, 2011 I am using the v9t9 dsk files Quote Link to comment Share on other sites More sharing options...
matthew180 Posted February 3, 2011 Share Posted February 3, 2011 I'm sure those files have to be converted. I have yet to really focus on all the virtual disk and file formats, why so many exist, and how to convert any given type to be usable. Two formats is one too many IMO. I'm sure you have to use TIdir to convert the T9V9 into something usable on the real hardware. I don't know for sure right off hand, but a search on this forum or Google will probably give you the answer. The Game Shelf is still timing out for me, so I can't download anything to try right now. Quote Link to comment Share on other sites More sharing options...
telengard Posted February 3, 2011 Share Posted February 3, 2011 I finally have a E/A cart and tried some of the programs from http://tigameshelf.net/asm.htm but every time I tried to load it it says "I/O error code 0" does it mean that it cant access the NanoPEB? thanks I ran into the same issue last night (first time trying out my CF7+ after a year or two of having it). I was using XB however, not E/A. Other dsk images seemed to work fine though. ~telengard Quote Link to comment Share on other sites More sharing options...
matthew180 Posted February 3, 2011 Share Posted February 3, 2011 Telengard, can you give the steps necessary from downloading to running on the 99/4A? Quote Link to comment Share on other sites More sharing options...
lucifershalo Posted February 3, 2011 Author Share Posted February 3, 2011 yes, pls, Telengard Quote Link to comment Share on other sites More sharing options...
Opry99er Posted February 3, 2011 Share Posted February 3, 2011 (edited) It depends on what is downloaded, obviously, but assuming it's in dsk format already, all you have to do is load the dsk image onto a CF card, then you need to "mount" a CF image to a physical "drive". Mount CF0001 as "DSK1" or something like that. In TI99Dir, there is an option for "Mount CF image" and it gives you plenty of decent instruction. It is in this way that you can have hundreds of dsks on a CF card which only facilitates the max TI capacity of 3 physical drives. Unlike a RAMdisk, you cannot use "DSKC" and the like... Just DSK1,2&3. Once your image is mounted into DSK1, all you need to do is run your program as required. If you have done all these things and still can't get it to work, you might want to run some additional tests. For 1, go to TIXB and type in: 100 PRINT "TEST 200 END Then type SAVE "DSK1.TEST" and see what happens. Edited February 3, 2011 by Opry99er Quote Link to comment Share on other sites More sharing options...
lucifershalo Posted February 3, 2011 Author Share Posted February 3, 2011 I tried same results:( I cant do a test as I dont have the TIXB cart Quote Link to comment Share on other sites More sharing options...
Opry99er Posted February 3, 2011 Share Posted February 3, 2011 Use TI BASIC. Same test, nothing different. If it saves, your DSK is good and it is mounted properly. If not, we need to debug further. Quote Link to comment Share on other sites More sharing options...
Opry99er Posted February 3, 2011 Share Posted February 3, 2011 Try uncoupling the CF7 from the TI and attempting the same load. See which I/O error it gives. If it's "0" then we may be looking at something hardware-related.... But I am pretty sure it will give a different I/O error. When your TI99Dir is up and running, what does your directory listing look like in the window? Quote Link to comment Share on other sites More sharing options...
lucifershalo Posted February 3, 2011 Author Share Posted February 3, 2011 It depends on what is downloaded, obviously, but assuming it's in dsk format already, all you have to do is load the dsk image onto a CF card, then you need to "mount" a CF image to a physical "drive". Mount CF0001 as "DSK1" or something like that. In TI99Dir, there is an option for "Mount CF image" and it gives you plenty of decent instruction. It is in this way that you can have hundreds of dsks on a CF card which only facilitates the max TI capacity of 3 physical drives. Unlike a RAMdisk, you cannot use "DSKC" and the like... Just DSK1,2&3. Once your image is mounted into DSK1, all you need to do is run your program as required. If you have done all these things and still can't get it to work, you might want to run some additional tests. For 1, go to TIXB and type in: 100 PRINT "TEST 200 END Then type SAVE "DSK1.TEST" and see what happens. I/O error 60 Quote Link to comment Share on other sites More sharing options...
Opry99er Posted February 3, 2011 Share Posted February 3, 2011 So you weren't able to save. One of 5 things is happening (in my estimation) 1) your DSK isn't formatted properly 2) your CF card isn't formatted properly 3) your DSK image isn't mounted properly 4) your CF7 is bad 5) your CF card is bad Probably one of (or a combination of) the first 3 is most likely. Obviously the TI recognizes the CF7.... Does it show up in your title screen? ("CF7 installed" or something like that) Quote Link to comment Share on other sites More sharing options...
lucifershalo Posted February 3, 2011 Author Share Posted February 3, 2011 when I switched on the TI it says Nanopeb+ or something like that on the title screen Quote Link to comment Share on other sites More sharing options...
Opry99er Posted February 3, 2011 Share Posted February 3, 2011 So the two hardware components recognize each other--- that's a positive thing.... So-- when TI99Dir is pulled up, does your CF directory look okay? Is there a list of all your CF volumes? Quote Link to comment Share on other sites More sharing options...
snume Posted February 3, 2011 Share Posted February 3, 2011 lucifershalo and telengard, do either of you guys have the manual for the CF7+? There are instructions in there for the mounting of the drives. The CF7+ adds a few of it's own commands and they are very helpful. You use one of them, the Call Mount command, and it's very easy once you know the syntax. Quote Link to comment Share on other sites More sharing options...
lucifershalo Posted February 3, 2011 Author Share Posted February 3, 2011 an image Quote Link to comment Share on other sites More sharing options...
Opry99er Posted February 3, 2011 Share Posted February 3, 2011 Yep--- you can mount with TI BASIC, but I just use TI99Dir because it's graphic, easy, and a one stop shop. Of course if you're on the real hardware--- you use CALL MOUNT to switch up the volumes in the drives so you don't have to go back to the PC. Thanks for mentioning that... I don't use CALL MOUNT very often because of how often I plug my card into my PC. Quote Link to comment Share on other sites More sharing options...
Opry99er Posted February 3, 2011 Share Posted February 3, 2011 Your card looks just fine. Formatted, clean.... Just gotta get Volume #2 mounted as DSK1. That's the only issue right now. I can't remember the CALL MOUNT syntax... But I think you'd use CALL MOUNT(2,1), for volume 2, drive 1. Been a while since I did that though, so don't quote me. It may be reversed and I may have it totally wrong. Quote Link to comment Share on other sites More sharing options...
lucifershalo Posted February 3, 2011 Author Share Posted February 3, 2011 could you explain to me how to 1) format DSK properly 2) format CF card properly 3) mount DSK image properly to be sure I am doing that right Quote Link to comment Share on other sites More sharing options...
Opry99er Posted February 3, 2011 Share Posted February 3, 2011 Everything looks great.... All you gotta do is get it mounted. I use TI99Dir to do it, but if that's not working, try mounting it from BASIC. Quote Link to comment Share on other sites More sharing options...
