keilbaca Posted February 6, 2011 Share Posted February 6, 2011 So, I go to play Virtual Racing and my Everdrive tonight. I purchased a Genesis 3 from Cash n Culture being I didn't have one, thinking, oh hey this would be a perfect portable little device for taking to my girlfriend's house to play some Sonic. So I fire it up, no startup logo. I play with the cart a bit, clean it with rubbing alcohol, and I get the sega starting screen to come up, and that's it. So I'm like ok maybe its not compatible with the Everdrive. I looked online, seen that it was... so then I'm like ok maybe its just a fluke, lets try my Virtual Racing. Nope, same thing. I then decide, ok whatever, I finally have a/v cables for my Genny 3/2, lets try my Genesis 2. That thing doesn't boot up at all, either game. So I dug out my Genesis 1, and that one worked fine. Dug out my other genesis 1, not booting. Is there any way to refurbish these cart connectors back to new? I've tried rubbing alcohol, 2000 grit sandpaper, then 200 grit sandpaper. Nothing, still no boot. Quote Link to comment Share on other sites More sharing options...
Reaperman Posted February 6, 2011 Share Posted February 6, 2011 (edited) Just a note, Virtua Racing will never run with a genesis 3. But yes, those connectors have gotten a bit bad. Edited February 6, 2011 by Reaperman Quote Link to comment Share on other sites More sharing options...
keilbaca Posted February 6, 2011 Author Share Posted February 6, 2011 Just a note, Virtua Racing will never run with a genesis 3. Oh I didn't know that. Thanks for the info But, its documented that the Everdrive does... and that acted the same way. Its just overly frustrating... Quote Link to comment Share on other sites More sharing options...
Reaperman Posted February 6, 2011 Share Posted February 6, 2011 (edited) Also, I use this product on all my cart slots. It's got a nice abrasive brush that clips on the end for getting right down in. One bottle's all you need...forever... Edited February 6, 2011 by Reaperman Quote Link to comment Share on other sites More sharing options...
StoneAgeGamer Posted February 6, 2011 Share Posted February 6, 2011 Just a note, Virtua Racing will never run with a genesis 3. Oh I didn't know that. Thanks for the info But, its documented that the Everdrive does... and that acted the same way. Its just overly frustrating... EverDrive works only if you enabled Genny3 mode. If you don't have that feature or its not enabled it won't work. Quote Link to comment Share on other sites More sharing options...
Jess Ragan Posted February 6, 2011 Share Posted February 6, 2011 Nah, that's not true. I'd say the NES and Saturn have the worst cartridge ports. Blinking screens on the NES are usually a result of cartridge connectors that have worn out. The Saturn has a cartridge port that's infamous for wearing out in a hurry. Quote Link to comment Share on other sites More sharing options...
Rockin' Kat Posted February 6, 2011 Share Posted February 6, 2011 you sure are having bad luck. I'd try using DeoxIT Barring that, you could try bending the pins outward with something like a dental pick. Quote Link to comment Share on other sites More sharing options...
keilbaca Posted February 6, 2011 Author Share Posted February 6, 2011 Just a note, Virtua Racing will never run with a genesis 3. Oh I didn't know that. Thanks for the info But, its documented that the Everdrive does... and that acted the same way. Its just overly frustrating... EverDrive works only if you enabled Genny3 mode. If you don't have that feature or its not enabled it won't work. Wow, really? I had no idea... is there a way to kick it to Genny 3 mode without using a Genny 1 or 2? Just curious. Quote Link to comment Share on other sites More sharing options...
keilbaca Posted February 6, 2011 Author Share Posted February 6, 2011 you sure are having bad luck. I'd try using DeoxIT Barring that, you could try bending the pins outward with something like a dental pick. Tried bending the pins out, and now I have to find a new cart slot <_< I tried using a needle, and it wasn't really thin enough... Quote Link to comment Share on other sites More sharing options...
Austin Posted February 6, 2011 Share Posted February 6, 2011 Damn dude.. Seriously bad luck. I have never had problems with any Genesis system's cartridge slot.. and I've owned a lot of Genesis systems over the years. The only issues I've run into are the same for other cart-based platforms--dirty cartridge contacts. Quote Link to comment Share on other sites More sharing options...
StoneAgeGamer Posted February 6, 2011 Share Posted February 6, 2011 Just a note, Virtua Racing will never run with a genesis 3. Oh I didn't know that. Thanks for the info But, its documented that the Everdrive does... and that acted the same way. Its just overly frustrating... EverDrive works only if you enabled Genny3 mode. If you don't have that feature or its not enabled it won't work. Wow, really? I had no idea... is there a way to kick it to Genny 3 mode without using a Genny 1 or 2? Just curious. EDIT: According to Igor I was incorrect. The menu system should still work no matter what, even on a Genesis 3. You need to enable Genny3 mode with a Genesis 3 to get the games to play. Quote Link to comment Share on other sites More sharing options...
StoneAgeGamer Posted February 6, 2011 Share Posted February 6, 2011 Edited last post. Quote Link to comment Share on other sites More sharing options...
keilbaca Posted February 6, 2011 Author Share Posted February 6, 2011 Edited last post. I seen all the posts, and I see. Well good to know that at least my attempt to fix it was not in vain, a simple menu switch. Quote Link to comment Share on other sites More sharing options...
Rockin' Kat Posted February 6, 2011 Share Posted February 6, 2011 you sure are having bad luck. I'd try using DeoxIT Barring that, you could try bending the pins outward with something like a dental pick. Tried bending the pins out, and now I have to find a new cart slot <_< I tried using a needle, and it wasn't really thin enough... Ouch. I'm sorry to hear that. It might be time to just hit the marketplace and see if someone can give you a good price on a tested working one... There are a few auctions on eBay for Genesis 3 systems that say they are tested working and don't have any bids yet that have low starting bids. Quote Link to comment Share on other sites More sharing options...
Chilly Willy Posted February 6, 2011 Share Posted February 6, 2011 The Genesis 3 doesn't connect a number of lines to the cart port that are used by such things as Virtua Racing and the 32X. There are mods on the net showing how to connect the lines from the ASIC to the cart port so they work. If you're really interested in getting the Genesis 3 to work, you'll need to mod it. Most folks find it easier/cheaper to just use a Model 2 or Model 1. Quote Link to comment Share on other sites More sharing options...
mbd30 Posted February 6, 2011 Share Posted February 6, 2011 No, that would be the original NES, which was obviously designed to de-emphasize the fact that it's a video game console rather than for decent functionality. Quote Link to comment Share on other sites More sharing options...
Rev. Rob Posted February 6, 2011 Share Posted February 6, 2011 I just want to add that the Genesis 3 isn't made by Sega. It's cheaply produced by Majesco. I've never owned one, but I do own a Genesis 1, Genesis 2, 32X, CDX, and X'Eye, and have never had any problems. And mbd30 is right. NES is the worst design ever. Quote Link to comment Share on other sites More sharing options...
mbd30 Posted February 6, 2011 Share Posted February 6, 2011 And mbd30 is right. NES is the worst design ever. But they got it right with the SNES which rarely has any problems with regard to getting games to work. Sometimes you have to blow into the cartridges and that's about it. But I notice the shoulder buttons on the controller becoming less responsive. I'd like to find a decent replacement and not some horrible knockoff with stiff buttons and short cord packaged as an official SNES controller (which is what I got last time I bought a replacement pad from the local used games store). Quote Link to comment Share on other sites More sharing options...
DracIsBack Posted February 7, 2011 Share Posted February 7, 2011 Given how many crappy NESes I've seen (both front and top loading), I think the Genesis cart port is a godsend in comparison. Quote Link to comment Share on other sites More sharing options...
SRGilbert Posted February 7, 2011 Share Posted February 7, 2011 Maybe it's just me, but I consider the Genesis Model 3 to be no better than one of those many clones that are flooding the market. No 32x, no CD, does it even work with the Master System adapter? Also, no stereo sound? No thanks. Seems like the only thing it has going for it is the size, which really means nothing to me. Quote Link to comment Share on other sites More sharing options...
keilbaca Posted February 7, 2011 Author Share Posted February 7, 2011 I just want to add that the Genesis 3 isn't made by Sega. It's cheaply produced by Majesco. I've never owned one, but I do own a Genesis 1, Genesis 2, 32X, CDX, and X'Eye, and have never had any problems. And mbd30 is right. NES is the worst design ever. I must have terrible luck then. Sounds like I should go with a Genny 2 then, I had no idea that Sega didn't make the Genny 3. I'll hit up the marketplace, also Shaun said he'd dig one out for me. At the rate I'm going, it doesn't hurt to have a couple spares... Quote Link to comment Share on other sites More sharing options...
StoneAgeGamer Posted February 7, 2011 Share Posted February 7, 2011 Maybe it's just me, but I consider the Genesis Model 3 to be no better than one of those many clones that are flooding the market. No 32x, no CD, does it even work with the Master System adapter? Also, no stereo sound? No thanks. Seems like the only thing it has going for it is the size, which really means nothing to me. Actually it may be even worse than some clones. I think some clones now can play Virtual Racing and I don't believe the Genesis 3 can. Quote Link to comment Share on other sites More sharing options...
chrisbid Posted February 7, 2011 Share Posted February 7, 2011 the genesis 2 is the worst option of the three. the sound is horrible (i dont have youtube access at work, but look up some sound comparisons between genny 1 and the genny 2). Quote Link to comment Share on other sites More sharing options...
mbd30 Posted February 7, 2011 Share Posted February 7, 2011 the genesis 2 is the worst option of the three. the sound is horrible (i dont have youtube access at work, but look up some sound comparisons between genny 1 and the genny 2). Apparently some Genesis 2 revisions are worse than others, and some versions of Genesis 1 are bad too. http://www.sega-16.com/forum/showpost.php?p=161951&postcount=1 You want the Genesis 2 with the 3/4 motherboard. Quote Link to comment Share on other sites More sharing options...
keilbaca Posted February 7, 2011 Author Share Posted February 7, 2011 Ugh, really? I had no idea there was that much of a difference in sound... I'm not too worried, I'm not *that* big of a Sega fan, I just want something that's a bit more lighter than the Genny 1 to carry that I can use the Everdrive with. Quote Link to comment Share on other sites More sharing options...
