Mad Hatter Posted February 14, 2011 Share Posted February 14, 2011 Does anyone have this? I downloaded a copy from the Hidden Reef but I can't get it to work. Does anyone know what file-name the controller searches for when you select "DISK MANAGER" from the main screen? I assume I got the correct 'ware however I can't get it to load from the main screen. Quote Link to comment Share on other sites More sharing options...
marc.hull Posted February 17, 2011 Share Posted February 17, 2011 Does anyone have this? I downloaded a copy from the Hidden Reef but I can't get it to work. Does anyone know what file-name the controller searches for when you select "DISK MANAGER" from the main screen? I assume I got the correct 'ware however I can't get it to load from the main screen. For what it's worth I have never been able to figure out how to get the disk manager running. I have several copies and have tried the one on THR but they all do the same thing which is nothing (for me anyhow.) Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted February 20, 2011 Share Posted February 20, 2011 (edited) Does anyone have this? I downloaded a copy from the Hidden Reef but I can't get it to work. Does anyone know what file-name the controller searches for when you select "DISK MANAGER" from the main screen? I assume I got the correct 'ware however I can't get it to load from the main screen. For what it's worth I have never been able to figure out how to get the disk manager running. I have several copies and have tried the one on THR but they all do the same thing which is nothing (for me anyhow.) IIRC, the filename is "MANAGER", a 96 sector (24K) file. The DM is similar to DM1000 and for all I know, they have the same code base. I suspect this file is a memory dump, done to simplify the load and memory move processes. Edited February 20, 2011 by InsaneMultitasker Quote Link to comment Share on other sites More sharing options...
Mad Hatter Posted February 24, 2011 Author Share Posted February 24, 2011 The disk I'm trying has a file named MANAGER on it, and a bunch of other files for that matter. The disk drive light will come on momentarily as it searches for the program, but it will not load. No big deal really, just wanted to check it out. It's easier to use the DM2 cart anyway instead of swapping disks around. Does anyone have this? I downloaded a copy from the Hidden Reef but I can't get it to work. Does anyone know what file-name the controller searches for when you select "DISK MANAGER" from the main screen? I assume I got the correct 'ware however I can't get it to load from the main screen. For what it's worth I have never been able to figure out how to get the disk manager running. I have several copies and have tried the one on THR but they all do the same thing which is nothing (for me anyhow.) IIRC, the filename is "MANAGER", a 96 sector (24K) file. The DM is similar to DM1000 and for all I know, they have the same code base. I suspect this file is a memory dump, done to simplify the load and memory move processes. Quote Link to comment Share on other sites More sharing options...
