basic compiler
rocky007
Yeah, I encountered a bug in the compiler but I had a true TI-BASIC program (no multistatement, no logic in THEN). The problem I found was it didn't properly alter something in CALL KEY. If you stick to BASIC rules, I found nothing else...
Since I won't be doing any more BASIC programming - I won't be using the compiler anymore.
If I ever get free time again, I'll probably be checking out MLC or GCC (when we get libraries).... I can't use anything that's not released to Public Domain... So Kull's is out of the question, as intriguing as it sounds.
-H
Maybe its a bug in the compiler.
Try this as an experiment:
192 A=C(1):: IF A=31 THEN A=1:: C(1)=A
Repeat this for c(2) to c(5)
Let us know what happens.
I tried it, and it still locked as soon as the characters hit column 31. Another compiler that works with XB has been suggested, and this may be a way out. But in the long term, I think my syntax needs to be more Assembler friendly on the whole, I know nothing of Assembly, but I can imagine that it is maybe structured a little differently to XB and there's something I'm doing wrong.
TI Puck from Vorticon worked perfectly. I downloaded the TI Basic version and compiled it myself to check. The whole game runs no problem. I even added a "FOR DE=1 to 250::NEXT DE" just after the "CALL KEY" routine, to slow it down!
I just don't get it. It's baffling. Thankyou for you're feedback :)
-H
It certainly doesnt like anything with any complexity to it. I've yet to write a program that will work, that actually has more than just sped up print statements. I'll get there in the end. :)
Man, great news!!! :) Yep-- the first successful assembly experience is cool. :) Can't wait to play your game. Tursi came up with a way to put these assembly EA5 programs from Wilhelm's compiler into cart form. :)
That made my ears prick up ..... sounds interesting , putting EA5 into cart. Please point me in the right direction of Tursi's thread on this? :)
HA! XB Compilers... Pussies! :P
Real men do it in FORTH :D
FORGET X
23 VALUE X
1 VALUE C1
4 VALUE C2
8 VALUE C3
12 VALUE C4
35 CONSTANT FROG
36 CONSTANT CAR
: SETUP
 1 GMODE \ 32 COLUMN MODE
 17 4 DO I 15 1 COLOR LOOP \ SET COLORS
 HEX  DATA 4 1899 7E3C 3CBD FF5A  DECIMAL  FROG DCHAR
 HEX  DATA 4 66FF DBDB DBDB FF66  DECIMAL  CAR  DCHAR ;
: DRAW-FROG
 X 11 FROG 1 HCHAR ;
: MOVE-CARS
 12 C1 32 1 HCHAR  C1 1+ 32 MOD TO C1  12 C1 CAR 1 HCHAR
 14 C2 32 1 HCHAR  C2 1+ 32 MOD TO C2  14 C2 CAR 1 HCHAR
 16 C3 32 1 HCHAR  C3 1+ 32 MOD TO C3  16 C3 CAR 1 HCHAR
 18 C4 32 1 HCHAR  C4 1+ 32 MOD TO C4  18 C4 CAR 1 HCHAR ;
: MOVE-FROG
 KEY?
 CASE
   69 OF
     X 11 32 1 HCHAR
     -1 +TO X
   ENDOF
   88 OF
     X 11 32 1 HCHAR
     X 1+ DUP 24 = IF DROP 23 THEN TO X
   ENDOF
 ENDCASE ;
: FINISHED?
 X IF FALSE ELSE ." WELL DONE!" TRUE THEN ;
: DEAD?
 X 11 GCHAR
 CAR = IF
   ." YOU'RE DEAD!" TRUE
 ELSE
   FALSE
 THEN ;
: RUN
 SETUP  23 TO X
 BEGIN
   DRAW-FROG
   MOVE-FROG
   MOVE-CARS
   DEAD?  FINISHED?  OR
 UNTIL CR ;
http://www.youtube.com/watch?v=W2UXBasc8jw
Don't be afraid to ask questions if you want to know how the code works!
Mark
FORGET X
23 VALUE X
1 VALUE C1
4 VALUE C2
8 VALUE C3
12 VALUE C4
35 CONSTANT FROG
36 CONSTANT CAR
: SETUP
: DRAW-FROG
 X 11 FROG 1 HCHAR ;
: MOVE-CARS
: MOVE-FROG
 KEY?
 CASE
   69 OF
     X 11 32 1 HCHAR
     -1 +TO X
   ENDOF
   88 OF
     X 11 32 1 HCHAR
   ENDOF
 ENDCASE ;
: FINISHED?
: DEAD?
 X 11 GCHAR
 CAR = IF
 ELSE
   FALSE
 THEN ;
: RUN
 SETUP  23 TO X
 BEGIN
   DRAW-FROG
   MOVE-FROG
   MOVE-CARS
   DEAD?  FINISHED?  OR
 UNTIL CR ;
Mark
Willsy you truly are a legend! :cool:
Forth!!!!!!! Well, this is actually swinging me away from Assembler compilers ..... All I need is this sort of thing, you know,
Forth source, and you took my game and did this. Man , May The Forth by with you!
How would you slow down the game ... what is the Forth equivelant to "For A=1 to 50::next A" ? :)
50 FOR NEXT
But probably better to put it into it's own routine. A value of about 500 seems about right...
: DELAY 500 FOR NEXT ;
I also switched MOVE-FROG and DRAW-FROG around. Much better movement now... I didn't notice before as it was all a bit too fast...!
Mark :D
23 VALUE X
1 VALUE C1
4 VALUE C2
8 VALUE C3
12 VALUE C4
35 CONSTANT FROG
36 CONSTANT CAR
: SETUP
: DRAW-FROG
 X 11 FROG 1 HCHAR ;
: MOVE-CARS
: MOVE-FROG
 KEY?
 CASE
   69 OF
     X 11 32 1 HCHAR
     -1 +TO X
   ENDOF
   88 OF
     X 11 32 1 HCHAR
   ENDOF
 ENDCASE ;
: FINISHED?
: DEAD?
 X 11 GCHAR
 CAR = IF
 ELSE
   FALSE
 THEN ;
: DELAY
 500 FOR NEXT ;
: RUN
 SETUP  23 TO X
 BEGIN
   MOVE-FROG
   DRAW-FROG
   MOVE-CARS
   DELAY
   DEAD?  FINISHED?  OR
 UNTIL CR ;
