Comments or Suggestions for newbie game?
Have you posted this in the batari Basic forum yet? I know you haven't included the code for us to look at, but the other batari Basic programmers would probably enjoy trying out the game and offering batari Basic programming examples.
What's the easiest way of having a new playfield come? For example, I want player0 to reach the end of the screen, which will prompt the new screen.
This is a very basic example, and there are surely better ways to do it, but I want to keep it simple.
  rem * example of moving between rooms
  dim room_number = a
  dim movement = b
  room_number = 1 : rem so you can go left or right from the start
  movement = 0 : rem not moving yet
  COLUBK = $00 : rem black
  player0:
  %11000011
  %01100110
  %00111100
  %00011000
  %00011000
  %11111111
  %00011000
  %00011000
end
  player0x = 17
  player0y = 64
main_loop
  COLUP0 = $3A : rem peach
  player0x = player0x + movement : rem move player0
  on room_number gosub room0 room1 room2 : rem draw the room
  drawscreen : rem draw the screen
  if collision(player0,playfield) then player0x = player0x - movement
  rem knock player0 back if collided with playfield
  movement = 0 : rem reset movement before checking joystick
  if joy0left then movement = 255 : rem 255 is equal to -1 (left)
  if joy0right then movement = 1 : rem 1 is equal to +1 (right)
  if player0x = 16 then gosub room_to_the_left
  if player0x = 137 then gosub room_to_the_right
  goto main_loop
room0
  COLUPF = $1C
  playfield:
  X...............................
  XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
end
  return
room1
  COLUPF = $4C
  playfield:
end
  return
room2
  COLUPF = $8C
  playfield:
  ...............................X
end
  return
room_to_the_left
  room_number = room_number - 1
  player0x = 136
  return
room_to_the_right
  room_number = room_number + 1
  player0x = 17
  return
Basically, you can check the player's x coordinate to see if he's moved to a point where you want the screen to change. You would also want to make him disappear off of one side and reappear on the other side-- i.e., if he moves off the left edge of one screen, he would end up near the right edge of the new screen, or vice versa.
Also, does the AA store make 8K custom carts? This, when finished, definently won't fit 4k.
You should PM Albert and ask him. If he can't accommodate you, there are also other places where you can get your games made into cartridges. :)
Michael
PS -- In your game, pressing fire continuously causes the man to "levitate." There should be some examples of programming a jumping/falling sprite with "gravity." My little example has no vertical movement or jumping/falling/gravity, just horizontal motion.
example_of_moving_between_rooms.bas.bin
Once again, the encouragement and support from the forum is outstanding.
You could try posting your game in the Homebrew Discussion section on AA to get more coverage. Some people will only download and play the game if it looks interesting to them. With that in mind, adding screenshots and inventing a back story to draw the potential player into the game might help too. The back story should cover who you are playing as and why you are doing the things in the game.
