Meltdown
You've got to save the nuclear reactor from a meltdown. A very cool game from an issue of
"Home Computer Magazine".
Years ago when I typed it in, I altered it by including instructions/story from the mag. I've tightened the code and tried to make sprite coincidences better. Later, I added some assembly language routines to speed things up using a utility called "ALSAVE" (which allows a normal Extended BASIC progam to save 'hidden' assembly along with the program). So, don't edit/resequence or it will get messed up.
MELTDOWN.zip
Edited by GratedTopping
I liked this game but it is true that it isn't as responsive as it could be. I know I cut out one of the sounds made when the oxygen is being depleted (two was unnecessary). I imagine that making the main character not have a walking animation would help with sprite COINCidences. Maybe making the 'squiggly line' that you fire move slower could help in that area, too. Changes can be made to the program further down in the line numbers without problems, I believe.
I know that I read somewhere, probably in a MICROpendium, about how you could still 'unhide' and retrieve assembly code that was hidden in an ExB program with ALSAVE. I think it had a companion program for that purpose. It seems that I used some code that was supposed to help improve responses from joystick or keyboard and I have no idea where I got that from and would like to see that again. I'm not sure it helped much, though. Perhaps in CPU overdrive under "Classic99" it would be better?
I think this performed much better on the real hardware.
It's probably a matter of taste. I had the C64 version back in the day. Quite hectic, but I didn't play it too much. Someone compared it with Tempest. Would be nice to see you develop it further.
http://www.youtube.com/watch?v=mgEWnYsACFk
http://www.youtube.com/watch?v=RkTPjypnqyI
http://www.youtube.com/watch?v=MO1fid9sD8U
Updated it a bit:
- CALL CLEARs are now DISPLAY ERASE ALL (it's how I like it)
- main-character's walking sounds are gone (slowed things down)
- other sounds' lengths made shorter (I never even realized, though obvious, that a command following a CALL SOUND won't execute until the sound is completed)
The CALL COINC detection still isn't the best, but it's all fun.
Does anybody think that the CALL LINK which apparently allows monitoring of keyboard and joystick in one statement, could actually slow things down somehow?
Have you tried with negative duration ?
CALL SOUND(duration, frequency, volume ...
Duration is from .001 to 4.250 seconds, although it may only vary up to 1/60th of a second. The computer continues performing program statements while a sound is being played. When you call the SOUND subprogram, the computer waits until the previous sound has been completed before performing the new CALL SOUND. However, if a negative duration is specified, any previous sound is stopped and the new one is begun immediately.
Edited by sometimes99er
