+atari2600land Posted March 21, 2011 Share Posted March 21, 2011 The reset button for my Sega Genesis doesn't do anything, and I was wondering what the problem might be and if I can fix it myself. Quote Link to comment Share on other sites More sharing options...
CGQuarterly Posted March 21, 2011 Share Posted March 21, 2011 If the button works like controller buttons do, you might just need to clean the contacts. I don't really see what else it could be. Take your console apart and clean the contacts with a white eraser to get rid of any oxidation and built-up dirt. Chris Quote Link to comment Share on other sites More sharing options...
Itchy Koala Posted March 21, 2011 Share Posted March 21, 2011 Aren't the genesis buttons spring loaded? It might just be off-set or some kind of mechanical issue probably Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted March 22, 2011 Author Share Posted March 22, 2011 What size screws do they use to screw the thing shut? I have unsuccessfully attempted to unscrew the stupid things. Quote Link to comment Share on other sites More sharing options...
nathanallan Posted March 22, 2011 Share Posted March 22, 2011 The case screws? I use a cheap-o screwdriver, they are not very small. The same screwdriver I use to take apart a 2600 I use for the Genesis. Some soldering might be involved, if the button can't be cleaned go ahead and replace it. Not too hard to do. Quote Link to comment Share on other sites More sharing options...
zylon Posted March 24, 2011 Share Posted March 24, 2011 Genny's use a carbon dot under a rubber boot sealed to its base. You can replace it with a 7800 style microswitch. Quote Link to comment Share on other sites More sharing options...
