MADS Knowledge-Base
tim(), .time etc. this functionality will have a limited range of applications
universal solution:
For /f "tokens=1-4 delims=/-" %%a in ("%DATE%") do (
    SET YYYY=%%a
    SET MM=%%b
    SET DD=%%c
For /f "tokens=1-4 delims=/:.," %%a in ("%TIME%") do (
    SET HH24=%%a
    SET MI=%%b
    SET SS=%%c
    SET FF=%%d
mads.exe time.asm -pl -d:year=%YYYY% -d:month=%MM% -d:day=%DD% -d:hour=%HH24% -d:minute=%MI% -d:second=%SS%
http://stackoverflow.com/questions/1192476/windows-batch-script-format-date-and-time
http://stackoverflow.com/questions/4248220/how-can-i-retrieve-the-seconds-part-of-time-in-cmd
time_date.zip
Edited by tebe
Having an excellent cross-platform tool like MADS and then forcing poeple to use platform specific batch scripts really brings me down. Every C compiler offers __DATE__ and __TIME__... :-(
Edited by JAC!
  • 3 weeks later...
Oops, spoke too soon on the .FL fix -- it is losing significant digits between 10^-3 and 10^-9 (MADS 1.9.8 build 5):
    48 20F0 3E 12 34 56 79 00           .fl     1.23456789e-3
    49 20F6 00 00 00 00 00 00 +         :10 dta 0
    50
    51 2100 3E 01 23 45 68 00           .fl     1.23456789e-4
    52 2106 00 00 00 00 00 00 +         :10 dta 0
    53
    54 2110 3D 12 34 57 00 00           .fl     1.23456789e-5
    55 2116 00 00 00 00 00 00 +         :10 dta 0
    56
    57 2120 3D 01 23 46 00 00           .fl     1.23456789e-6
    58 2126 00 00 00 00 00 00 +         :10 dta 0
    59
    60 2130 3C 12 35 00 00 00           .fl     1.23456789e-7
    61 2136 00 00 00 00 00 00 +         :10 dta 0
    62
    63 2140 3C 01 23 00 00 00           .fl     1.23456789e-8
    64 2146 00 00 00 00 00 00 +         :10 dta 0
    65
    66 2150 3B 12 00 00 00 00           .fl     1.23456789e-9
    67 2156 00 00 00 00 00 00 +         :10 dta 0
    68
    69 2160 3B 01 00 00 00 00           .fl     1.23456789e-10
    70 2166 00 00 00 00 00 00 +         :10 dta 0
    71
    72 2170 3A 12 34 56 78 90           .fl     1.23456789e-11
    73 2176 00 00 00 00 00 00 +         :10 dta 0
    74
    75 2180 3A 01 23 45 67 89           .fl     1.23456789e-12
    76 2186 00 00 00 00 00 00 +         :10 dta 0
float .FL fixed (line 9033: if x<1e-2)
line 777: pass_max = 20
.rept bug fixed
.rept 4
/* lda #0
*/ nop
.endr
mads_02.02.2014.zip
Is there a way to find out the length of the file imported to an array using ".GET"? I wand to do
MAIN.ASM
.GET "TEXT.TXT"
ICL "INCLUDE.ASM"
INCLUDE.ASM
.SAV // Store the file content here, but .SAV has the length as mandatory parameter
There is something about the the behaviour of .zpvar and .var that puzzles me:
.zpvar does not need an address at the end, but .var does. Is this correct behaviour?
see code below. The line ".var c1 .byte" throws an error:
pagezero_start	=	$a0
.zpvar	a	.byte = pagezero_start
.zpvar	b,c	.byte
.zpvar	d	:10	.byte
.zpvar	e	.byte	; this all works...
highmem_start	=	$ec00
.var	a1,b1	.byte	= highmem_start
.var	c1	.byte	; ...but this line gives an error: "varstest.asm (11) ERROR: Variable address out of range"
	ORG 4096
	RUN start_main
start_main
	nop
MAIN.ASM
.GET "TEXT.TXT"
ICL "INCLUDE.ASM"
INCLUDE.ASM
.filesize 'filename'
.filesize('filename')
.len 'filename'
.len('filename')
.zpvar	b,c	.byte
.zpvar	d	:10	.byte
	ORG 4096
	RUN start_main
start_main
	nop
its correct
.zpvar = expression
.var is different, stored data if detected ORG, .ENDP, .ENDL
.local temp
.var a,b,c .word
 nop
.endl             ; -> stored A,B,C (word)
org $ec00
.var a1,b1 .byte = $8000
.var c1 .byte
; a1,b1 - > $8000
; c1 -> $ec00
in your example, ORG is missing, undefined adress
you need segment (.var not working with segment, probably bug)
.segdef high_mem, $ec00, $100,rw
org $8000
.segment high_mem
a1 .byte
b1 .byte
c1 .byte
.endseg
nop
nop
.segment high_mem
d .word
e .word
.endseg
nop
nop
Edited by tebe
Hello tebe,
Segment is not quite what I need, it also writes the segment to the obx file (which is not needed). The output of mads -l:
     1                 .segdef highmem, $ec00, 512, rw
     3                     ORG 2048
     4                 .segment highmem
     5 FFFF> EC00-EDFF> 00 00 + a1    :256    .byte
     6 ED00 00 00 00 00 00 00 + a2    :256    .byte
     7 EE00            .endseg
I only want the addresses of the labels, so I found a workaround using struct:
.struct highmem_struct
    pm_0    :256    .byte
    pm_1    :256    .byte
    pm_2    :256    .byte
    pm_3    :256    .byte
.ends
.var    highmem    highmem_struct    =    $f000
Hello,
I have a problem with simple code dealing with byte variables. Instead of byte values assigned in i, j and n byte variables the program shows word values for the first two variables. I tried also with dta b, dta l and dta h... but it didn't work either. Please tell me where in the code is the problem, thanks!
MADS program
org $3200
main
.var i, j, n .byte
mva #20 i
mva #50 j
mva #120 n
jsr printf
.by $9b 'i = %' $9b 0
dta a(i)
jsr printf
.by $9b 'j = '
dta c'%',$9b,0
dta a(j)
jsr printf
.by $9b 'n = %' $9b $9b 0
dta a(n)
jmp *
.link 'libraries/stdio/lib/printf.obx'
run main
Output
i = 12820
j = 30770
n = 120
vars.obx
vars.asm
another question...
when I am using .macro
and want to do something like this
.macro calc
lda :1
sta :2
.endm
reference
calc buffer,output
I got an illegal adressing mode error while compiling?
Depends how you're calling it. This may be relevant if you require immediate addressing:
ldax .macro	" "	; load a,x pair
	.if :1 = '#'
		lda #< :2
		ldx #> :2
	.else
		lda :2
		ldx :2+1
	.endif
	.endm
Also this:
http://atariage.com/forums/topic/192375-mads-macrosprocedures/?do=findComment&comment=2907500
Edited by flashjazzcat
ok... can someone explain why this not work?
What are the parenthesis for? What's "+#" supposed to do? If you call it with simply ":10 calc buffer", will it not work?
EDIT: Answer to that is - yes it will compile as ":10 calc buffer", but I don't know whether it compiles into the code you expect it to produce.
