WinFLASH
Hello all,
yesterday i have added a webpage with info about my Windows-based tool WinFLASH V1.2 for the Atari Flashcard, you can find it in the tools section of my Jaguar-website, on the webpage are links for ZIP-archives with the executable and the Visual C++ source, as well as links to the website of the printer-port driver DLL you'll need to get my program work.
Here is the link to the WinFLASH webpage:
http://www.mdgames.de/jaguar_winflash.html
Kind regards
Matthias
  • Like 9
  • 2 weeks later...
  • 2 weeks later...
Hello!
Excellent! I was pondering flashing some of my stuff to my flashcart for demo'ing at the pub and wondered how I would accomplish that. Now I have the answer! top news!
So did it work for you and all the other who tried it out?
I am asking because i wasn't able to test it before releasing it.
Kind regards
Matthias
Hello!
Sorry not had need or chance to try it out yet. Will also need to dig out a cable for it too.
I'll let you know once I do.
  • 2 weeks later...
Hello!
Do you need an old computer with parallel port to program it ?
Yes, Atari's FLASH-card uses a parallel-port cable connection (DSUB-25 to DSUB25), and Atari provided a DOS-based program that communicates with the FLASH-card via the printer-port.
Or is there a usb -> parallel cable that works under windows 7 that will do ?
This could be possible, but i don't have any experience with such USB-to-Printer-cables.
(For my development-work i use a "Jaguar era"-compatible Win98SE-PC with both real printer and real serial ports).
Like the skunkboard the cartridge needs to be in the atari jaguar to be programmed or there is a way to give it power away from the jaguar ?
No, you need to have the Atari FLASH-card inserted in the Jaguar's cartridge slot, the FLASH-card is not an autonome device.
Kind regards
Matthias
I tested two such cables (based on two different chips). Both of them are compatible with the standard printer protocol only ; otherwise, they don't work at all.
So unless the Flash cart protocol is compatible, it won't work.
Edited by Zerosquare
