thegamezmaster Posted May 18, 2011 Share Posted May 18, 2011 I have an 80g non backwards compatible ps3 in good working order. I have the chance to trade for an original 80g with backwards compatibility for ps2. I've checked the serial numbers. The only problem with the bc ps3 is there is no composite video output but does have s video out. I only have a standard tv. I've looked on the net and can't find anything about this problem. I've switched cables, doesn't help. Ive tested the bc one and except for the problem mentioned, it seems to work fine. Anyone have an opinion or suggestion on this. I'm leaning towards trading him. Any thoughts would help,thanks. Quote Link to comment Share on other sites More sharing options...
HammR25 Posted May 18, 2011 Share Posted May 18, 2011 So the BC PS3 won't work correctly with something like this? Was the PS3 being used with an HDTV before you tried hooking it up to your old tv? If that's the case you may need to simply reset the console to it's default so it'll show on the older screen. http://www.portfolioofpb.com/blog/ps3-blank-screen-switch-inputs-hdmi-to-composite-to-hdmi Quote Link to comment Share on other sites More sharing options...
thegamezmaster Posted May 18, 2011 Author Share Posted May 18, 2011 (edited) I've tried the hold down to switch the video no luck.All I get is a black screen with faint re and blue I think running diagonally through the picture in composite. Edited May 18, 2011 by thegamezmaster Quote Link to comment Share on other sites More sharing options...
cybercylon Posted May 21, 2011 Share Posted May 21, 2011 (edited) I have an 80g non backwards compatible ps3 in good working order. I'll stop you right there. I may have same option (trade), but I don't think I will bother. If what you have is already in good working order, I'm not sure if trading it in for a system that has an older optical drive and has crappy software BC would be worth it to you. I'd say pick up a PS2 slim on the cheap Edited May 21, 2011 by cybercylon Quote Link to comment Share on other sites More sharing options...
HammR25 Posted May 22, 2011 Share Posted May 22, 2011 I've tried the hold down to switch the video no luck.All I get is a black screen with faint re and blue I think running diagonally through the picture in composite. If that doesn't work I'd avoid it like the plague. Quote Link to comment Share on other sites More sharing options...
+save2600 Posted May 22, 2011 Share Posted May 22, 2011 In any event, the controller pictured in your avatar and the games it plays is worth 100x more than any modern game system Quote Link to comment Share on other sites More sharing options...
thegamezmaster Posted May 23, 2011 Author Share Posted May 23, 2011 In any event, the controller pictured in your avatar and the games it plays is worth 100x more than any modern game system Even if it don't work like when it was new? You interested? Quote Link to comment Share on other sites More sharing options...
