esplonky Posted July 16, 2011 Share Posted July 16, 2011 can someone help me out? i am only 15 at the moment, stubborn, and need a fast, easy way to learn 6502. not necessarily become fluent just yet, but to learn the basics. i already read some of "Atari Roots" but i dont have an atari 800 or 400 and i dont plan on buying one. i know these basic things so far off/on, yes/no, white/black, the whole concept of the numbers 1 and 0 i know that 1111 1111 = 255 and that's all that 8-bit can handle. that's all i know about 6502, and i really need help, any help is appreciated! Quote Link to comment Share on other sites More sharing options...
Wickeycolumbus Posted July 16, 2011 Share Posted July 16, 2011 This book is probably the best. It's how I learned http://www.atariarchives.org/mlb/ 2 Quote Link to comment Share on other sites More sharing options...
esplonky Posted July 16, 2011 Author Share Posted July 16, 2011 thanks! ill jump into that! Quote Link to comment Share on other sites More sharing options...
esplonky Posted July 17, 2011 Author Share Posted July 17, 2011 how long did it take you to learn from this book Quote Link to comment Share on other sites More sharing options...
Wickeycolumbus Posted July 17, 2011 Share Posted July 17, 2011 how long did it take you to learn from this book The learning doesn't stop with the book, you learn more and more with each project. Just read the book slowly, take in as much as possible, and you'll be fine. Quote Link to comment Share on other sites More sharing options...
Yart Posted September 9, 2011 Share Posted September 9, 2011 (edited) This is awesome. I've been wanting to learn ASM for a while too but I had a hard time with every other resource. I like how this guy compares the routines to BASIC. Makes it so much easier for me to learn. Though from what I understand this is for the Atari 8-Bit line of computers and not the 2600 eh? Still a good learning point (and I hear the 2600 is much harder anyways). What's a good assembly compiler for Windows to use for Atari computer applications? Will DASM work? Edited September 9, 2011 by Yart Quote Link to comment Share on other sites More sharing options...
danwinslow Posted September 9, 2011 Share Posted September 9, 2011 I like CC65 myself. www.cc65.org Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted September 9, 2011 Share Posted September 9, 2011 Remember to check this out when you get a chance: http://www.randomterrain.com/atari-2600-memories.html#assembly_language And be sure to check out the useful links: http://www.randomterrain.com/atari-2600-memories-tutorial-andrew-davie-01.html#useful_links Quote Link to comment Share on other sites More sharing options...
Mr SQL Posted September 9, 2011 Share Posted September 9, 2011 The Batari compiler produces an .asm output file which does a really good job of showing you how your code is translated into assembly; that is a great way to learn along with a good book on the basics of Assembly to help explain what is going on. Quote Link to comment Share on other sites More sharing options...
esplonky Posted September 10, 2011 Author Share Posted September 10, 2011 Can someone show me how to install dasm on my Linux computer? Quote Link to comment Share on other sites More sharing options...
Joe Musashi Posted September 10, 2011 Share Posted September 10, 2011 Can someone show me how to install dasm on my Linux computer? As far as I can see, the recent stable DASM version 2.20.11 does not come with binaries for Linux, just source. You would have to compile it yourself. Unfortunately, this is not straightforward, so another thing you can do is to download an older version. E.g., you can get DASM 2.20.10 If you unzip it, there's a folder bin/Linux, which contains three executables. One of them might work for you on Fedora. You do not have to install dasm. Just copy the executables to wherever you want. E.g. if you copy dasm to /usr/local/bin you should be able to start it in the shell with just "dasm". Quote Link to comment Share on other sites More sharing options...
esplonky Posted September 10, 2011 Author Share Posted September 10, 2011 Sweet thx Quote Link to comment Share on other sites More sharing options...
esplonky Posted September 10, 2011 Author Share Posted September 10, 2011 i go to /home/esplonky/dasm/bin/Linux and they i type "dasm" and it says "command not found" Quote Link to comment Share on other sites More sharing options...
RevEng Posted September 10, 2011 Share Posted September 10, 2011 You probably don't have that directory or "." in your PATH variable. Try typing "./dasm" instead. Quote Link to comment Share on other sites More sharing options...
Joe Musashi Posted September 10, 2011 Share Posted September 10, 2011 Also, if you have not done already, make sure it can be executed by setting the executable (X) flag: "chmod 777 dasm" (to check the flags, type "ls -l dasm", you can get more info about chmod with "man chmod" or see here http://www.ee.surrey.ac.uk/Teaching/Unix/unix5.html) Quote Link to comment Share on other sites More sharing options...
esplonky Posted September 11, 2011 Author Share Posted September 11, 2011 (edited) joe got me up and running, butttttttt i have one problem. every time i assemble my source code (see below) i get an error message (see below also!) *=1000 LDA #4 STA 400 STA 1000 LDX #5 LDY #6 STX 500 STY 600 LDA 1000 LDX 500 LDY 600 BRK [root@Esplonky Linux]# ./dasm test.asm DASM V2.20.10, Macro Assembler (C)1988-2004 test.asm (1): error: Unknown Mnemonic '*=1000'. test.asm (3): error: Unknown Mnemonic 'LDA'. test.asm (4): error: Unknown Mnemonic 'STA'. test.asm (5): error: Unknown Mnemonic 'STA'. test.asm (6): error: Unknown Mnemonic 'LDX'. test.asm (7): error: Unknown Mnemonic 'LDY'. test.asm (: error: Unknown Mnemonic 'STX'. test.asm (9): error: Unknown Mnemonic 'STY'. test.asm (10): error: Unknown Mnemonic 'LDA'. test.asm (11): error: Unknown Mnemonic 'LDX'. test.asm (12): error: Unknown Mnemonic 'LDY'. test.asm (13): error: Unknown Mnemonic 'BRK'. Complete. and my code above was changed by me because i was tweaking to see if it would compile, so ive tried with all kinds of indentions and stuff. Edited September 11, 2011 by esplonky Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted September 12, 2011 Share Posted September 12, 2011 (edited) DASM supports multiple processors, so you have to tell it which one you're writing code for. PROCESSOR 6502 ORG 1000 LDA #4 STA 400 STA 1000 LDX #5 LDY #6 STX 500 STY 600 LDA 1000 LDX 500 LDY 600 BRK Edited September 12, 2011 by SpiceWare Quote Link to comment Share on other sites More sharing options...
esplonky Posted September 12, 2011 Author Share Posted September 12, 2011 now how would i make it a .bin file? cus everytime i assemble, and i say "./dasm test.asm -f#.bin" of "./dasm test.asm -f bin" i get "illegal output format" Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted September 12, 2011 Share Posted September 12, 2011 The -f should be followed by an actual number, not #. 3 means don't include the start address as the 2600 doesn't use it. This is how I compile Frantic: ./dasm frantic.asm -f3 -v0 -sfrantic.sym -lfrantic.lst -ofrantic.bin -v0 is how verbose (wordy) the output is during the compile -s is the symbol file, it lists all the variables and labels and what their values are. There's no space between the option and the file name (as with the next 2 options). -l is the full compiler listing -o is the binary file you want to create The extra files are helpful for figuring things out, but you don't need to use them. ./dasm test.asm -f3 -otest.bin you can even leave off the -o part, if you do the .bin would be called a.out Quote Link to comment Share on other sites More sharing options...
esplonky Posted September 13, 2011 Author Share Posted September 13, 2011 sweet thanks!!! Quote Link to comment Share on other sites More sharing options...
GonzoGamer Posted December 5, 2011 Share Posted December 5, 2011 check out this link http://www.atariarchives.org/mlb/index.php Quote Link to comment Share on other sites More sharing options...
esplonky Posted April 13, 2012 Author Share Posted April 13, 2012 Thanks everyone, I am going to learn 6502 asm on my new Atari 800xl, and will use Machine Language for Beginners, and The Second Book of Machine Language. thanks for your help everyone! 1 Quote Link to comment Share on other sites More sharing options...
