candle Posted January 29, 2013 Author Share Posted January 29, 2013 could someone who has ntsc machine do me a picture of screen he is getting on? don't know how many lines there are for ntsc user to see, and my telly won't display ntsc at all Quote Link to comment Share on other sites More sharing options...
Frankie Posted January 29, 2013 Share Posted January 29, 2013 It's scrolling pretty fast, so it's blurry - Quote Link to comment Share on other sites More sharing options...
candle Posted January 29, 2013 Author Share Posted January 29, 2013 thanks i see my instructions are almost usable Quote Link to comment Share on other sites More sharing options...
MEtalGuy66 Posted January 29, 2013 Share Posted January 29, 2013 (edited) Tell the NTSC guys to take apart their monitor and adjust the VSIZE pot.. Or even better... Get a PAL ANTIC.. Edited January 29, 2013 by MEtalGuy66 Quote Link to comment Share on other sites More sharing options...
Marius Posted January 29, 2013 Share Posted January 29, 2013 On the MyIDE ][ his Fat32 loader indeed does not work. It has something to do with the CF card not enabled on bootup stage. If you want to make this compatible with MyIDE ][ you need some technical information about MyIDE ][ I guess. Anyway, it works great on MyIDE I. Although the absence of a RTC makes that the line with the timer does do weird things. I'm still testing things and games out, but everything works great so far. Quote Link to comment Share on other sites More sharing options...
candle Posted January 29, 2013 Author Share Posted January 29, 2013 try this one fat32-side.xex fat32-incognito.xex fat32-myide.xex fat32-intmyide.xex 1 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted January 29, 2013 Share Posted January 29, 2013 On the MyIDE ][ his Fat32 loader indeed does not work. It has something to do with the CF card not enabled on bootup stage. If you want to make this compatible with MyIDE ][ you need some technical information about MyIDE ][ I guess. I have all the info pertaining to card unlocking (having implemented same in MYIDE2.SYS) - so if Candle decides to go for it, no problem. Quote Link to comment Share on other sites More sharing options...
Frankie Posted January 29, 2013 Share Posted January 29, 2013 try this one That fits now! Quote Link to comment Share on other sites More sharing options...
Marius Posted January 29, 2013 Share Posted January 29, 2013 It runs definately an amazing lot of titles. Great. The only title (so far) that does not run is my own created .XEX from the Cart Version of David's Midnight Magic; but that one has a memlo of $0800 so that can not run. It only works on emulator or from a bootdisk, I haven't found a working file loader so far able to boot this. Except for the FAT32 loader from MyIDE ][ but that isn't a fair comparison, since that one first loads the complete file into SRAM and then it does some examination on the file. If you are interested in that DAVIDMM.XEX let me know. Quote Link to comment Share on other sites More sharing options...
candle Posted January 29, 2013 Author Share Posted January 29, 2013 sure Marius, just post it here, or if you don't want to, pm it Sebastian 1 Quote Link to comment Share on other sites More sharing options...
+CharlieChaplin Posted January 29, 2013 Share Posted January 29, 2013 It runs definately an amazing lot of titles. Great. The only title (so far) that does not run is my own created .XEX from the Cart Version of David's Midnight Magic; but that one has a memlo of $0800 so that can not run. It only works on emulator or from a bootdisk, I haven't found a working file loader so far able to boot this. Except for the FAT32 loader from MyIDE ][ but that isn't a fair comparison, since that one first loads the complete file into SRAM and then it does some examination on the file. If you are interested in that DAVIDMM.XEX let me know. hmmm, two more ideas: 1) if the file is smaller than 32kbytes, one could use "Super-Copy" to relocate it to $1F00-xxxx and RUN adress 1F3F. Most PCS pinballs are just 30kbytes / 242 sectors in size, however the DMM cart version could be somewhat bigger/longer... 2) if the file size is bigger than 32kbytes, one could use "Super Packer" (PC version by TeBe) to pack it and move to a different memory location... Just send me a copy and I will try to examine your file version of DMM... -Andreas Koch. 1 Quote Link to comment Share on other sites More sharing options...
Marius Posted January 29, 2013 Share Posted January 29, 2013 here it is... and in another topic ( this one: http://www.atariage.com/forums/topic/207712-how-to-make-your-own-bootdisk/page__hl__+own%20+boot#entry2679080 ) I posted the ATR I created with a self written loader. In that topic a lot of interesting replies btw about creating this kind of stuff. I was not able to make a working .xex ... It was a bit too complicated (all those PC relatedntools people advised... I'm not a PC/MAC man... so if someone else can create a working .XEX I would be happy) Thanks for all the support people! Quote Link to comment Share on other sites More sharing options...
Marius Posted January 29, 2013 Share Posted January 29, 2013 @Candle btw. did you see my note on the 'rtc' line driving nuts on MyIDE? I guess that is because no RTC is available. Not really a problem, but it looks a bit ehm... stressed Quote Link to comment Share on other sites More sharing options...
Marius Posted January 29, 2013 Share Posted January 29, 2013 Hi Candle, Just found a 32MB CF card, which appears to work... this one is format FAT16 But: on some directories I do not see all entries, but after a few files I see garbage and then nothing. Some directories are full of garbage. The only thing I could think of: is there a limitation on file-name-length on FAT16 which does not exist on FAT32? The files that are listed right, appears to run fine. The garbage-filenames do not load (it's not just the filename that is wrong abviously) The card is ok, the data is not corrupt. Quote Link to comment Share on other sites More sharing options...
candle Posted January 29, 2013 Author Share Posted January 29, 2013 now it will load david3.xex 1 Quote Link to comment Share on other sites More sharing options...
a8isa1 Posted January 29, 2013 Share Posted January 29, 2013 (edited) Firstly Candle, thanks for all the work you do to support the Atari 8bit community. I seem to be having a problem with the new version of FAT32 Loader (internal MyIDE version). The following games do not load with their symptoms. All of these same games load fine from the very same CF card with your first version of FAT32 Loader (the one that does not sort the file names). Electrician - blue screen with a flickering block cursor Crossbow (Fandal), Commando, Commando+ - all freeze when prompted to press a key. Henry's House - scrambled video display Marbles (Compute!) - black screen All the other games I've tried load fine. -SteveS Edited January 29, 2013 by a8isa1 Quote Link to comment Share on other sites More sharing options...
candle Posted January 29, 2013 Author Share Posted January 29, 2013 (edited) Marius, make a dump using usb image tool and make it available for download Steven, please post xex files here Edited January 29, 2013 by candle Quote Link to comment Share on other sites More sharing options...
candle Posted January 29, 2013 Author Share Posted January 29, 2013 electrician - tested 7 version i have, all of them loads henry's house - 4 version tested, all load crossbow - tested 2 version, all load and run commando+ - loads and runs commando - garbage on the screen (have this as commando v3) marbles - don't have it, sorry Quote Link to comment Share on other sites More sharing options...
+CharlieChaplin Posted January 29, 2013 Share Posted January 29, 2013 Hmm, I don`t think its the case, but anyways. MS-DOS 6.22 uses FAT16, only 8.3 filenames are allowed and it has a 1024 files limit per Directory. Maybe the same is true for a 32MB CF card... If so, use 8.3 filenames only and less than 1024 A8 files per directory. -Andreas Koch. Quote Link to comment Share on other sites More sharing options...
candle Posted January 29, 2013 Author Share Posted January 29, 2013 this is all handled already, image will tell it all, instead of gueswork Quote Link to comment Share on other sites More sharing options...
a8isa1 Posted January 29, 2013 Share Posted January 29, 2013 Marius, make a dump using usb image tool and make it available for download Steven, please post xex files here All files were obtained from Kheffington's disk set (see below). Kheffington also provided a convient ZIP of the entire file tree. link http://www.atariage.com/forums/topic/187482-4-atari-16mb-hard-disk-images-completed/page__hl__%20kheffington%20%20disk%20%20set Quote Link to comment Share on other sites More sharing options...
candle Posted January 30, 2013 Author Share Posted January 30, 2013 fixed fat16 directory issues fat32-side.xex fat32-incognito.xex fat32-myide.xex fat32-intmyide.xex 2 Quote Link to comment Share on other sites More sharing options...
Marius Posted January 30, 2013 Share Posted January 30, 2013 This did the trick indeed. I didn't change my 32MB card, so this morning I tried the new version, and the directory entries are all listed well. (Including long file names!) Quote Link to comment Share on other sites More sharing options...
Marius Posted January 30, 2013 Share Posted January 30, 2013 now it will load Thanks a lot! It's a great version of DMM since this version can be played 100% with joystick (previous releases of DMM need keyboard control for some of the pinball effects/features). Quote Link to comment Share on other sites More sharing options...
a8isa1 Posted January 30, 2013 Share Posted January 30, 2013 (edited) fixed fat16 directory issues This release solved my problems as well! All the games that I mentioned having troubles with are now loading and running. Thanks! -SteveS p.s. The info line and the scrolling instructions are working perfectly on my NTSC 800XL. Edited January 30, 2013 by a8isa1 Quote Link to comment Share on other sites More sharing options...
