CPU memory viewer
I wrote a little utility for watching TI-99/4A CPU memory. Did that for testing some subroutines of the spectra2 library.
Upon program startup 2 threads are started.
Thread 0 is used for updating the memory location while navigating through memory (up/down=page up/down, left/right=line up/down)
Thread 1 is where the action is. It takes the current memory location and dumps memory to the screen.
The screen is constantly updated, so you'r kinda watching "realtime".
http://www.youtube.com/watch?v=0ZIMwEkC_2I
Here's the cartridge binary:
memview.zip
Here's the source code:
       AORG  >6000
* Cartridge header
GRMHDR  BYTE  >AA,1,1,0,0,0
       DATA  PROG0
       BYTE  0,0,0,0,0,0,0,0
PROG0   DATA  0                     ; No more items following
       DATA  RUNLIB
MSG0    BYTE  13
       TEXT  'MEMORY VIEWER'
* Include required files
       COPY  "D:\Projekte\spectra2\tms9900\runlib.a99"
* SPECTRA2 startup options
SPVMOD  EQU   GRAPH1                ; Video mode.   See VIDTAB for details.
SPFONT  EQU   FNOPT3                ; Font to load. See LDFONT for details.
SPFCLR  EQU   >C0                   ; Foreground/Background color for font.
SPFBCK  EQU   >01                   ; Screen background color.
* Variables
TIMERS  EQU   >8342                 ; Address of timer table (8 bytes). Space for future slots reserved
MEMORY  EQU   >8350                 ; Current memory location
MEMOLD  EQU   >8352                 ; Backup memory location
RAMBUF  EQU   >8354                 ; Work buffer
* Main
MAIN    BL    @SETUP                ; Setup screen
       JMP   SETUP2                ; Start memory viewer
*      GENERAL SETUP -- GENERAL SETUP -- GENERAL SETUP
* SETUP ..:
* SETUP - Set up CPU memory and VRAM
SETUP   MOV   R11,R3                ; Save R11
       BL    @SCROFF               ; Turn off screen
       BL    @CPYV2M
       DATA  >0980,RAMBUF,10*8     ; Copy patterns of digit 0-9 from VRAM to RAM
       BL    @CPYV2M
       DATA  >0A08,RAMBUF+80,6*8   ; Copy patterns of letters A-F from VRAM to RAM
       BL    @CPYM2V
       DATA  >0800,RAMBUF,16*8     ; Copy patterns of 0-9,A-F to VRAM => set 1
       BL    @CPYM2V
       DATA  >0880,RAMBUF,16*8     ; Copy patterns of 0-9,A-F to VRAM => set 2
       BL    @CPYM2V
       DATA  >0F80,RAMBUF,16*8     ; Copy patterns of 0-9,A-F to VRAM => set 16
       BL    @CPYM2V
       DATA  >0380,COLTAB,32       ; Load color table
       BL    @FILV
       DATA  >0000,32,32*24        ; Clear screen
       MOV   @START,@MEMORY
       BL    @SCRON                ; Turn on screen
       B     *R3                   ; Return
*  Some data used by subroutine
COLTAB  BYTE  >C0,>C0,>F0,>F0,>50,>50,>50,>50,>50,>50,>50,>50,>50,>50,>50,>50
       BYTE  >50,>50,>F0,>F0,>C0,>C0,>C0,>C0,>C0,>C0,>C0,>C0,>C0,>C0,>04,>04
T3      BYTE  8,>F0,>F1,>F2,>F3,>F4,>F5,>F6,>F7
START   DATA >6000                  ; Starting position
*      MEMORY VIEWER -- MEMORY VIEWER -- MEMORY VIEWER
* SETUP2 ..:
* SETUP2 - Setup for memory viewer
SETUP2  BL    @PUTAT
       DATA  >0018,T3              ; Display 0..7 at Y=0 and X=24
       LI    R0,TIMERS
       MOV   R0,@WTITAB
       LI    R10,>0100             ; Set highest slot in use
       BL    @MKSLOT
       DATA  >0003,NAVI            ; Start navigator task
       DATA  >0103,DUMP,EOL        ; Start memory dump task
       B     @TMGR                 ; Run kernel task
* NAVI ..:
* NAVI - Navigate through memory
NAVI    DECT  STACK
       MOV   R11,*STACK            ; Save R11
       LI    TMP1,22*8
       MOV   @WVRTKB,TMP0          ; Get keyboard flags
       COC   @KEY1,TMP0
       JEQ   NAVIA
       COC   @KEY2,TMP0
       JEQ   NAVIB
       LI    TMP1,8
       COC   @KEY3,TMP0
       JEQ   NAVIA
       COC   @KEY4,TMP0
       JEQ   NAVIB
       JMP   NAVIZ
NAVIA   S     TMP1,@MEMORY
       JMP   NAVIZ
NAVIB   A     TMP1,@MEMORY
NAVIZ   B     @POPRT                ; Exit
KEY1    DATA  K1UP                  ; Up
KEY2    DATA  K1DN                  ; Down
KEY3    DATA  K1LF                  ; Left
KEY4    DATA  K1RG                  ; Right
* DUMP ..:
* DUMP - Take CPU memory dump
DUMP    DECT  STACK
       MOV   @MEMORY,@MEMOLD       ; Take copy
       LI    R2,23                 ; 23 rows
*  Do initialisation
       MOV   @MEMORY,R0
       BL    @PUTHEX               ; Display current memory address
       DATA  >0013,MEMORY,RAMBUF,16
       MOV   @ZTMP00,@WYX          ; Set cursor start position
*  Display byte values
DUMP1   LI    R1,4                  ; 4 Columns
       ORI   CONFIG,>8000          ; Set display bit
       BL    @MKHEX
       DATA  MEMORY,RAMBUF,>F0
       AB    @BD4,@BX              ; Next column
DUMP2   MOV   @MEMORY,R0
       MOV   *R0,R0                ; Display address
       ORI   CONFIG,>C000          ; Set bit 0-1 (display bit, next charset bit)
       BL    @MKHEX
       DATA  R0HB,RAMBUF,0         ; Dump word
       AB    @BD5,@BX
       INCT  @MEMORY               ; Next word
       DEC   R1
       JNE   DUMP2
*  Display bytes as string
       LI    R1,8                  ; Bytes to process
       MOV   @MEMORY,R0
       S     R1,R0
       LI    TMP1,RAMBUF
       MOVB  @BD8,*TMP1+           ; Set string length
DUMP3   MOVB  *R0+,TMP2
       SRL   TMP2,8
       CI    TMP2,33
       JLT   DUMP4
       CI    TMP2,127
       JGT   DUMP4
       SWPB  TMP2
       JMP   DUMP5
DUMP4   LI    TMP2,>2E00            ; Display '.' character
DUMP5   MOVB  TMP2,*TMP1+           ; Write byte
       DEC   R1                    ;
       JNE   DUMP3                 ; Repeat until all bytes processed
       BL    @PUTSTR               ; Display string
       DATA  RAMBUF
*  Update position counters
       AB    @BD1,@BY              ; Next row
       MOVB  @BD0,@BX              ; Start with column
       DEC   R2
       JNE   DUMP1
       MOV   @MEMOLD,@MEMORY       ; Restore current memory address
DUMPZ   B     @POPRT                ; Exit
ZTMP00  DATA  >0100                 ; Display position Y=2, X=0
       END
It gets interesting at 0:47 in the youtube video. When reaching the >9800 range you see a lot of changes.
Are these the GROM ports? I verified it on my TI-99/4A and it behaves the same.
The classic99 debugger does not show that behaviour.
EDIT: Looking more closely it shows, that it's the GROM read data/read address being triggered.
PAGE 0 9800 9802
PAGE 1 9804 9806
PAGE 2 9808 980A
Edited by retroclouds
This morning I dug out my old customized speech synthesizer. Some guy added a load interrupt switch to it back in the hay days.
Never made use of it, so thought that today is a good day to give it a try :D
I changed the program so that it can now attach itself to the load interrupt.
Note that the program lives in the cartridge space (>6000). I always use an 8K supercart, but it should work the same when burned to (E)EPROM.
Quite pleased with it ;)
Here's the updated binary and source code
memview.zip
       AORG  >6000
* Cartridge header
       DATA  PROG1
PROG1   DATA  PROG0                 ; Address of next menu item
       DATA  RUNINI
TITLE1  BYTE  21
       TEXT  'ATTACH LOAD INTERRUPT'
       DATA  RUNLIB
TITLE0  BYTE  13
* Variables
MEMORY  EQU   >8350
MEMOLD  EQU   >8352
* Execute this before RUNLIB
RUNINI  LI    R0,>1234              ; Set flag for attaching to load interrupt
       MOV   R0,@>8300             ; R0 in the SPECTRA2 workspace, not the GPL workspace (!)
       B     @RUNLIB               ; Initialize SPECTRA2 library
* Main
MAIN    BL    @SETUP                ; Load fonts, etc.
       CI    R0,>1234              ; Was flag set ?
       JEQ   ATTACH                ; Yes, attach to interrupt
       B     @MVIEW                ; No, so start memory viewer
* SETUP ..:
       BL    @CPYV2M
       BL    @CPYV2M
       BL    @CPYM2V
       BL    @CPYM2V
       BL    @CPYM2V
       BL    @CPYM2V
       BL    @FILV
       MOV   @START,@MEMORY
*  Prepare for timer table
       LI    TMP0,TIMERS
       MOV   TMP0,@WTITAB
       B     *R3                   ; Return
*     LOAD INTERRUPT -- LOAD INTERRUPT -- LOAD INTERRUPT
* ATTACH ..:
* ATTACH - Attach to load interrupt
ATTACH  LI    TMP0,WS1              ; spectra workspace at >8300
       MOV   TMP0,@>FFFC           ; Set vector
ATTAC0  LI    TMP0,RUNLIB           ; Entry point in spectra library
       MOV   TMP0,@>FFFE           ; Set vector
       C     @>FFFC,@ATTACH+2      ; >8300 ?
       JNE   ATTAC1
       C     @>FFFE,@ATTAC0+2      ; RUNLIB ?
       JNE   ATTAC1
       BL    @PUTAT
       DATA  >0503,MSG0            ; Successfully attached
       JMP   ATTAC2
ATTAC1  BL    @PUTAT
       DATA  >0508,MSG1            ; Failed to attach ...
ATTAC2  BL    @PUTAT
       DATA  >0805,MSG2            ; Press space bar to exit ...
ATTAC3  BL    @MKSLOT
       DATA  >0001,EXIT,EOL        ; Exit to title screen when key pressed
ATTAC4  B     @TMGR                 ; Start thread scheduler
*  Background task
EXIT    COC   @ANYKEY,CONFIG        ; Any key pressed ?
       JNE   ATTAC4                ; No, check again
       BLWP  @0                    ; Exit
MSG0    BYTE  26
       TEXT  'ATTACHED TO LOAD INTERRUPT'
MSG1    BYTE  16
       TEXT  'FAILED TO ATTACH'
MSG2    BYTE  23
       TEXT  'PRESS SPACE BAR TO EXIT'
* MVIEW ..:
* MVIEW - Start memory viewer
MVIEW   BL    @PUTAT
       BL    @MKSLOT
* NAVI ..:
NAVI    LI    TMP1,22*8
       COC   @KEY1,TMP0
       JEQ   NAVIA
       COC   @KEY2,TMP0
       JEQ   NAVIB
       LI    TMP1,8
       COC   @KEY3,TMP0
       JEQ   NAVIA
       COC   @KEY4,TMP0
       JEQ   NAVIB
       JMP   NAVIZ
       JMP   NAVIZ
NAVIZ   B     @SLOTOK               ; Exit
KEY1    DATA  K1UP                  ; Up
* DUMP ..:
DUMP    MOV   @MEMORY,@MEMOLD       ; Take copy
       LI    R2,23                 ; 23 rows
*  Do initialisation
       MOV   @MEMORY,R0
       BL    @MKHEX
       BL    @MKHEX
       AB    @BD5,@BX
       DEC   R1
       JNE   DUMP2
       MOV   @MEMORY,R0
       S     R1,R0
       LI    TMP1,RAMBUF
       SRL   TMP2,8
       CI    TMP2,33
       JLT   DUMP4
       CI    TMP2,127
       JGT   DUMP4
       SWPB  TMP2
       JMP   DUMP5
       DEC   R1                    ;
       DATA  RAMBUF
       DEC   R2
       JNE   DUMP1
DUMPZ   B     @SLOTOK               ; Exit
       END
