PULSAR SUBROUTINE
orion1052003
Is there some way to make this better? How can you control the length of time this "enemy" stays on screen?
1100 SUB PULSAR
1110 CALL CLEAR!TEST LINE
1120 CALL SCREEN(2)
1130 CALL CHAR(72,"804020100F080B0A0A0B080F1020408001020408F010D05050D010F008040201")
1140 P=7 :: CALL MAGNIFY(3)
1150 CALL SPRITE(#4,72,P,18,1,0,20)
1153 P=6 :: CALL COLOR(#4,P)
1160 FOR J=1 TO 8 :: FOR I=1 TO 7 :: P=7 :: CALL COLOR(#4,P) :: CALL SOUND(100,-1,I,2000,0) :: P=6 :: CALL COLOR(#4,P) :: NEXT I :: NEXT J
1165 FOR I=1 TO 100
1170 P=6 :: CALL COLOR(#4,P) :: P=7
1175 P=7 :: CALL COLOR(#4,P) :: P=6
1180 !ALL COINC(#1,#4,10,C)
1185 NEXT I
1190 GOTO 1190! TEST LINE
1200 SUBEND
Edited by orion1052003
If you're generally experimenting with 2 colors (not knowing their final values), here they are 6 and 7, then perhaps setting the values in the beginning of your program, like C1=6 and C2=7, could be used. Setting the value of P every time and right before you use it may only slow down execution.
For example
would become
1140 CALL MAGNIFY(3)
1150 CALL SPRITE(#4,72,7,18,1,0,20)
etc.
In lines 1170 and 1175 you even set the value of P after the COLOR, but it's never used (overwritten).
1150 CALL SPRITE(#4,72,7,18,1,0,20) You don't have to keep 7 as P to allow the sprite to change colors? 1150 CALL SPRITE(#4,72,P,18,1,0,20)
It seemed like the other day, when I had 6 or 7 in the CALL SPRITE statement it would only stay one color and when I plugged in a variable it changed colors back and forth, PULSATING, when I did 1170 P=6 :: CALL COLOR(#4,P) and 1175 P=7 :: CALL COLOR(#4,P).
1170 should be changed to this?
10 P1=6 :: P2=7
1170 CALL COLOR(#4,P1)
1175 CALL COLOR(#4,P2)
I changed it to the below, but it no longer works. The sound is remmed out, but there is an error and it stops at 1150.
1100 SUB PULSAR
1140 !ALL MAGNIFY(4)
1150 CALL SPRITE(#4,72,6,18,1,0,20)
1160 !OR J=1 TO 8 :: FOR I=1 TO 7 :: P=7 :: CALL COLOR(#4,P):: CALL SOUND(100,-1,I,2000,0):: P=6 :: CALL COLOR(#4,P):: NEXT I :: NEXT J
1165 FOR I=1 TO 100
1170 CALL COLOR(#4,P1) :: CALL COLOR(#4,P2)
1185 NEXT I
1190 GOTO 1190
1200 SUBEND
10 P1=6 :: P2=7
Yes.
1100 SUB PULSAR
1165 FOR I=1 TO 100
1185 NEXT I
1190 GOTO 1190
1200 SUBEND
As it is the value of P1 and P2 is zero. Think you forgot to set them with: 10 P1=6 :: P2=7
This seems to do it ...
10 P1=6 :: P2=7
20 CALL SCREEN(2)
1140 CALL MAGNIFY(4)
1190 GOTO 1170
