Newbie Needs Help
kamakazi
Hi All,
I am attempting to learn the Intellivision for development purposes. However, when trying to use a printed code of Merrick's Hello World code and compiling it with AS1600, I keep getting all kinds of errors. Would someone be kind enough to tell me what is going wrong? Is it my code or something else?
;;HELLO.ASM
;;by MICHAEL ALLARD
;;based on source code by Merrick J. Stemen
;;21 OCTOBER 2011
;;Program makes calls to EXEC
;;Not a REAL GAME!
;;Complier: AS1600
;;Portions of ROMHDR adapted from Joe Zbiciak's PONG
ROMW 10
ORG $5000
ROMHDR:
WORD $0001 ;Moveable Object Data Pointer
WORD $0000 ;RTAB
WORD START ;START of program
WORD $0000 ;Background graphics pointer
WORD ROMHDR ;CARDTAB
WORD TITLE ;Pointer to ASCIIZ Title String
BYTE $80  ;Bit 7 SET - Run code after title
BYTE $02  ;H/V offset
BYTE $00  ;color stack mode (0=CS; 1=F/B)
BYTE 1,1,1,1 ;color stack data (All blue)
BYTE $02  ;Red Border
TITLE: BYTE 100, "MIKE'S GAME",0
;;Print "2000" where the copyright data goes
;;(I realize that I only need two zeros
POST_TITLE: MVII #$2D0,R4 ;WHERE THE COPYRIGHT DATE GOES
MVII #$97,R1	 ;CHARACTER "2" - WHITE
MVO@ R1,R4	 ;PUT THE "2" ON THE SCREEN
MVII #$87,R1	 ;CHARACTER "0" - WHITE
MVO@ R1,R4	 ;"0"
MVO@ R1,R4	 ;"0"
MVO@ R1,R4	 ;"0"
MVO@ R5,R6	 ;PUSH R5
INCR R4
JSR R5,$187B
BYTE "Mike",0    ;PUT MY NAME OVER LAST MATTEL
MVI@ R6,R7	 ;RETURN FROM TITLE SCREEN
START: MVO@ R5,R6 ;PUSH R5
MVII #$0200,R4 ;START OF SCREENMEM
MVII $240,R0  ;TO CLEAR ENTIRE SCREEN
JSR R5,$1738 ;CLEARMEM
MVII #$027C,R4 ;WHERE TO PRINT THE MESSAGE
MVII #$0004,R3 ;COLOR TO PRINT THE MESSAGE
JSR R5,$187B ;PRINT DATA THAT FOLLOWS
BYTE "HELLO WORLD!",0
MVII #$02DE,R4 ;WHERE TO PRINT THE MESSAGE
MVII #$0000,R3 ;COLOR TO PRINT THE MESSAGE
JSR R5,$187B ;PRINT THE DATA THAT FOLLOWS
BYTE "PRESS F10 OR ESC",0
MVI@ R6,R7  ;IS THIS THE END?
And the error messages I keep getting:
00000000 ROMW			 00000000 ORG			  00000000 ROMHDR
00000000 WORD			 00000000 BYTE			 00000000 TITLE
0000000d POST_TITLE	   0000000f MVII			 0000000f MVO@
0000000f INCR			 0000000f JSR			  0000000f MVI@
0000000f START
  ;;HELLO.ASM
  ;;by MICHAEL ALLARD
  ;;21 OCTOBER 2011
  ;;Not a REAL GAME!
  ;;Complier: AS1600
0x0				    ROMW 10
ERROR - parse error at/before token "10"
0x0				    ORG $5000
ERROR - parse error at/before token "$5000"
0x0				    ROMHDR:
0x0				    WORD $0001 ;Moveable Object Data Pointer
ERROR - parse error at/before token "$0001"
  WORD $0000 ;RTAB
ERROR - multiple definition of label
ERROR - parse error at/before token "$0000"
ERROR - invalid opcode
0x0				    BYTE $80  ;Bit 7 SET - Run code after title
ERROR - parse error at/before token "$80"
ERROR - parse error at/before token "$02"
ERROR - parse error at/before token "$00"
ERROR - parse error at/before token "1"
0000 0064 004d 0049  TITLE: BYTE 100, "MIKE'S GAME",0
0003 004b 0045 0027 0053 0020 0047 0041 004d
000b 0045 0000
000d 02bc 02d0   POST_TITLE: MVII #$2D0,R4 ;WHERE THE COPYRIGHT DATE GOES
0xf				    MVII #$97,R1	 ;CHARACTER "2" - WHITE
ERROR - parse error at/before character "#"
ERROR - parse error at/before character ","
  MVO@ R1,R4	 ;"0"
  MVO@ R1,R4	 ;"0"
  MVO@ R1,R4	 ;"0"
  MVO@ R5,R6	 ;PUSH R5
  INCR R4
  JSR R5,$187B
ERROR - parse error at/before string "Mike"
000f 0275   START: MVO@ R5,R6 ;PUSH R5
ERROR - parse error at/before token "$240"
ERROR - parse error at/before string "HELLO WORLD!"
ERROR - parse error at/before string "PRESS F10 OR ESC"
ERROR SUMMARY - ERRORS DETECTED 74
		   -  WARNINGS	   0
Any help in the right direction would be appreciated. For software, I am using the SDK1600 package with all included development apps. The "Hello World" code is from an Electonite document titled "Programming the Intellivision II. After reading the title, which I just noticed, is there a difference between the two or is this code for something else? Thanks in advanced.
You probably want a space before your instructions mnemonics so that the assembler knows its not a label.
You also had a # missing from a MVII instruction. Fixed code is here :-
;;HELLO.ASM
;;by MICHAEL ALLARD
;;21 OCTOBER 2011
;;Not a REAL GAME!
;;Complier: AS1600
   ROMW 10
   ORG $5000
ROMHDR:
   WORD $0000 ;RTAB
   MVO@ R1,R4	   ;"0"
   MVO@ R1,R4	   ;"0"
   MVO@ R1,R4	   ;"0"
   MVO@ R5,R6	   ;PUSH R5
   INCR R4
   JSR R5,$187B
   MVII #$240,R0  ;TO CLEAR ENTIRE SCREEN
GroovyBee is right. For reference, the Assembler treats all symbols flushed to the left margin as labels, whether they are followed a colon or not. So, your code
MVII #$97,R1
is interpreted as if "MVII" were a label followed by the invalid instruction "#$97, R1".
-dZ.
Edited by DZ-Jay
Came here to say the same thing as GroovyBee and DZ-Jay...
Strings that start in the first column usually get interpreted as labels. Most modern programming languages (except possibly Python) largely ignore white space. AS1600 (and most assemblers, for that matter) treat the first column of a new line as special, though, to distinguish labels from mnemonics / macros / etc.
(The major exception in AS1600 are the MACRO/ENDM directives, which want to start in the first column. That's really rather unique to AS1600, and comes from how Joe Fisher implemented macros in his IMASM tool that I integrated into AS1600. But, let's not get ahead of ourselves... just know that MACRO and ENDM are the two exceptions to "first column means a label".)
Er, Joe, if I recall correctly, you can also use a macro in the first column and it'll be expanded properly.
-dZ.
Edited by DZ-Jay
Groovy, what manual?
The first rule of the club is don't talk about the club. The second rule of the club is don't talk about the manual :lol:.
Shouldnt you be programming your 7800 games so you can hurry up and start the Intv ones, and stop harrassing the tourists!!!!
:P :P :P :P :D
:P :P :P :P :D
Ouch! Harassing the tourists, LOL!
-dZ.
